Question about Amana SXD524VW Side by Side Refrigerator
AMANA SIDE BY SIDE
WATER WILL NOT COME OUT OF THE FRONT WATER DISPENSER BUT WATER IS COMING INTO THE FRIDGE AND THE LITTLE PUMP IS WORKING MODEL DOES NOT HAVE A FILTER
    Genius:
  • 1,073 Answers
What is the model?
Posted on Apr 17, 2008
Plum in a Amana fridge freezer
hello. I am assumming that your model has the ice and water dispenser. Not all models do. On the rear of these models with the ice and water feature you will find a small [1/4 inch] line that has to be connected to a cold water supply source. If you go to most any hardware store you can get the little kit necessary to make this connection. The kit consists of a length of 1/4 inch tubing, the connector to attach to the tube at the rear of your appliance, a valve and a tapping kit to tap into your closest cold water source. If the fridge is near the kitchen sink, you may choose to connect under the sink. If not, make sure you purchase a kit with enough 1/4 inch tubing to reach your nearest cold water pipe. J.
Jul 20, 2010 | Amana 22.6 cu. ft. Side-By-Side...
My Aman side by side quit dispensing water. It
Does your fridge have a small tank inside the food compartment? If so, the water may have frozen in the tank and the problem can be solved if you take a blow dryer and warm the tank. That's what happened to mine and with a temp adjustment to keep the food compartment a bit warmer, the water doesn't freeze.
May 30, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Hooking up water line to LG LRSC26920TT - water runs great through line, but once connected to fridge, no water runs through line in fridge - no water comes out when trying to fill a glass. No water...
dissconnect water line coupling behind lower kick plate under door. push water dispenser; and sell if water flows out line. keep a towel handy. it there is water; then, the problem is in the door itself. of course, make sure the water solenioids are working.
Apr 17, 2010 | LG LRSC26925 Side by Side Refrigerator
My side by side Amana water dispenser no longer
you have a kink in your tubing test by checking at pump which is visable by taking back felt cover at bottom where water tube goes in cut a few inches away from pump to see if water flows when you activate swich if so you have a kink in your system to repair the cut they have couplings in the store
Mar 22, 2010 | Amana Refrigerators
My brother moved and the movers removed the side by side doors
The dispenser assembly comes apart from the front. It should give you access to the waterline as it comes up from the bottom.
Eric
Jan 19, 2010 | Amana SXD524VW Side by Side Refrigerator
Water is not dispensed when the dispensor is activated. Only a clicking noise under the fridge can be heard. model srd2555w
When you try the water dispenser you should hear the water inlet valve which is on the back where the water supply comes in. If you do hear it then Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws.
If you don't hear the valve working the dispenser switch is bad.
Aug 16, 2009 | Amana SXD524VW Side by Side Refrigerator
Amana fridge water dispenser real slow
u m,ay have to change the filter tubing as well
Mar 15, 2009 | Amana ARB8057CSL Bottom Freezer...
Amana Side by side refridgerator Model SBD20TPE P1190006WE
hi
one question : are the units under warranty ?
if not its pretty easy to swap the dispenser paddles and the membranes
infact i have been using this site for many years and have found it helpful: : www.howstuffworks.com
thanks
May 04, 2008 | Amana ACD2232HR Side by Side Refrigerator
Amana fridge water filter squealing
I would suggest that you put the new water filter back in and try dispensing water for about ten minutes. If there is still a high pitched noise then you could try bleeding the water line at different points along the water circuit (with control over the incoming supply). The fact that you are forcing water through the tank should normally resolve any air locks. The water filter could also be bled of air. Hope this is of some help.
Sep 05, 2007 | Amana ASD2326HE Side by Side Refrigerator
Amana SXD524VW Side by Side Refrigerator Logo
185 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
