Question about Dell 924 All-in-One InkJet Printer
How to get my Dell Photo 924 to feed paper for printing?
  • Anonymous Apr 26, 2008
    The paper feeds into the first rollers of my printer, but then won't go any farther. I hear whirring and can see the parts moving near where the paper is supposed to come out, but it won't feed all the way through. I unplugged the power adapter, flipped the printer over, tapped the bottom, rolled the rollers manually, and looked for obstructions (I don't see any). Does anyone have any other suggestions?
    Scholar:
  • 41 Answers
If you are having issue with the paper feed ,How to get my Dell Photo 924 to feed paper for pri - moz-screenshot.jpg try these steps
1. Unplug the power adapter
2.open the printer cover , look for any obstructions inside , lift the printer and shake it firmly
3.turn the printer upside down and gently tab on the base,.
4. Put your Hand inside the Input paper tray and manually roll the two rollers
5. Put back the power adapter , turn on the Printer and try to copy a document from the printer.
Try all these steps and if you still have the paper feed issue then purchase the new printer
Posted on Apr 21, 2008
(1) put in paper
(2) push start button
(3) if all else fails,recycle the Dell and get something more reliable
Posted on Apr 16, 2008
My Dell AIO 924 printer will not feed paper.
1.Check inside the printer to see if you have the ink properly installed.
2.Make sure you don't you re-use papers that you have already used.
3.All papers have to be perfectly allined.
4.Check the connection wires between the computer and the printer.
5.Scan your computer with a security system to catch and eliminate viruses,tracking cookies etc.
If all else fails I don't know what to say
Jun 24, 2012 | Dell 924 All-in-One InkJet Printer
My Dell 924 CLAIMS it has a paper Jam and does NOT.... it will not clear this out and I can't print anything! Help!
check the feed rollers for a dirt build up , they can be cleaned with a damp cloth, the probable cause is slipping feed, the printer expects paper and none is fed due to the slipping of the rollers.
look where the front edge of the paper sits, there are rollers there that bring the paper into the printer, clean them.
Jan 11, 2011 | Dell 924 All-in-One InkJet Printer
It starts to feed and the rollers keep going and the paper stops and does not print
Start of layer. Dell 924 All In One Inkjet Printer. Click To Close ..... However it does a good job with photo printing on photo paper, .... I had contacted Dell about the problem I was having and I felt they were not going to do .... I bought a all in one dell printer, and it will not feed the paper, correctly. ...
catalog.ebay.com/Dell-924-All-One-Inkjet-Printer-/50399257/r.html
Jul 02, 2010 | Dell 924 All-in-One InkJet Printer
Paper jams when printing
just add some more paper to the tray..and arrange it properly..
i think the paper pick mechanism failed to pick the paper.or there is a long time delay before the paper reach the printing area..
thanks for using FIXYA!
pls let me know if it solve the problem..
May 21, 2009 | Dell 924 All-in-One InkJet Printer
Paper does not feed
Try feeding a post card or a different kind of paper thru the feeder tray, make sure that it is going in smoothly.
Try something innovative for checking out those rollers
Feb 08, 2009 | Dell 924 All-in-One InkJet Printer
Paper will not feed all the through the printer
I had the same problem with my Dell 924 and after EXTENSIVE research I found a forum where about 90 percent of the people with the same problem ultimately found some sort of foreign object in the printer. I spent about 30 minutes shaking my printer to no avail then I broke out the flashlight and started looking in every nook and cranny. I lifted up on of the small black plates on the roller towards the back of the printer (if you're looking in the front) and low and behold I saw something that looked odd. Grabbed some tweezers and fished out an allergy pill in a little bubble pack. Was wedged in there to good to fall out from the shaking. Take a piece of card stock or photo paper and try to feed it through the printer manually. If starting at the top, take note of where the paper stops and that should be where your problem is. Try feeding from the top and the bottom, if the paper will not feed through, something is in it's way. Hope this helps.
Dec 25, 2008 | Dell 924 All-in-One InkJet Printer
Dell 924 paper feed
you need to clean paper feed rollers with isopropanol alcohol on a microfiber towel or get a sheet of cardstock to print on as it prints it will force out any foriegn material
To correct paper feed function make sure feed sensor lever isnt broken
Oct 29, 2007 | Dell 924 All-in-One InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
190 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
