Question about HP LaserJet 2420 Printer
HP Laserjet 2420- Late Paper Jam
I have a HP laserjet 2420 that gives me a late paper jam quite often. It needed a maintenance kit, so I bought a kit and installed it, and it still gives me the same error message. Any Ideas on what may be causing this error message?
  • 1 more comment
  • varindershar Jul 01, 2008
    paper jam when i give print
  • Anonymous Oct 01, 2008
    My piece of equipment keeps stating "Jam Inside Rear Door" however I have taken out all the paper that was jammed but the message continues to come up....How can I fix this?
  • LSVIVERA Oct 21, 2008
    I HAVE SAME PROBLEM ONLY HALF SHEET WILL COME OUT AND PAPER JAM. IN THE DISPLAY IT SHOW 13.4 UNEXCEPTED ERROR.
    Problem Solver:
  • 7 Answers
1) Your paper tray may be too full, makes it heavy to lift and not enough pressure for the pick up roller.
2) Pick up roller is slippery, wipe it clean with alcohol to make it abbrasive.
Posted on Jul 08, 2008
HP LaserJet 1020 paper jam alert
Here's a video Harshit kumar suggested as a solution to your problem from YouTube:
Fixing a Paper Jam - HP LaserJet 1020 Printer
Apr 17, 2013 | HP LaserJet 1020 Printer
Paper jam paper canon 2420
the problem is the paper go in wrong way and we pull out one piece of the paper is missing , the massage saying paper jam hellp us thanks
Oct 10, 2012 | HP LaserJet 2420 Printer
LaserJet 2420 Printer: hp 2420n 13.20.00 jam inside rear door...
i have 2420 dn printer..printer reddy mode the power on...but not initlizing...13.20 paper jaming error coming but paper is not jam..hw to resolve
May 06, 2010 | HP LaserJet 2420 Printer
Hp laserjet 2420 paper jam 13.20.00
Hi, check throughout the printer for small pieces of paper stuck, broken sensors etc, clean the rollers in the paper tray 2, check for wear. clean the registration rollers (under a metal flap under the print cartridge) do not clean the transfer roller (the spongey roller sitting under the drum!)
Feb 09, 2010 | HP LaserJet 2420 Printer
Getting the error on my HP 4345mfp - TOP OUTPUT BIN, PAPER LATE JAM. 5017-Oct-2009 02:02 PM18209913.09.0048.081.2TOP OUTPUT BIN, PAPER LATE JAM 4917-Oct-2009 02:00 PM18209613.09.0048.081.2TOP OUTPUT BIN,...
my experience says jamming in duplex area using card stock. this may occur if default is duplexing. set default to single side and / or try same job using plain a4 80gm2
Oct 20, 2009 | HP LaserJet M4345 MultiFunction Printer
My HP Laserjet 2430dn makes a grinding noise after power on.
CHECK RS PRINTER PARTS FOR HP LASERJET 2400 2420 2430 PRINTER GEAR KIT
Feb 26, 2009 | HP Office Equipment & Supplies
Blank printing
Did you pull the plastic tape from the side of the cartridge?
Nov 14, 2008 | HP LaserJet 2420 Printer
Duplex Path, paper late jam
Can you save that one document as a pdf and print it?
Feb 20, 2008 | HP LaserJet 2420 Printer
Hp 4300 laserjet
Does it jam at the fuser when doing a single print?
These machines have a Maintenance kit required every 200 000 prints, these MK's include all feed rollers, a transfer roller and the entire fuser assy. To replace the kit fixes all issues I've seen in these printers besides when the cartridge affects print quality.
If it is jamming at the fuser on a single print done via the printer operations panel, and your paper is fresh, it could only be the feed roller having trouble gripping the paper or the fuser not turning/stuffed.
Feed Kit, I have my doubts as to this being your problem
Maintenance Kit Fixes 98% of the time
Was is noisy before it died?
I have seen a few with stuffed fuser drive gears but not many and customers could hear it wearing.
How many prints since last MK? via keypad print a configuration page, count is there ie pages since last maintenance xxxxxx
Jan 31, 2008 | HP LaserJet 4300n Printer
False Paper Jam Error
Make sure the paper tray guides are set against the paper more likely to be the back guide not pushing the paper to the front of the tray. If you have the guides set correctly then place one sheet of paper in the tray and blot some methylated spirits on the leading edge along the page width and close the tray and try printing something.
You will have a jam repeat process 3 or 4 times then open tray and remove paper. Where you soaked the spirits into the paper there should be a grubby mark where the feed roller has rubbed and cleaned. Wipe the tray dry and put fresh paper in then hopefully you will now be able to print. If you cannot then the likely thing is that the paper feed pickup spindle is broken and will need replacing.
Hope this helps you and please rate me
Thanks J
Dec 14, 2007 | HP LaserJet 2420 Printer
HP LaserJet 2420 Printer Logo
719 people viewed this question
Ben Johnson
