I have a emachine 2220 the power just went off i have replaced the power pack but nothing happens i have held the start button for long periods and still it wont turn on
  • sammyxyz Apr 26, 2008
    same model of emachine (2220), some problem happened similar date (Apr). No power, no fan except a green light in the motherboard is on. How to sort this out?
Bad power supply. you can try to reset the cmos and see if that helps ( a tiny jumper close to the cmos battery)
If it doesn't help, it is power supply for sure :(
Posted on May 21, 2009
Buy a new PC (not an emachine)
Posted on May 16, 2008
I have a emachine that powers ou, power pack fan, cpu fan but not the hardrive. It shut down and now won't start up. No beeps
Unplug from AC, open the case, clean if necessary, reseat the memory mods, use Electronic Contact Cleaner spray on contacts, plug in, push the on/off button. Does it begin to start, and in a few seconds completly shuts down? No LED's , no fans, nothing? Sounds like a PSU failure. Mine went out in 6 years.
Jan 09, 2013 | Computers & Internet
EMachine 2862 Desktop Dead On Power-Up
check all the leads to the hard drive and check that the fan starts spinning when you switch it on if it dont start then the problem is the switch these do often go and can be easily replaced and they are not expensive i had the same problem and found that it was just the switch hope this solves your problem for you you can bypass the swith so that the computer comes on when you turn the plug on but when you shut down the computer this shuts everything down but the switches are cheap enough to buy if you have changed the power pack then the only thing it can be is switch .................................
Oct 31, 2007 | E-Machines T2682 (000002965) PC Desktop
My emachine won't power up.
Power is not working.replace the power cord and check if it stays the same then your power box is not working.
Jul 16, 2012 | E-Machines eMachines Desktop PC
My sons eMachines 2220 will not come on, not a bleep, not a light nothing, is it worth buying a new power supply and if so, how much do they cost?
It looks like this computer supports processors from the Pentium 4 family of processors. If that is the case, then in my opinion, no, it is not work fixing (unless *maybe* you have a spare and compatible power supply laying around). We are currently 3 processor generations past that now, if you count sandy bridge as a separate family past the original i7 processors.
Feb 02, 2012 | Computers & Internet
I have a T3626 emachine that I replaced the drive.
check all your ground screws on the motherboard. If that doesn't work try booting it up with out the hard drive. if that doesn't work, pop out the BIOS battery and unplug your computer, let it sit for about a min. and put the battery back in and restart.
Sep 18, 2009 | E-Machines Emachine T5026 power supply **...
Emachine T3624 will not power up
Emachines are notorious for having faulty power supplies. If your lucky you just need to replace the power supply. I've seen a lot of them where the power supply also fried the motherboard.
Please don't forget to rate this solution.
Jun 15, 2009 | E-Machines T2984 PC Desktop
Pushing the start button and nothing happens on my emachine T2984
I think your power supply has gone bad and will need to be replaced. You can get a 500 watt power supply for about 60 bucks and you can replace it yourself. very easy
Dec 07, 2008 | E-Machines eMachines Desktop PC
Presario v2000 stuck in hibernation, can't power it up
remove battery plug in power...see what happens ...nothing happens press and hold power button until you hear response(shut down)press power as usual to boot.if it doesnt work first time try a few times more remember to keep power button pressed to shut down.
Oct 19, 2008 | Compaq Presario R3000 Notebook
Computers & Internet Logo
361 people viewed this question
David Payne
David Payne
