Question about Janome 6019QC Mechanical Sewing Machine
Janome 6600 tension
The tension dial is not working and the thread going through it is loose. The dial goes all the way up to 9 and is barely acceptable for general sewing but not for something I want to be done well. I did not notice why or when this happened and the machine probable has about 15 sewing hours on it since bought brand new.
  • Anonymous Jun 11, 2008
    I had this problem early on. I turned out the bobbin just wasn't in right. This machine is much more sensitive than my old (OLD) one. Everything has to be just right.
  • Janome Master
  • 1,388 Answers
Lint trapped in the tension dials is the most likely cause
If you are using a standard tension of 4 or 5 and this problem has developed over time, the most likely cause is lint deposited between the tension disks.......
Raise the presser foot and with a length of scrap fabric, use an action like flossing your teeth to get between the disks......in extreme cases a probe (old needle) may be used very gently to remove thread and lint, but be VERY careful not to scratch the polished surfaces.
I have also written a tutorial on tension balance which may be of further assistance:
Please TRY the solution BEFORE giving your considered rating.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
Janome 6600 tension - 4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
www.bargainbox.com.au
Posted on Nov 16, 2008
2 Suggested Answers
  • 323 Answers
SOURCE: Janome 6600 tension
You need to do a tension assembly test.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Tension assembly test. To do this test. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.)
If it doesn’t work this way then you probably have a piece of thread or lint stuck inside the tension discs. To remove it, turn the tension to 0 zero and raise the presser foot.Using a small screwdriver, open the space between the discs and spray with canned or compressed air. The stuff should come out. Do the tension test again to make sure you got everything and then try sewing again.
sewman7
Posted on Feb 16, 2009
Janome 6600 top tension too loose... a big wad of thread underneath. I've re threaded, tried a new bobbin, cleaned the machine.
Sounds like thread nesting (or bird nesting).
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct,.
Set the upper thread tension to the midway point and then tweak it for your machine.
Jul 29, 2017 | Janome Sewing Machines
Janome one step Despite altering the tension dial the top thread is looping on underside of material and when pressing the reverse button material puckers.I tried adjusting the tension dial from 0-9
Usually, this occurs because the top thread is not fully seated in the tension disk.
Reset your top tension to the midway point and then tweak it.
What causes Bird Nests Superior Threads
Birds nest under the fabric big loops of thread top side looks good...
Jun 07, 2017 | Janome Sewing Machines
Upper thread tension too loose even when I dial it up to 9
I suggest that you get in touch with http://www.janome.co.uk/index.php?option=com_chronocontact&Itemid=14 and have a chat with them ...
Mar 19, 2013 | Janome Magnolia 7330 Sewing Machine
Stitching is too loose on the Juno Janome Serger Model 3434D
sergers the most frustrating machines. Every time you change fabrics you go through a tension adjusting phase.
First make sure you have threaded the machine in the proper order. upper looper, lower looper, then needles from right to left. Always thread any machine while the presser foot lever is in the UP position.
If you ever break a thread... you MUST pull all threads and rethread using the proper order.
Ok that's out of the way. Pull all your threads and get out several pieces of the same fabric scrap. Thread each pathway with a different color. This will help you determine which thread is giving you fits. Sew a test strip. Which thread is loose? tighten/loosen that tension. Keep doing this until you have a well balance seam. Then clip the colored threads starting with the upper looper thread, tie off to your proper color for your seam pull the thread through and up through the throat plate. proceed in this manner with lower looper, right needle, left needle. Sew a test seam.
Good luck.
Aug 08, 2012 | Janome Sewing Machines
How to fix the tension on a memory craft 8000-way too loose at the top
it's possible that the tension dial has gone bad & needs to be replaced
at a sewing machine repair shop
Feb 27, 2012 | Janome Sewing Machines
Janome 6600 displays E3 Error. How do I correct
Hi
Direct from the Janome workbook E3 error relates to:
"Stepping motor for tension release (MC6500P & MC6600P only)"
Ensure there is no lint or thread trapped between the discs of the top tension unit.........try "flossing" where thread goes down thru tension unit with a scrap of clean fabric.
It may also be the mechanism that releases tension when the presser foot is raised....it is a sensor and may be out of alignment...not really an easy home fix.
Let me know how you get on, just remind me of the issue as I respond to many.
Bargain Box
Sep 15, 2009 | Janome Sewing Machines
Janome 6600 tension
sewman7
Feb 16, 2009 | Sewing Machines
Tension Problems with Janome DC3050
If your machine is binding. It sounds like you have a threading problem. Check your manual and rethread the machine. The A is for Automatic tension I would not change that. I would also notify your dealer and see if you have thread under the bobbin case. All sewing machines should be serviced each year.
Dec 13, 2007 | Sewing Machines
Janome 6019QC Mechanical Sewing Machine Logo
1,581 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
