Question about Palm TX Handheld
Palm Reboots when on Internet
When I try to access the Internet on my Palm TX it automatically reboots. When I try any other program the system is just frozen; can not touch activate anything. Please advise. Thanks.
  • 2,794 Answers
What happens when you press the reset button on the back of the TX?
Posted on Jun 09, 2008
Every time I try to hotsync-my palm tx shuts down and reboots-to preferences and set date-set time-why? and what can I do .DR J
Probably and error, back it up and give it a hard reset. Also, after any reset the first screen it always shows it to set date and time.
Jan 15, 2010 | Palm TX Handheld
Using the desktop, is there anyway to move(either to the memory card or the PC) or delete files on a Palm TX. I apparently used to much of the devices memory and now I can't ge to the home screen(it...
If you're able to hotsync, then yes. In the desktop, delete notes or other items (Does the TX have voice memos? Those would be a quick way to free up a lot of space!)
Perform a hotsync, and your Palm should then have some free memory.
If you're not able to hotsync, then nothing you do in the Desktop will have any effect on the Palm.
But, I'm skeptical that this is the real problem. It sounds more like memory corruption, and a hard reset is going to be the real fix.
Sep 14, 2009 | Palm TX Handheld
I have an entry in the memo feature of my palm. Everytime I try to access the information the palm goes black and reboots? What causes this to happen and how can I retrieve the information?
When a Palm OS device reboots like that, it shows that there is a driver conflict. Somewhere along the line some software that was installed is conflicting with other software on the device and causes the reset. I would suggest deleting applications from the device one by one and testing after each to see if the reset is still happening. If you are using the Palm Desktop software that came with the device and performed a Sync (backup) after you created the Memo... it should be saved and accessible in the Desktop software (Memo tab). If no Sync was performed after creating the Memo, you will need to remove applications one at a time until the software conflict is removed allowing you to run your device without the constant reboots. It's a bit of a tedious process, but the only solution if you didn't back up the device after creating the memo you are trying to retrieve.
Hope that helps
Aug 12, 2009 | Palm Treo 650 Handheld
My TX crashes every time I try to hot sync
You could delete that app if you want, however I would go into hotsync config and sync only one section at a time, such as Notes, but not contacts or calendar (or anything else). If it works then add a section, such as contacts. Keep adding sections until it malfunctions. Pimlico software makes a product dbfixit ($) that can fix database (blob errors). You can download and install it, and it will report on (but not fix) any errors it finds.
Feb 04, 2009 | Palm TX Handheld
Pda will not hotsync
assuming that you use your palm tx on a windows xp system, files from the emails could be corrupted. are you using palm desktop or outlook?
if you are using palm desktop, you can rename the back-up folder to old and try to resync
Oct 08, 2008 | Palm TX Handheld
Palm TX is resetting itself over and over
First Try letting the battery drain out. Then only recharge partially. I know this doesn't make much sense, but I have the same problem and have tried ALL the known fixes...reboots galore. The only thing that allows me to use the device in any way is a partial charge. Again, a fully charge TX will reboot over and over and over
Jul 07, 2008 | Computers & Internet
Email errors
I would erase the TX memory and reload the software.
The TX memory can be erased by pressing the reset button in the back of the unit while holding down on the power button. Press yes to confirm delete.
Reload Palm software from CD.
May 19, 2008 | Palm TX Handheld
Palm TX reboot
May 13, 2008 | Palm TX Handheld
Treo659 reboots constantly
Try a reset first but you more likely a hard reset will take care of this but it will wipe your palm. Anything you have added since your last hotsync will be gone and there is no way to get it back.. After you do the reset the next hotsync should put your info and programs back on.
Jan 04, 2008 | Palm Treo 650 Handheld
Palm TX Handheld Logo
83 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Don Eagan
 steve
steve
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
