Question about Acer n310 Pocket PC
Acer n310 pda power problem
The pda will not switch on at all now. Used to do this, but was cured by removing, then replacing battery, soft resetting. Know at least one other user with exactly the same problem. Can anyone help?
Thanks in anticipation
  • Anonymous May 22, 2008
    Hello, I have the same problem :( did somebody solve it?
    Many thanks
  • Jackoffski Jun 18, 2008
    got the same problem. hard reset it too much i think its fried.
I have a Acer pda model C530 and it has a switch that detects if the cover is correctly inserted, check that switch, buy electronic contact cleaner spray and clean it (and clean the battery contacts,on/off button) if possible try with a new or known good battery. If it has dropped to the floor it might have some bad contacts.
Posted on Oct 03, 2008
Laptop has frozen and won't even switch off
replace the batterry and try to switch on
Dec 09, 2010 | Samsung N310-13GB Netbook
Plain White Screen on My Acer n35 PDA
Connect an external monitor to your laptop and see what it displays. The white screen is your backlight, you just do not receive any data. This could be because of a bad video card or a bad LVDS cable. Try the external monitor and let us know.
Nov 01, 2017 | Computers & Internet
Acer N30 PDA charging problem
My PDA n30 is not a year old yet - when I put it to sync and charge everything looks fine but when I unplug it does not stay charged - it blacks out straightaway.
Please help
Jun 09, 2009 | Acer n30 Pocket PC
Screen align problem
try to do hard reset if its not works
try to update rom image
if still not works try to replace your touch screen to new one
Dec 15, 2008 | HP iPAQ H3950 Pocket PC
I can only especulate on all the possible reasons, so let go one by one throuh them and their possible solutions:
1. The RX3000 Ipaq family has a known mechanical issue on the switch that senses when the back cover lid is properly closed.
When the switch is nor properly depressed, the PDA won't charge the battery if plugged on the cradle or to the USB sync cable, or won't turn on.
Remove the back cover lid and the battery, put them back again. Check the cover lid is placed flush and that there is not any gap between the cover and the PDA body.
Try again in power it on and/or charge the battery, confirming the orange LED light is turning on.
2. Either the cradle/USB sync cable or the AC wall adapter are defective.
The PDA won't power on if the battery is not charged to the minimum voltage for it. If the AC wall adapter or the cable/Cradle are defective, won't power on.
Put to charge the battery and confirm the orange LED light is turning on. If so, the you can discard that the cradle/USB cable or AC wall adapter are defective.
It the orange LED light won't turn on, it may be either one of these three parts that are defective, or that the back cover lid is not properly closed.
3. The battery dried out. If the battery is defective or won't accept charge, the pda won't power on.
To discard a defective battery, put the PDA to charge it, and it will power on when plugged to the USB cable or to the charger, and check in the settings screen, on the power icon, if the battery is charging.
If the back cover lid is properly placed, and the PDA won't power on when plugged to the USB cable or AC wall adapter, then the battery is not the problem.
4. Discarding that the battery or the USB cable or cradle or the back cover lid are the problem for this problem, the only option that is left is that the main board is defective.
Such failure on the mainboard could be caused for several reasons (moisture or humidity or water damage, or a electronic component that is worn out, or a integrated circuit that is shorted, etc) but it can be only verified and confirmed by an electronics technician.
You have the option of send it to be repaired, or try it yourself, which will require to buy a PDA with working mainboard (or the mainboard alone) and swap the parts. It requires a minimum of technical skills to do it.
Best regards,
Apr 22, 2008 | HP iPAQ RX3715 Pocket PC
Connection to internet problems
Have you updated the firmware?
Mar 22, 2008 | Acer n310 Pocket PC
Dell Axim X50 PDA won't turn on
Had the same problem. Did some research and fixed the problem by performing a "soft reset". Tap the reset indentation on the back once quickly. Do NOT hold it in or you will lose all saved data. Mine's working fine now.
Feb 25, 2008 | Dell Axim X50 Pocket PC
Palm Tungsten E2 won't work after power cord is removed.
The traditional steps for resetting charging problems are:
1) press reset /while/ the power cord is plugged in
2) unplugging the battery for about 30 seconds, then plugging it back in
You have done #2, but I do not know if you have done #1. Try it, then try to recharge again. If that fails then you probably need a new battery. I have found them on eBay before.
Feb 22, 2008 | Palm Tungsten E2 (Multilingual) Handheld
PDA displays only a white Screen
Hello First of all please inform me if the pda displays ONLY a white screen. Are there any characters on the screen or something like this? Does a soft-reset or a hardreset helps solving this problem ?(please try these first). I will be able to assist you better if I know the answers to these questions. If you need more informations on how to do hard/soft resets please inform me. You may also find these informations in your device's user manual. Good luck and please reply with more informations.
Sep 07, 2007 | Acer n310 Pocket PC
Acer n310 Pocket PC Logo
367 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
