Question about Motorola Mobility HS805 Consumer Headset
Bluetooth module not attached
Bluetooth working fine. Suddenly on trying to 'connect' to head set the phone tells me..."bluetooth module not attached". I cannot find away around it...please help.
Ray.
Had the same problem. i read that you need to turn off the phone and turn it back on that should fits the problem. i tried it and it corrected the same problem you have.
stanley
Posted on May 03, 2008
Bluetooth quit connecting with Moto Razr Phone
Go to bluetooth and see what is listed click on it and remove device. Start over.
May 03, 2017 | Motorola Mobility H700 Wireless Headset
How to connect the blue tooth head set to this phone
go to settings, wireless and networks, bluetooth.
make sure bluetooth is on.
turn on your headset, to sync the new headset, normally you have to turn on the device and continue to hold the power button until the headset goes into bluetooth sync mode.
normally around 10-15 seconds of holding the power button.
THen tell HTC to scan for devices. Your headset should appear. if it asks you to type in a code, it is generally 0000 or 1111
Feb 12, 2011 | HTC F3188 Smartphone
My speaker have water damage, i can hear but they cant hear me, can i use blue tooth
Hi, a blue tooth device would allow you to hear and speak through it so it should solve your problem.
the only problem you may have is if the water damage has causes damage to bluetooth inside the phone, try choosing bluetooth on your phone and see if you can still do a search and connect with another phone, if you can still connect to another phone to say send music or picture via bluetooth then this would suggest your bluetooth is fine and using a bluetooth head set will solve your problem and allow you to use your phone again.
if you cant connect to another phone via bluetooth then the chances are it wont pick up the bluetooth head set and you would be no better off
let me know how you get on or if you need further assistance ok
please rate this solution as i have a whole page of unrated posts, thanks
Dec 13, 2010 | LG enV3 VX9200 Cell Phone
Suddenly the bluetooth connectivity is not working. It always in ON Mode and when i tried to turn off the bluetooth it is getting cancelled. And the bluetooth searching is also not working . Overall the...
you should restore default factory setting
go to phone setting-master reset-restore factory setting it will ask for a password get from your phone manual
after that check whether it is working or nor otherwise contact your manufacturer
Jun 07, 2010 | Sony Ericsson S312 Mobile Phone - Silver
Bluetooth connects to LG Vu phone but does not work
I would suggest taking the battery out when the phone is powered on. Replace the battery and try to re-pair the set.
If that doesn't work, then its likely the bluetooth module in your phone is broken. You can validate this by pairing the bluetooth with another handset.
Jun 30, 2009 | LG Shine CU720 Cellular Phone
BLUETOOTH MODULE NOT ATTACHED
you need to switch on bluetooth headset with battery charged enough. also you need to put bluetooth in search mode to pair it with phone. see manual which came with bluetooth to get it in search mode.
Jan 01, 2009 | Motorola Mobility RAZR V3
I lose my Bluetooth connection, and the problem is with the phone
You will need now to take the phone and have the firmware reflash in the phone.
Dec 10, 2008 | Motorola Mobility RAZR V3
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.
2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select H500 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Jun 27, 2008 | Motorola Mobility H500 Wireless Headset
Bluetooth module not attached !
try this,., delete old pairing for ur bluetooth, and re- pair it again...gudluck
May 10, 2008 | Motorola Mobility RAZR V3
Krzr k1m won't connect to bluetooth device
Turn off the phone. Remove the micro-sd card. Restart phone. It should connect now.
Nov 22, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Motorola Mobility HS805 Consumer Headset Logo
47 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
