Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Freezer up top cools but not at the bottom .
The The The frigidaire is working but have problem with coolness at the bottom inside is working but have problem with coolness at the bottom inside is working but have problem with coolness inside the bottom door.The top makes ice and keep my meat frozen . But inside bottom door the air is warm. When we take it out of socket and start it back up it works well. then 3 days later the bottom gets back warm. And the top works well.I notice in the top the vent that cools the bottom get clog with ice.This is the one that supose to keep the bottom cool. Could someone tell me what's going on?We keep the bottom temperture on cool setting. Thank you Mrs roberson. fanniebellj@yahoo.com
  • Anonymous Apr 24, 2009
    it's cool in the freezer but not in frig
I think you must call a technician to check the air damper control and have an adjustment for the air passage to avoid clogging of ice to the air vent located at inside the freezer section cover.And to check if theres air leakage on the gasket of the fridge.
Posted on Apr 23, 2008
Have frigidaire my freezer is working but bottom of refridge is not getting cold
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 21, 2010 | Frigidaire 18.3 cu. ft. Top Freezer...
Freezer is working but the bottom refrigerator is not cooling?
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Oct 02, 2010 | Frigidaire FRT21P5A Top Freezer...
I have a Frigidaire refrigerator top/bottom, not side by side, and the freezer is working but refrigerator not cooling. Help!
heatman101
ioyt356
May 22, 2010 | KitchenAid KSRG25FKSS Side by Side...
Frigidaire 16.5cu top mount not cooling fridge. freezer is froze
The baffle that opens to allow cooling into the refrigerator may be blocked, broken or mis wired. These units work by just cooling the freezer and then blowing some cold air into the refrigerator whenever the fridge thermostat calls for it. The fridge's thermostat is trying to cool the refrigerator but something is preventing the cool air from getting to the refrigeration part, that's why it's freezing up the freezer
Mar 13, 2010 | Frigidaire FRT17B3A Top Freezer...
Frigidaire frs26zrf
IS THE EVAPORATOR FAN INSIDE FREZZER WORKING AT ALL IF IS NOT WORKING THEN THERE IS NO AIR FLOW TO THE BOTTOM PART
Nov 09, 2008 | Refrigerators
Freezer not cooling
remove back panel inside freezer and see if pipework is frozen up and also check fan is working. if pipework frozen up, indicates a fault with the defrost system
Sep 14, 2008 | Frigidaire 16.7 cu. ft. / 473 liter...
Bottom is too warm
Make sure your fan is working ,its in the freezer behind panel .If not the fan your passage area is probably covered with ice and the air cant get in freezer
Jun 14, 2008 | Frigidaire FRT15G5CS Top Freezer...
Frigidaire stand alone Refrigerator won't cool Fans and Compressor work
when you removed the back panel inside refrig was there any sign of cooling, perhaps only top 1 pass of the coil was frosted, or completly warm no signd of frost at all?
Feb 17, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Frigidaire Side-By-Side Top Not Cooling
the unit is loosing the freon supply to the evaporator.you either have a leakage,a blockage or the compressor is not pumping to full capacity.
Nov 05, 2007 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
115 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
