Question about Sony Playstation 3 (PS3) Console
Blu-Ray sound I have PS3 hooked to TV with HDMI cable and fiber optic to stereo but no sound
  • 55 Answers
Go to Sound settings and select audio output to Optical.
Posted on Sep 05, 2008
I just wanted to know how to hook up my lg 3d blue ray player. i'm not home so i can look at anything. I need to know how many HDMI cords I may need to plug in my tv, digital cable box, the a/v...
You can do this two ways.
Way #1 connect your cable box to your a/v receiver with one hdmi cable. Connect your blu ray player to your a/v receiver with a second hdmi cable. Lastly, connect a third hdmi cable from the a/v receiver to the television. (3 hdmi cables needed this way)
Way #2 connect your cable box to your television with one hdmi cable. Connect your blu ray player to your television with a second hdmi cable. Connect your a/v receiver to your television with a RCA/composite a/v cable or with a fiber optic cable. Connect your cable box to your a/v receiver with a fiber optic cable or RCA/composite a/v cable. Lastly connect your blu ray player to your a/v receiver with a fiber optic or RCA/composite a/v cable. This method takes 2 hdmi cables and three sets of fiber optic and or RCA/composite a/v cables.
Can't get more specific than that without having the a/v receiver's model number, type of cable box, and television model number. Hope this helps.
Jul 22, 2011 | Audio Players & Recorders
I wanted to know if there is a way to hook up the sound from a Panasonic DMP-BD655P-K Blu-Ray player to my existing Yamaha DVX C310SW home theater system. I know I can hook the Blu Ray directly to the TV...
Yes this can be done. You have several options for audio hookup. Stereo 2-channel (white and red) RCA cables, digital audio (optical or coaxial) or HDMI. Your home theater must have the inputs available such as optical, coaxial etc. Typically the stereo 2-channel RCA is the simple way. Just connect from the Bluray audio outputs to the Home theater inputs (white and red) for stereo sound. Select the input on the home theater. For Dolby Digital 5.1 use optical digital audio cable (black port) or coaxial (orange RCA port) from Bluray to similar home theater input.
Mar 06, 2011 | Yamaha Audio Players & Recorders
PS3 surround sound
You will need the optical cable. My receiver only passes video through the hdmi. So I hooked up the HDMI cable to the tv, and the optical cable to the receiver. Once that is done you have to go to the audio settings for the PS3 and chose audio through the optical.
Dec 22, 2009 | Sony Playstation 3 (PS3) Console
Blu ray connect to my sc-pt660
as far as hooking up your blu ray player to the sc-pt660, the only real way to utilize the surround sound (with true surround sound) is through the optical audio out. You need to connect your blu ray player through hdmi to your tv and then connect your blu ray player to your surround sound using the optical audio out/in. I, personally have the sc-pt660 hooked up through component cables so I don't waste an HDMI input on my TV. Except for cd's, there is no reason for you to use the actual dvd player part of the surround sound considering you have a blu ray player. In conclusion, hooking your blu ray player and the sc-pt660 up to get better video simply isnt possible (your blu ray player alone gives the best possible resolution, 1080p). As far as audio goes, run an optical audio cable from your blu ray player to your sc-pt660 to get true surround sound.
Mar 23, 2009 | Panasonic SC-PT660 Theater System
No sound
I had the same problem on 3/21/09...I found it was the PS3 settings. I had to go into the visual settings (not sound) and change the linear sound to optic digital...but I also had to purchase a digital optical cable...plug everything into your tv instead of the receiver and then hook up the digital optical cable from your tv to the receiver. A it will work and b it is a better sound quality than that of the HDMI cable.
Mar 14, 2009 | Yamaha HTR-6130 Receiver
HK AVR 645 7.1-Receiver Turns off when sound starts to come through
did you figure it out? I bet your problem is the same as mine NOT HDCP complitant.... its gettting a signal from the bluray that can not be accepted... research HDCP compliant... my ONKYO does the same thing...
Jul 10, 2008 | Harman Kardon AVR 630 Receiver
Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Is Yamaha HTR-640 a receiver? Try HDMI from PS3 to receiver or Sony HDTV. If HDMI from PS3 to receiver the you need and HDMI from receiver to out Sony HDTV. You could connect everything to receiver and HDMI out to HDTV. You can not have an HDMI cable AND an optical cable coming out of the PS3, only one or the other.
Dec 30, 2007 | Yamaha HTR-6130 Receiver
Hooking up a PS3 to my surround sound
you have to go to the set up menu and let the receiver know that you are inputting dvd audio to the digital in. (assigning). that way, when you switch the receiver to dvd, it will look for audio from the digital input. your receiver manual will guide you through that set-up.
if that does not work, the fiber optic cable could be bad. this is more common than people would expect.
another option is to just rca cables to the receiver from the ps3. there is an adapter that lets you do that.
good luck
mark
Dec 28, 2007 | Televison & Video
No Audio
What port do you have the HDMI from you BD player into on the 510. If you have it on the DVD port then fiber optic will do you no good, the DVD HDMI only supports digital coax, the Video2 HDMI only accepts fiber optic, and there is an extra fiber optic for the Sat input. If your BD player does not have digital coax out, or if you dont want to buy another cable, just move the HDMI from DVD to Video2 on the 510. I am willing to bet you have the BD player plugged into the DVD HDMI port and the fiber optic cable from you BD player to the Video2 fiber input.
Dec 18, 2007 | Sony STR-DG510 Receiver
Sony Playstation 3 (PS3) Console Logo
82 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
