Question about HP LaserJet 3050 All-In-One Printer
3050 everything prints "dark" - background and print
  • gypsymom May 08, 2008
    when you copy anything it puts a line down the middle of the page.
When we copy or scan we get lines at both side throught
the paper
Posted on Jul 19, 2008
the paper
Why when I select color copy on HP Deskjet 3050 J610, it prints with a blue background?
The issue is from the glass on the copier, it would be better if you clean it very well or possible change.
Aug 20, 2014 | HP Deskjet 3050 All-in-One J610A Printer :...
Why do I get bleed through printing on page.
You didn't use HP ink and/or recycled paper is in your printer. Also check that dark/heavy ink is not selected on printer setup on the computer.
Jul 29, 2014 | HP LaserJet 3050 All-In-One Printer
Printing text quality
Through printing or copying?Copying: Increase dark in quality..Printing: check in printer preferences,remove check mark at economy mode..check..For Tech guys only: Remove adf unit, take out laser scanner unit, clean reflecting mirror & motor reflector gently with ear buds..fix it back..check..quality..
Jan 31, 2012 | HP LaserJet 3050 All-In-One Printer
My HP Laserjet 3050 frequently pauses when I try to prints PDF documents, but everything else seems allright. This is causing a problem and when the printer is trying to load the document it is like it...
When you select your printer from Acrobat you need to click on the advanced tab on the lower left of the print driver window and set it to print as graphic. This will speed up printing dramatically.
Sep 05, 2011 | HP LaserJet 3050 All-In-One Printer
Dark Background on the paper
replace the drum unit (toner) your drum is weak causing dark background
Nov 21, 2009 | HP LaserJet 4 plus Printer
Dark background print in minolta EP2050 mach.
Replace controller/ interface board. The next step would be the regulator board. If you must keep resetting the ATDC and receive different values ( assuming that the ATDC is new) then the problem is back. What supplies/ controls the ATDC? The controller, but forgive me if I am wrong, there is a small interface board after the controller that the ATDC is plugged into.
Dec 24, 2008 | Minolta Office Equipment & Supplies
Dark background on Dell 1700 printing
Faulty (or wrongly) remanufactured cartridges can produce a 'background' to a print, which can be even across the page or have a mottled effect.
Do a printer self test page (press the arrow button).
put the old toner cartridge back in and do the same.
Does the background show with the old cartridge ?
If it does, its a drum unit problem, if not its a toner cartridge problem, and that should be under warranty if you've just replaced it.
Dec 06, 2008 | Dell 1700n Laser Printer
Printer making funny noise and print is almost peeling off the page on the right side
Your problem is with the fixing film in the fuser assembly (HP Part #RM1-3044). The brown material you see is the plastic film ripping and peeling off of the hheating element.
Jan 23, 2007 | HP LaserJet 3050 All-In-One Printer
HP LaserJet 3050 All-In-One Printer Logo
442 people viewed this question
Seeker5211
Seeker5211
