Vehicle Parts & Accessories Logo
Posted on Apr 15, 2008
Removing vehicle locator from my dodge caravan
I need information on how to remove the vehicle locator from my car. Can you help
Aaron Hackbarth
Level 1:
Scholar:
  • Contributor 36 Answers
  • Posted on Dec 25, 2009
Aaron Hackbarth
Contributor
Level 1:
Scholar:
Answers
36
Questions
0
Helped
14215
Points
56
An easier way is to get a gps jammer. They make nice ones for cheap. Check the import sites from china. They make a small unit that plugs into cig lighter socket, and is no bigger than your thumb.
http://tayx.manufacturer.globalsources.com/si/6008827809982/pdtl/Security-products/1006202554/Car-GPS-Tracker-Jammer.htm
or
http://www.google.com/search?hl=en&source=hp&q=china+Car+GPS+Tracker+Jammer&aq=f&oq=&aqi=
Where is the flasher located on a 2008-2010 Dodge Crand Caravan?
Go to Autozone.com, register for free and enter your vehicle information-year, make, model, & engine size. Vehicle-specific repair guides are available, as well as component locations. It should show where to locate the flasher. Usually on older vehicles, the flasher is by itself under the dash. Newer ones often incorporate the turn signal flasher with the hazard flasher.
2answers
1999 dodge grand caravan speedometer and rpm not working
Sound like a problem with the VSS (Vehicle Speed Sensor) that is located in top shift linkage; its possible that need some adjust or replacement. First check fuses.
Hope helps.
2005 dodge caravan 2.4 , location of crankshaft position sensor?
2005 Dodge Caravan SE 2.4L Engine. Crank Shaft Sensor is located on the front of the engine (side toward the radiator) and right below the starter.
Raise the vehicle on stands or ramps. From under the vechcle, unclip the wire plug. Loosen and remove the 8mm bolt. Pull out old sensor.
This CAN be done WITHOUT removing the starter. Easiest way is to use a deep 8mm x 1/4” drive socket and good lighting. I had to use vise grips to grip and pul out the old sensor. It is okay to twist and pull.
NOTE: I have seen many posts placing this sensor in all kinds of places. For this vehicle, this is where it is located. If you have a different engine or year, it could be located someplace else.
3helpful
Need the wireing order for a 1992 dodge caravan in changing the termostate i removed the wires to reach the nuts marked them but the car runs bad must have them mixed up 3,3 liter engine caravan se
For the 3.3L:
Firing Order:
1-2-3-4-5-6
Cylinders:
(back of vehicle)
1--------3--------5
2--------4--------6
(front of vehicle)
Ignition Coil:
(back)
6---3
4---1
2---5
Let me know if this helped, or if you have additional information or questions. Feel free to contact me at FixYa.com!
I need change the computer in my dodge caravan 1999 v6 3.8
this is a fairly simple job. The location of the unit varies within the same year make and model.
Take your vin number and ask the local deal about recalls and -- where the location of you vehicle computer is - sometimes these are called brain boxes by dealers - - once located you will have little problem in removing and replacing the unit.
1helpful
What tools are needed to change a fuel filter on 2004 dodge caravan
Hi I'm litoshop first the filter is located over the fuel tank you may have to loosen the belts on the tank first you need a good jack and a pair of jack towers for security then you need a special tool to pull out the hoses you can buy it in any auto parts you can ask for fuel line remover remember before you work on your car disconnect the negative cable on the battery and secure your vehicle before you go under if you need more help you know where you can find me good luck. if this information has been useful please let use know thank you
Fuel rail removel
I WENT TO A DEALER AND CONSULTED A MECHANIC. HE EXPLAINED TO ME IN DETAIL ON HOW TO REMOVE THE FUEL RAIL. HE ALSO TOLD ME YOU HAVE TO LET THE VEHICLE REST FOR A HOUR SO THE PRESSURE WILL GO DOWN. ACTUALLY IT IS QUITE SIMPLE.
I need to locate the fuel filter
It's under the vehicle, on top of the gas tank. Depressurize the fuel system before removing. Countrycurt0
Power steering pump
The pump has to be removed from under the vehicle by removing the exhaust system from the flex bracket and moving it to as far left of the vehicle as possible..remember you have to remove the splash shield that protects the engine components first...then remove all associated bolts,hoses (plug them so they won't drip) and remove the pump from the vehicle..that it.
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
