Question about Compaq Presario 700 470024-192 Notebook
My laptop does not work
Dear sir,the problem started when i wanted to turn on my laptop ;i tried that for many times but nothing new just ,i mean what i see on the screen , only the name Compact then the laptop does not continue to open the windows.
my laptop is Compac Presario 700 with an Athlon processor.Many specialists told it is the BIOS and i have to flash it -firmware .
Please Help ...!
notice the picture
  • 655 Answers
Dm its a POST screen.
you may find the error which cause problem in tha back of this screen.
  • Just press Esc or Tab to see the POST screen.
  • Note down the messages which appears on the screen.
  • Then tell us whats goin on.
OR
You can try to boot in safe mode.
  • Just start pressing F8 after power on. It will open the Windows boot mode select menu.
  • Select Same mode
  • see whats going on
Gud luck
Iqbal
Posted on Apr 15, 2008
  • Compaq Master
  • 13,433 Answers
Since you cant get anywhere from the compaq logo.. well try to press TAB button in the startup, try a few times (start it again if you dont get anything)
You should get the diagnostic screen.
If the bios needs to be flashed .. then the chip needs to be removed from the motherboard, difficult operation contact a local pc shop for help if you are not experienced in takeing laptops apart and useing a soldering iron the remove the bios chip from the motherboard and then flashing it in another pc motherboard.. well difficult it is.
I wont go into more detail.
My 2011 Malibu will not start
Does it turn over, like it's trying to start, and then just never does? Or does nothing happen at all when you turn the key. If it's trying to turn over but won't start, it could be a fuel pump or fuel line issue. If there's nothing but a click or silence when you turn the key, it sounds like an electrical issue with your starter.
Oct 24, 2017 | Cars & Trucks
Sir, my laptop screen is not working, when i will start the laptop the screen is display nothing means just black, as my laptop is off. what i will do ?
On the Back of All Laptops, you have a monitor hook up port, try hooking a monitor to the port, Boot it and see what happens from there.
Aug 06, 2013 | Lenovo ThinkPad R61 Notebook
Hello good day,sir My compaq presario cq40..is powering on but blank on the screen and caps lock and num lock blingking only.I try ready so many time but everything are not meaning for me that's why i need...
Hi
You could try this
switch on power and press either the f5 or f8 key
if this works try to go down to use the last good known configuration
itf that dont fix it
try again to power up and press either the f5 or f8 key
and try to repair
if not try to start up in safe mode and do a system restore back to when it was ok
Mar 06, 2011 | Compaq Computers & Internet
Hi sir/madam, My laptop's screen doesn't turn on. I thought the screen is gone n need a new one but after trying to turn it on like ten times it turned on everything was perfect but when I tried to restart...
Hi if you are getting nothing at all from the lcd screen (black screen with no cursor or icons) there are two possible causes 1st is the LCD itself it starting to worn out or sometime it is just the simple wire connecting the LCD to the mainboard to get the display that needs to be replaced.
If your getting a black screen with blinking cursor and you can still see the hp logo at startup you just need to update the video card driver of your laptop.
Have the HP check first the hardware side of your system so that they can replace the broken parts. thanks
Jan 14, 2011 | HP Pavilion dv9000z Notebook
Hp dv6408nr laptop beeps four times when I turn it on then nothing happens.
4 beeps usually means a system time failure which means the main timer on your motherboard isn't working. it's not something that can usually be repaired and you probably need a new motherboard
Jan 11, 2011 | HP Hewlett Packard Pavilion dv6408nr...
Sir i want to load new window in my laptop but im not able to find booting hardware means hardwares though which i can load window at boot time
you need too go into the BIOS and set the boot order so the DVD is picked before the hard drive.
press F2 when starting the laptop to enter the setup - from there you can change the book order.
Please let me know if this helps?
Dec 18, 2010 | Computers & Internet
When i turn on the LT, the hard drive starts clicking, but no video, cd drive works, but nothing shows on screen, I switched to an out side monitor, same thing, nothing happens. Am wondering if HD is bad...
the hard drive is definitely bad so take it out of the laptop, clicking noise means the platters inside of it are misaligned.
After taking out the hard drive then turn on the laptop and see if you get video. If you do then you know the hard drive was shorting out the motherboard. If you still don't get video then unseat and reseat the memory sticks one stick at a time in each slot one at a time and try turning it on after each memory reseat.
If the laptop still doesn't turn on then take out the dvd drive as well.
If you still have no video then that means not only is the hard drive bad but also the motherboard.
Jan 23, 2010 | Dell Latitude C610 Notebook
Acer AL1916 can't start
If you press the power button and nothing comes on at all then something isn't providing power to the laptop as it should and you may likely need to replace the battery or the power cord.
Find a replacement battery. Change your battery with a new one then plug it up and turn on to see if this works.
If replacing the battery doesn't work then replace the power cord and trying turning it on again. If this doesn't work either, you have a more serious issue going on.
Not too long ago, I was on vacation, my laptop had been working fine until suddenly it wouldn't come on at all. I went into the office to grab a new battery and power cord. (I work on computers so I had spare parts in my office/Tech Room.)
I got home and replaced the battery then tried to turn it on using the old power cord...didn't work. This was a brand new battery so now I knew that I could rule out the battery as the issue...the only two things left to troubleshoot were the power cord and the laptop itself.
I put my old battery back in the laptop then tried to turn it on using a different power cord and it worked. I didn't need to replace my battery or laptop. The power cord had failed.
I hope that your issue is as simple as this solution. Try confirming whether your battery and power cord are still working...you may just need to replace one or the other.
Thanks for using Fixya.
Share your experience by rating this solution.
Mar 29, 2009 | Acer AL1916B 19" LCD Monitor
Vostro 1310 won't turn on
i dont think theres anything wrong with the laptop but who's ever is using it could have done smth wrong
Mar 08, 2009 | Dell Vostro 1500 Notebook
Compaq Presario 700 470024-192 Notebook Logo
80 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
