Advantech ADAM-4520  Serial Adapter
I can't use two adam modules with a 4520, help!!
posted by sdyc on Apr 15, 2008
When only using 4017 with a 4520, or only using 4050 with a 4520, the module can be found through ADAM-4000 Utility. But if using 4017 and 4050 with a 4520 at the same time, neither modules can be found in ADAM-4000 Utility. How can I solve it ?
thank u!!
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 29, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Do the addresses conflict?
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on I can't use two adam modules with a 4520, help!!:
I don't want to Accept this solution
Can you Help with these Serial Adapters problems?
Advantech ADAM-4520 (ADAM-4520-D2) Serial...
We have SSE device using Moscad protocol: Connections:...
I have three duplicate setups with each PC connecting an...
Serial Adapters
My DYNEX does you disconnect the cable of the badge for...
Can i use a USB to RS232 converter for my Adams-4520?
I try several cables but I cant get conection from modem...
Loading problems.
Need Immediate Assistance?
Chat Live Now!
Repair Service
Find Serial Adapter Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Computer Networking Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
