Question about Dell Inspiron 6000 Notebook
Computer I am having a problem with getting on the internet. I had my provider come out and verified I am connected. He also hooked up his system to my router and his worked. Any ideas what the problem may be?
My microphone is no enable on my laptop
Posted on Apr 17, 2008
I cannot check my emails
Dear Pamela,
The order in which you would like to verify connectivity to the computer is important. Depending on your provider. Most provide what is nicked named as a surf board. Which is between your line coming to you with the signal, then the router, and then to the device . No matter what it may be.
To verify. Open the internet shortcut link to the lower right of your screen in the startup section. Right click it. Two choices will appear. Troubleshoot Problems or Open network and sharing Center. Follow the directions and verify connectivity.
Should a no connection to internet check cabling appear. go to your first source feeding the system to reboot the Surf Board. Remove power for no less than 10 Seconds . Plug it back into the system and wait for a reset and the fault to clear which will be visible in the icon at the lower right of your screen. If it does not clear. Then go to your Wireless Router and press the reset button on the back of the unit and let cycle to verify connectivity. Should that not work ,unplug it and wait ten seconds and power back up.
These actions correct 90% of the needed actions for most cases knowing it was working and an interruption has occurred. You may have to restart your computer if updates and settings were interrupted. In any event this procedure works as a general form for all.
If you have internet capability. And you need internet support . Go to this link
3G9WB 7 2 Wireless Broadband Home Network Gateway NetComm Wireless
Firmware and Upgrade instuctions. Go to this link Support 7 2 Wireless Broadband Home Network Gateway 3G9WB
Fare. Well.
Jan 04, 2015 | NetComm Telstra Bigpond 3g9wb 3g Wireless...
Tip
Internet Connection Basics
Modern high-speed internet connections are made using DSL or cable modems. In general, most DSL modems also act as routers, but not too many cable modems act like a router.
Some internet connection basics: Every device connected to the internet has an IP (Internet Protocol) address. The address consists of 4 groups of up to 3 numbers each. They would look like this: 123.111.36.145 (0 is the smallest number and 255 is the largest you will see). When you connect to the internet, you are assigned an IP address by your ISP (Internet Service Provider). When you hook up your computer
to the modem, the signal is passed through the device to your computer and the device's IP address becomes your address. This is not secure, as the "bad guys" could type your IP address into their machine and theoretically see your computer and access all your data.
Connecting with your modem: Modems come with a CD nowadays. Running the setup CD makes connecting quite easy. With a DSL modem, you normally have to provide a username and password to log on. Cable modems generally rely on the cable connection to your house to recognize who you are and when you run the setup CD, you are automatically connected.
The router: The purpose of this device is twofold--one is to take the signal you get from your ISP and send it to a number of computers in your home network. The second purpose is to take the IP address and send it to a different address on each computer. This acts as a "firewall" in that the IP address assigned to your computer is no longer the address of the computer. Those bad guys trying to hack into your system will have a much more difficult time.
Types of routers: There are wired routers capable only of hooking up computers with ethernet cable within a network. There are wireless routers--normally these have 4 wired ports and a set of antennas. These function will in a mixed environment of wired and wireless computers. Most people these days are using wireless routers.
In my next tip, I'll describe how you go about hooking up your new router to an existing internet connection.
on Aug 09, 2010 | Computers & Internet
Trying to send an email with pictures but it freezes every time i try and send
Have you tried sending an email using different computer? Most of the time, internet connection and internet browser are the common cause of system freeze up when sending an email.
Try to access your email in a different computer that is connected to a different network. If you're not able to duplicate the problem on different computer, then the problem has something to do with the computer that you are using.
Contact your ISP to verify if there's any issues with the internet connection. Or clear the cookies, internet files, and browsing history of your browser.
But if the same problem occur while using different computer, you must check the file size of the picture that you are trying to send. Most email provider could support attachments that has 32MB, 50MB, 1GB attachment. But it will depend on your email provider.
Thank you and good luck!
Jun 29, 2010 | Yahoo Mail
How do I get my EnGenius ESR-9752 router to work with my Actiontec GT701 modem? I have a desk top computer using XP. I just bought a lap top with wireless capabilites. I want to run this system through the...
1. connect yellow cable from Actiontec to the internet port (labeled internet)
2. Power cycle the engenius router.
3. login to the Engenius and verify the status. You should an IP Address from the ISP (Internet Service Provider). If not then you will have to verify the IP address from the router.
4.Make sure the laptop the see the wireless connection.
5.Verify the "ESSID" if your router and connect.
Apr 25, 2010 | Computers & Internet
No internet ask for account data
Contact your service provider and make sure that you have a Data plan on your account - or that it has been 'keyed-in' properly on their computer system so that you will have internet service
If you you have a data plan and verify that it is in the system - and you still don't have internet access, ask to talk to your cellular provider's Tech Department when you call them in order to verify the correct access codes have been properly programmed in your phone.
Apr 07, 2010 | Cell Phones
I have a belkin router N-150 F6D4230-4 and it has been hooked up for a while. Well, I had to get my internet turned back on today and now my wireless internet does not work. The modem light is flashing on...
It would be best if you setup the router again. Restore the router to factory defaults. Note: This will remove all previously configured settings "some router has reset button on the back of the router cover by a sticker. The reset button is small that you need a pen to reset it."
1.Unplug the power to the cable / DSL modem
2.Connect the power to the router.
3.Connect a computer to one of the LAN ports of the router.
4.Restart your computer.
5.From the computer connected to the router, open your web browser (internet explorer).
6.Enter the router's address, http://192.168.2.1
7.Click Login in the upper right-hand corner of the page. The router does not ship with a password, so just click Submit.
To configure the router to connect to the Internet, you must enter information provided by your Internet Service Provider (ISP) into the "Connection Type" section in the left-hand column under the "Internet WAN" heading of the router's configuration page. If using DSL Internet, you may need to enter the PPPoE username and password. Likewise, if you have been issued a static IP address by your provider, the static IP fields (including network mask and gateway) must also must be set in the router.
ISP Connection Type
AT&T PPPoE
Charter PPPoE, Dynamic
Comcast Dynamic
Earthlink PPPoE, Dynamic
Qwest PPPoE
Road Runner PPPoE, Dynamic
Verizon PPPoE, Dynamic
8.Plug the power back into your Internet modem.
9.Verify that this computer can connect to the Internet properly. Open a new web browser and visit a few Internet sites such as Google.com or Yahoo.com.
10.Finally, configure additional network security features as desired to guard your systems against Internet attackers
If issue is not resolve you can contact your Internet Service Provider for assiatnce.
Nov 20, 2009 | Belkin Computers & Internet
Have system for voip. Only can't hook up the
Try getting a router that has one in/4 out between modem n voip. Your voip unit should have an RJ45 connector to connect to router, not your computer. The USB connector might be to connect the voip to a different type of router, and will not be used. The 2 phone connectors are for two different phone lines that your voip provider can provide you with.
Sep 20, 2009 | Toshiba DOCSIS Cable PCX2600 (DAZ8823A-R)...
Cannot share my cable modem connection
You need to connect a router to the cable modem.  The router then gets an IP address from Comcast and provides a gateway between the computers connected to the router.
The modem expects to communicate with a single Ethernet device, and provides an IP address to the first device that provides a piece of data called a MAC address.  By placing a router in-between, the router gets the IP address that lets you communicate on the Internet.  It provides local IP addresses to the equipment connected to the local Ethernet and "routes" those to the Internet.  You can either hook your two devices into the router if it has enough ports, or hook you switch to the router and hook your PC and PS3 into the switch.
May 05, 2009 | Linksys EtherFast EZXS16W 16-Port Ethernet...
Sharing a connection with wired and wireless computers
i just have a question, do you have an internet connection when your computer connected to your modem(the device provided by your Internet Service Provider)? Possible that the Belkin not working is that maybe you don't have internet from ypur ISP.
I suggest you to connect your computer first to the modem, turn off the pc and afterwards the modem, after 2 minutes, turn on the modem first, when all lights stable, turn on the pc and check if you can go online. If not, better contact your ISP first for them to check the connection. If everything working fine with your ISP. Reply to this post again and provide the following information.
Your ISP?
Brand of the Modem?
Brand of the Belkin Router?
Type of Connection you have form ISP, DSL or CABLE?
If DSL, please make sure that you have a username and password from your ISP?
How many computers do you have?
What is the Windows Version your using or the Operating System?
Thanks.
Sep 29, 2008 | Belkin (F5D7231UK4) Wireless Router
Hooking Sprint aircard to Wireless Boroadband Router
You could do this, it would be a bit of work! You would have to dedicate the computer with the sprint card to provide the internet connection to your router, which would then supply all the other computers with internet.
Assuming you have windows XP or Vista on the machine with the sprint card you would enable Internet Connection Sharing, which would provide an internet connection into whatever is plugged into the ethernet port, your router.
Hope this helps!
Feb 13, 2008 | Linksys Wireless-G Broadband Router
Dell Inspiron 6000 Notebook Logo
41 people viewed this question
Alun Cox
