Question about Pitco Frialator SG18S Deep Fryer
Pitco gas automatic 18
I have been told that i require a new relay board i have another pitco same year same model how could i go about  identifying the relay  board (to remove) myself? to use as replacment. Regards and thanks
    Sniper:
  • 114 Answers
This is the PITCO site and it has parts lists and operating manuals:
http://www.pitco.com/doc_lib.htm
Posted on Jun 13, 2008
Gas connection location on the back side. I am getting two 14's and two 18's. Location of the gas connection and it's size!
For the best gas installation/ instruction manual you can visit and download Owner's Manual at
http://www.pitco.com.
Regards.
Jun 23, 2011 | Pitco Frialator SG18S Deep Fryer
Why does my Pitco Frialator not heat to 350?
If your fryer has computer controller (the one with 8 product buttons and left, right arrow), check the display when you turn off the computer board, it should display "gas 2". If not, you have to change the gas configuration by accessing the programming mode.
Feb 24, 2011 | Pitco Frialator SG18S Deep Fryer
No fuel to the rail. New pump,filter,control module over radiator(2).checked inertia switch. if wire to inertia switch is same color code as wire leaving ECM then no power leaves ECM when switch is...
It helps if you tell what year,model, engine you are working on. Is power at the Inertia Switch? The power comes from the FUEL PUMP RELAY, the ECM only grounds the relay to turn it on. but not knowing what you are working on, thats all the info I have .
Sep 07, 2010 | Ford Taurus Cars & Trucks
My pitco gas frialator oil leak in tank .how can
You need to identify where the leak is coming.
If the leak is on the fry tank, best way to address it is to replace the oil tank.
Check the serial number of the unit with leak on fry tank, verify if it is still under warranty at PITCO web on http://www.middleby.com.
Jul 11, 2010 | Pitco Frialator SG14 Deep Fryer
Just purchased a used pitco frialator model no.145
Visit http://www.middleby.com and go to PITCO web, you can download there installation, operation and user's manual which you can use as reference.
Apr 10, 2010 | Pitco Frialator SG14 Deep Fryer
My GE XL44 Gas Range (Model JGBP34 GEP 1A) control
If you like the stove and it in good shape otherwise, have it fixed. The parts are still available. The stove in good used condition (without leak) is probably worth $75.00. May cost that much to repair it. Will cost approximately $450.00 to replace it with equal range. If it's a standing pilot model (no electricity needed) they are unavailable and your new range will require power to use the oven. Hope this helps.
Dec 07, 2009 | GE Spectra JGBP35 Gas Kitchen Range
Model S176W Jenn-air F-1 code flashing and beeping
Not sure what an F1 code is on that unit, but an easy check here,
shut off unit at breaker, remove face and unhook touchpad (ribbon) from the ERC. Turn the breaker back on, If the error code stops and it doesn't beep, the touchpad is most likely the problem. If it continues to beep and throw code, could be the Erc, (or something else telling the erc somethings wrong.) without knowing the F1 fault code, I wouldnt know where to start looking!
I would probably recommend a tech to reinstall the new Erc and or touchpad. Most new electrical components require extreme care when handling/installing, and a tech will know the proper procedures. Good Luck!
Sep 12, 2009 | Jenn-Air JGS8750 Gas Kitchen Range
Deep fryer from a restarant to change over to propane need orfices
I am looking at buying a pitco double deep fryer. It is natural gas, is it possible and at what cost to switch it over to propane. Model: F14S-CV - Serial: G99DC09212 Thanks Derek
Jul 19, 2009 | Pitco Frialator SG14 Deep Fryer
Converting a pitco frialator from natural gas to propane
you need to change the pressure regulator,burner orfices and possibly the gas valve.goto northernparts.com and type in the model of the fryer for propane
Dec 12, 2007 | Pitco Frialator SG14 Deep Fryer
Pitco Frialator SG18S Deep Fryer Logo
122 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Treefrog15
Treefrog15
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
