posted by sootycat1 on Apr 15, 2008
This projector was working fine and as far as I am aware has over 1000 hours left. I switch it on (from cold) , it powers up (green light) I see the EPSON logo projected onto the screen and the menu's, then after about 45 seconds a high speed fan comes on, the screen goes blank, and the red light flashed every 1 second (the manual says this is an internal fault) has anyone got any ideas what the fault is ? is it going to cost me an arm and a leg to repair ?
Comment by sootycat1, posted on Apr 16, 2008
Hi Marrie,
The lamp looks fine. The LED that is flashing is the Lamp/Temp (red) every 1 second. The manual says blinking every 0.5 secs is lamp/heat fault, every 1 sec is internal fault, this is every 1 second and the fast fan comes on after about 45 seconds from cold so doesn't seem like an overheating issue unless there is supposed to be a primary colling fan that is faulty. Others have suggested Poss Power Ballast or fan switch fault, any ideas ?
Comment by sootycat1, posted on Apr 30, 2008
Thanks again Marrie,
I took it to a local PC repair shop who maintain and deal with the local school projectors and they have said there is a problem with the main board.
My problem is where can I get a replacement board for a decent price ?
I was told it would be cheaper to buy a new projector but surely there must be some spare parts around ?
Do you have any ideas where I can go, phone, email, internet for the correct bits - I seem to have hit a dead end other than ebay but in the last 2 weeks nothing has come up. . .
Thanks in advance.
Clarification Request
by Marrie, posted on Apr 16, 2008
Hi there
Firstly keep in mind that the hours they give you is only an estimate.
Take out the lamp and check for any irregularity on it , like shape or discoloration.
Could you tell me which LED on the Projector flashes ? Power or Lamp or Temp. ?
Best Solution
posted on Apr 17, 2008
Hi Sootycat
Ok , most of the time this would be the Fan.Powerboard that is faulty then and unfortunatelly it would be better to replace the part rather than having it repaired.
Repaired Powerboards normally give the same problem a couple of months down the line.
Rating Locked! (?) sootycat1 has rated this solution as Helpful
Suggest a new solution for this problem
Post a New problem for Epson EMP-54 Multimedia Projector
Email this problem
Email this problem
Can you Help with these Multimedia Projectors problems?
ceiling mount remote broken
Hi there -is there a way to... Answer This...
Repair Service
Find Multimedia Pro. Repairman Near You:
