Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
After software install of the new HD my computer will not boot if the HD USb cable is left attached. If I unplug the USB cable then the computer will boot up.
  • Anonymous Apr 28, 2008
    My PC will boot up but very slow to boot up
  • rpistone Mar 13, 2009
    I just got a new Dell Inspiron 1525 running Vista 64 bit OS. Everything worked fine until I plugged my iPod into the USB port to charge; it charged fine, but if I left it plugged in and shut down the computer, it would not reboot again, unless I unplugged the iPod from the USB drive, shut down and rebooted - then it was fine again. Can you help me to solve and resolve this problem? Thanks very much.
  • 106 Answers
Please check the boot priority in cmos setting...if its 1 priority given from usb drive than it will not boot till u unplug it.
Posted on Apr 15, 2008
I have a hp printer/scanner 3510 and hp computer, the printer works fine but it won't scan!! the lcd screen says, "the computer is not responding. check if the usb cable is attached" the cable is...
Unplug the USB cable to the printer. Uninstall the HP printer software. Reboot. Reinstall the HP printer software and WAIT until the installation program tells you to plug in the USB cable.
Mar 09, 2014 | HP Photosmart C4280 Aio Printer
I am just installing a new Canon MX7600. It says to not connect the USB cord but I did connect it and forgot to disconnect it before proceeding. When I started the machine I got an error message (5010). I...
Hello there.
It sounds like the printer has partially installed the drivers but because you left the device plugged in, instead of unplugged, it has failed to setup the printer on the computer.
I recommend uninstalling the printer from 'Control Panel' on the Start Menu in Windows. You can uninstall the software from the Add/Remove area of the control panel.
When this has uninstalled completely, unplug the printer USB cable. Shutdown the computer and wait a few moments.
Then , with the USB cable still unplugged, power up the computer and re-insert the printer setup disc.
This will prompt you to install the printer again, then plug in the USB cable when prompted.
Hope this helps.
May 23, 2008 | Canon Office Equipment & Supplies
? while replacing hard drive
1)First of all make a backup of your data on a USB Drive or an External Hard-Drive.
2)Turn off the computer and unplug all the power supply wires.
3)If your HD is SATA, then unplug the cable attached to it.
4)If it is PATA(IDE), firstunplug the IDE cable attached to the motherboard and the HD and then remove the power cable between the HD and the SMPS.
Dec 28, 2010 | Computers & Internet
My laptop won't boot from cd
to reset the BIOS, there is a small battery somewhere in your computer. if you unplug it for 3 seconds, it will reset the BIOS. I RECOMMEND THAT YOU DO NOT TRY THIS! get a service professional. If this doesn't work you might need to get a new laptop.
Dec 29, 2009 | Toshiba Satellite A105-S2712 Laptop
Diagram on how to plug an mx320 canon up to a computer
This is Canon Support, and the Getting Started guide which tells you, and shows you, how to properly cable up your Canon Pixma MX320,
(Copy and paste the above into your address bar, then press the Enter key)
Should this link not work for you, here is Canon Support, and the download page the link came from,
Scroll down to the - Guides and Manuals heading. Below this heading at the bottom of the box, there is - Getting Started
MX320_GS_EN_US_V1.pdf ,in red. Click on this.
You may not see anything happening for up to 20 seconds. I downloaded it just now for a test, (To make sure it's working), and I had to click MX320_EN_US down in my system tray, at the bottom of the monitor.
Pages 3, 4, and 16 tell, and show how to hook up the cabling.
Essentially you are attaching the phone line to be able to use Fax, attaching the power cord for power to the MX320, and attaching the
USB cable from the MX320 to the computer.
You MUST set the MX320 up first, and MUST install the software first, BEFORE attaching the USB cable.
(The USB cable plug end, that goes into the computer is Flat.
It is a USB A male plug.
The USB cable end that goes into the MX320 is Not flat.
It is a USB B male plug. Square shape with the top two corners cut off.
This USB B plug goes into the back of the MX320. In the middle of the back there is an inset, or indention. The plug goes in sideways.
Should you have attached the MX320 to the computer with the USB cable, BEFORE you installed the software from the Installation CD, let me know.
[1.Make SURE the MX320 does not have the USB cable plugged into it!
Turn the MX320 off, and unplug from power.
2.Go to Start>Control Panel>Add/Remove Programs, and Remove theCanon software. All of it. Anything you see listed with Canon relatingto the MX320.
3.If it asks you to restart your computer, do so. If it does not, do so anyway.
4.After Windows has fully loaded, insert the Canon MX320 Installation CD disk. Install the software. If it asks you to restart your computer do so, if not restart it anyway.
5.After Windows has fully loaded, plug the MX320 into power. Press the Power On button. Give the MX320 time to set itself up.
Now plug the USB cable into the MX320.
You should soon see, 'Found New Hardware', and also perhaps, 'Found MX320' ]
Nov 18, 2009 | Televison & Video
Usb hub unsafely unplugged from notebook. now
do one thing boot ur vista without usb hub then go to device manager remove your usb drivers of the hub disconnect the hub from computer, restart notebook, then connect the hub back when windows boot let vista to install the driver of that hub, after that connect your devices one by one ok let me know what happen? :-)
Aug 21, 2009 | Belkin (F5U237) 7-Port USB Hub
Scanner not working need software install
hi friend,
u can download software in
Installing a scanner on newer PCs is pretty straight-forward. If the scanner is a USB device, you'll need to install the software CD that came with the scanner. These will normally be one or two disks and a few others that usually only prove to be trial software or other programs you do not need. Be wary of installing these third-party CDs, as you likely will never use them and they tend to want to take over the way media is handled on your computer.
First, unpack the scanner from the box. Make sure you have all of the attachments and especially the quick setup instructions if they were in the box. You can assemble the scanner and set if off to the side. You can plug the power cable in, but do not plug the USB cable into the computer.
Boot up the computer and load the scanner software disk into the CD ROM drive. If it does not launch automatically, you can navigate to it through My Computer and click the setup.exe file. If there are additional disks for your scanner that need to be loaded, you will be prompted for them.
Once the software has been installed, you can then attach the USB cable to the computer. Windows should find the new scanner and load the drivers for it automatically.
Troubleshooting Scanner Problems:
If your scanner had worked in the past but has stopped functioning, you can usually unplug the scanner, then go to Add / Remove Programs in the Control Panel and remove the scanning software. Then you can repeat the installation process above.
thank u for using fixya
Aug 11, 2009 | HP Photosmart 2610xi All-In-One InkJet...
Is it possible to install 2nd 0/s on separate hard drive 40gb,id not sata attached via usb with laptop of dell inspiron 1525 c2d give steps to install
It depends what kind of SO do you want to install
I recommend you to user an USB Linux distro.
Anyway, normally when installing any SO lets you select the partition where you want to install the SO.
Select the partition belonging to the USB External HD, and do everything else normally.
You must have in mind that you will lose everything in the USB HD, and that using it this way the OS will work only when the HD is plugged to the same PC, it may work with a different PC with different hardware but the SO will install the new drivers for the new hardware.
That's why I recommend you to use linux, check this out
Mar 19, 2009 | Microsoft Windows 98 for PC
Yes U can enable Boot from USB device ...& first boot device must be USB Hard Disk...
Nov 29, 2008 | HP Pavilion dv4000 Notebook
I have installed the software for a lexmark x73 all in one printer, and it won't print a direct copy or align new ink cartridges. the comuter i installed it on is running windows xp.
Sometimes more than one copy of the printer can get installed, so try this:
  1. From Control Panel > Printers remove ALL copies of the Printer.
  2. Unplug the USB cable to the printer and re-boot the computer.
  3. Reinstall the software and then plug the USB cable back in and XP will find the printer.
That should FixYa...
Apr 21, 2008 | Office Equipment & Supplies
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
209 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
