Question about HP OfficeJet 6110 All-In-One InkJet Printer
6310 all-in one
Keeps losing connection I have replaced all cords going to it. I have replaced the printed its self 3 times in the last month the same problem keeps coming back afer a few days of operation.
    Problem Solver:
  • 10 Answers
If by "losing connection" you mean it keeps saying it found new hardware or wants to reinstall itself, this has been a common issue with Windows Vista and newer products.
First step is to check hp.com for an update. On most units, there is a patch to get rid of this issue. If you have no luck with that, try reinstalling the software package.
Posted on May 01, 2008
  • 4 Answers
Sounds like you have troubleshot all of the physical connections. Have your replaced/updated the driver? Go to HP's support website and see if there's an updated driver for your printer and operating system, i.e., mac, vista, xp, etc. My printer came with two discs and I accidently installed the wrong driver. I had similar problems. Hope this helps.
Posted on Apr 24, 2008
Can I wear a rash guard shirt in the sea?
Yes! They are specifically made for use in the sea. However, like anything you wear in the sun or in saltwater, the rash guard will lose some color and elasticity over time. To keep your rash guard lasting longer, it important to wash it out thoroughly with fresh water after your take it into the salt water. I go swimming in the ocean about 3 times a month and my rash guards always last about a year or so before they become too loose to wear.
Jan 14, 2013 | Water Sport
Every few months the compressor will not come on. It will try over and over but will not start. At the same time, the light does not come on when the door is opened. I can unplug the power cord and plug it...
Hi!!
The lighting circuit and the compressor electrical circuit are independent from each other once they go past the electrical terminal block, (where the power cord connects to, on the back of the fridge).
For the description of the problem, it sounds like you have a loose power cord terminal connection at the block, a defective power cord or power outlet.
Try connecting the fridge on the other power outlet (if it is connected to a regular dual outlet ), some times the contactors, over time, tend to loose the grip on the power cord plug and the contact is lost, when you remove the plug from the outlet and plug it back in, restores temporarily the contact again, or, the plug itself can be defective and loses contact. Replacing the power cord and using a different power outlet (even if it is a dual) will let you know if that where the problem was. If that doesn't solve the problem, let me know and will do some more troubleshooting.
Good Luck and keep me posted.
Jan 10, 2011 | Refrigerators
My Officejet 4315 All-in-One is printing very very slow How do I fix this problem? I have restarted it and unplugged then replugged it and have restarted the computer and it still prints really really...
The very first thing you need to do determine whether the issue is in the Hardware or in the Software for that on the printer .
1. Load plain paper in the tray.
2. Press the Setup button
3. Press 2 to select Print Report
4. Press 4 to select Self-Test Report . The self-test page prints.
Measure the time (in seconds) it takes for the test page to prints.If the test page prints in less than 60 seconds , this is normal print speed and you do not need to troubleshoot.If the test page prints in more than 60 seconds , go to the next step.
Important ;
Some products print faster than others. If the test page exceeds 60 seconds, and other documents you print typically take as long, the print speed is normal. Troubleshoot this issue only if your product is designed to print faster than about 60 seconds a page or if printing is slower than usual.
***** IF THE PRINT SPEED IS MORE THAN 60 SEC.
Check the power supply. to check the power supply you need to follow these steps.
1. Turn the product so that you can access the rear side.
2. Unplug the power cord from the back of the product.
3. Remove any devices between the product and the power outlet, such as surge suppressors or power strips.
4. Plug the power cord directly into a wall outlet.
5. Print and time a self-test again.
If the test page prints in 30 seconds or less , the problem relates to the power supply. Replace devices between the product and the power outlet, or leave the product connected directly to the wall outlet. If the test page takes significantly longer than 30 seconds to print, continue to the next solution.
CHECK THE CARTRIDGE COMPATIBILTY.
Incompatible cartridges can cause the slow printing problem.
Which cartridges you use depends on your country or region. To check the cartridge compatibility you can go to this site (for hp printers) http://www.hp.com/buy/suresupply and check The number on the cartridge label must match the numbers listed on HP SureSupply.
PERFORM A RESET.
1. Press the Power button and turn off the printer.
2. unplug the power cord. Disconnect the data cable(USB,Ethernet depending upon the the product set up). wait for 30 secs. reconnect all the cable and than try to print a test page.
if these steps resolves the issue than you dont need to continue troubleshooting or if the issue persist than Replace the Power supply for your product.
Jul 06, 2010 | HP Officejet 4315 All-in-One Printer
The last line of every document is cut off and the bottom half is missing as though the margin isn't long enough, but that's not the case.
Try to print a self test page using the below steps
  1. Load U.S. Letter, A4, or legal size paper into the input tray.
  2. Press the Setup button.
  3. Press 1 to select Print Report , and then press 1 to select Self-Test Report .
  4. Press OK . The self-test page prints.If this prints fine, perform the partial reset of the printer using the below steps:
    1. Unplug the power cord from the HP All-in-One.
    2. Wait for 20 seconds.
    3. Press and hold # and 3 while plugging in the power cord to the HP All-in-One.
    4. Release the buttons after the HP All-in-One starts up.
    5. The HP All-in-One will now be reset to factory defaults.
Sep 27, 2009 | HP Officejet Pro L7680 All-In-One Printer
About a month ago my screen on my laptop would
Sounds like one of two things. Either your connection wire from the screen to the hard drive is lose most of the time you can go on the product sites enter the info on the underside of the computer enter that info on the products site and get your info from the help self section or the repair diagram. Number 2 is your screen has a bad wire and it needs to be replace you can find them new on ebay and most of the time it is easy to fix yourself. I hope some of this info helps you.
Jul 14, 2009 | Gateway C-141x Tablet PC
Trying to get my Lexmark Z45 to print but it won't at all. I have checked all connnections and replaced the USB cord and gone through all troubleshooting help issues. Nothing will get it to print unless I...
This happens to me about every 3 months.
What you need to do is remove the program drivers.
Go to control panel and select add/remove software and uninstall the all in one program.
Reboot.
Now go the Lexmark site and download the all in one drivers and reload.
It will take you through the install program and once completed you should be able to print.
Apr 01, 2009 | Lexmark X4270 All-In-One InkJet Printer
Losing brake fluid, pedel goes to floor
do you keep adding fluid all the time? if so then we have to find out where the fluid is going. please respone to me question and i will help you thrugh this thanks
Jan 31, 2009 | 2000 Chevrolet Impala
HP LaserJet 2430n occasionally prints goblety-gook
ISSUE: When printing from the computer, you receive a line of garbage or all of the printed output comes out on one line. SOLUTION: See the following:
  1. Perform a self-test to be sure that the HP LaserJet printer is functioning properly. If the self-test is not correct, remove all cables and accessories (if any) and print a self-test again. If the self-test is still not correct, service the printer. If the self-test is correct, go to the next step.
  2. Reseat or replace the cable. Check the cable for bends or pressure applied by objects resting on the cable. A faulty cable or cables that do not meet the IEEE-1284 Standard can cause print defects by distorting signals.
Jan 09, 2008 | HP LaserJet 2430n Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
57 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
