Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Water not flowing into ice maker
I have just recently put a new ice maker in my Frigidaire side by side that is only 5 years old. I can here the ice maker kicking on, but the water does not kick on to flow into ice maker. You can still get water from the door, but for some reason it does not kick on to flow into ice maker.
  • 4 more comments
  • surpatel Apr 22, 2008
  • Anonymous Jan 13, 2009
    Same as above. I tried to defront at the rubber inlet tube with no results.
  • philb1a Feb 24, 2009
    Same problem...no water will flow to ice maker...I can manually fill it and it makes ice and dumps it out...but then it won't refill...I did replace the dual water solenoid with a new one and still the same problem......any ideas....Phil
  • Anonymous Mar 16, 2014
    Water is running and working at the door. I can hear the motor in the back trying to pull water into the ice maker but no water is flowing.
    my ice maker water flow needs to be adjusted lower. How do I do that?
  • Anonymous Mar 20, 2014
    put in new ice maker and controler and now its putting to much water out
    Genius:
  • 1,073 Answers
Yes there is a problem with the water valve or the fill tube that puts water into the ice maker is frozen not letting water into the ice maker
Posted on Apr 17, 2008
Frigidaire refrigeratyor ice maker doesn't get watyer
either your filter was put on in the wrong direction or when u replaced there were stuff in the line and it stopped up the hose or your have a crimp in the line
Dec 23, 2015 | Frigidaire FFHS2611LB Side By Side...
JCD-23 making too little ice
Check the water flow to the ice maker. Turn the supply water off, loosen a fitting near the ice maker and then turn the water on. You should get plenty of water. If it is slow, check the filter.
Dec 01, 2013 | Frigidaire FRS3R5EMB Side by Side...
Ice maker problem
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Jun 08, 2010 | Frigidaire FRS3R5EMB Side by Side...
Water will not flow into ice maker
This has happened to me a couple of times. First check to see if water is dripping from the water line on the back of the freezer. If it is that means ice has formed at the intake on the back of the ice maker and isn't allowing water to get in. Pull everything out and defrost the freezer for 3 - 4 hours. Make sure you dry everything out before putting the food back in.
Jan 13, 2009 | Frigidaire FRS3R5EMB Side by Side...
Ice maker not working - Frigidiare refridgerator Model number FRS26BH6CB4
take the line off of the solinoid valve and check to see if there's a screen in the valve. that could be plugged with debris.
Dec 20, 2008 | Frigidaire FRS26R4A Side by Side...
A couple times recently , when the ice maker was on, it worked but accompanied by a loud click, click, click sound. Now is suddenly stopped working...any suggstions-- can't find the manual . Refrig is...
is water getting to the unit in freezer??? if not you probably have a bad water valve located where water from pipes is connected... if so then you may need new ice maker
Nov 29, 2008 | Whirlpool GS6NBEXR Side by Side...
Water Dispenser with mind of it's own
one test is too turn off your ice maker and it will stop...you have a bad diode on the water line and are getting line feed from the ice maker...
to fix it you will need a new diode
#5303918287 DIODE KIT
#5304418384 DIODE KIT
the parts store will get you the correct one with a model and serial number of the refrigerator
let me know if it helps
Nov 03, 2008 | Frigidaire Refrigerators
Frigidare side by side Gallery fridge
sounds like you water is spilling out instead of going into ice maker... check the inlet spout for ice or other blockage
Oct 10, 2007 | Frigidaire GLRS237ZA Side by Side...
Water dispenser spontaneously erupts when making ice
I had to fix a problem like this the other day you need a inlet solenoid
Aug 29, 2007 | Frigidaire FRS26KR4A Side by Side...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
1,683 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
