E-4 will not clear
Code E-4 on display after making a copy. code will not reset or clear, until turned off for several minutes.
Take it and buy a new one u cheap ****
Posted on Apr 16, 2008
Error code sc545
The Error Code SC542 or Sc546 could be a caused by a few reasons. There is a temperature problem with the fuser unit, the roller thermistor is bad, or the BCU Board is bad.
1 metode to reset Ricoh Error code sc542:
To clear the code:
Hit the yellow "Clear Modes" key
Press 107 on the number pad
Press and hold the "Clear Stop" for 10 seconds until you get a new screen ...
Press the "Copy SP" Button on the display
Open the front door
Turn front left power switch off and on
Shut the door
The error code is now cleared.
To Enter and Exit the SP Mode
1. Press yellow "Clear Modes" key .
2. On the operation panel keypad, press 107 number
3. Hold down red "Clear" key more than 10 seconds.
The Copy SP is displayed.
4. Press "Copy SP" and go to the code SP5810, press "Execute"
5. To exit the SP mode, just press Exit in the upper right corner of the SP mode
screen. Power switch off and on and the error code is now cleared.
Hope this his helps, thanks for using fixya.
Aug 28, 2014 | Office Equipment & Supplies
My Xerox XC 1040 lights are on but it will not copy. There is a H and a 4 that comes up on the small screen. We have had several lightning storms in this area lately. We have turned it off and also...
The lightning can cause this code. The good news is that also means it is most likely a false code. Reset this code by pressing the Clear key then the Far Left key on the control panel also known as the exposure mode key. Then press clear again followed by far left again. So in short form press C, Far Left, C, Far Left. If done fast enough and properly your display should go blank. Now key in 14 as if you were going to make 14 copies and press the print button. This should reset your H4 and the machine should be restored to operational. If the code comes back within a minute or so then you have a failure in the fuser unit (part that gets hot)
Good Luck and Thank You for using Fixya
Jun 15, 2010 | Office Equipment & Supplies
I have a H3 error code on a xerox workcentre Pro 215. What do I do to clear it?
This should correct it.
NOTE: Some Status codes will not clear even though the problem has been fixed. Status codes that will not clear must be manually reset using the 'Fault Reset 14 Procedure'.
  1. Locate the [C] (Clear) button on the Control Panel, at the far right.
  2. Locate the Image Quality button, below the Auto on the Control Panel, toward the left side.
  3. Press the buttons in the following sequence within 4 seconds. Press [C] (Clear), press [Image Quality], press [C] (Clear) again, press [Image Quality] again.
  4. The error code should disappear. If the Status code does not clear, repeat step 3 until the status code clears; but no more than five times.
  5. Use the [10] and [1] buttons to enter 14 on the Display Screen, as if you were to make 14 copies.
  6. Press the [Start] button. The machine should be ready to use.
  7. Make a copy, to check that the machine is working properly.
Dec 15, 2009 | Xerox WorkCentre M20i All-In-One Laser...
H-4 error code is displayed.
What you want to do, it turn the maachine off and on, then press Cleat, Auto, Clear, Auto. That is the pinkish clear button and the auto exposure button. Press in order Clear, Auto, Clear, Auto, the display will go blank. Enter the number 14, enter that as if you were going to make 14 copies, press start, That will reset the machine and it should run fine.
Feb 03, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Error code
May 18, 2008 | Xerox WorkCentre PE16 All-In-One Laser...
Error mesage
IF these steps do not work you will have to replace the fuser or fuser heat rod then perform the reset.
May 15, 2008 | Xerox WorkCentre Pro 16fx Laser Printer
Trouble code
May 06, 2008 | Sharp AR-160 Copier
Printer
Give this a try, 9 times out of 10 it fixes the H4 problem.
> Support & Drivers > WorkCentre XD100 Digital Copier - Laser Printer Support > How To Clear an H4 Code Solution: Perform a Fault Reset 14 bttn_print.gifMake Printable bttn_email.gifEmail this page elem_1_spacer.gif Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Mar 10, 2008 | Sharp AR-M160 Laser Printer
Xerox Workcentre Pro 215
This should resolve that fault code
Jan 24, 2008 | Xerox WorkCentre PRO-215 All-In-One Laser...
SHARP AR-M277
this should resolve it.
Jan 22, 2008 | Sharp AL-1655CS Laser Printer
24 people viewed this question
jasbo
jasbo
