Question about Panasonic PT-AE900U Multimedia Projector
Out of focus center of picture
I have had the projector for 2 years now and no problem. Since I replaced the lamp, I have an out of focus center of my picture. Green color halo / shadow effect.
The rest of the outside picture is very good.
  • 563 Answers
Hi there
This could either be a bit of dust on the inside of the lens or the LCD's
Posted on Apr 17, 2008
Out of focus
the glasses in the Lens are failing.the glasses were burned
you need the new Lens, USD80
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
Mar 23, 2014 | BenQ MX615 DLP Projector 3D Ready...
White spots on screen i have changed the lamp
It's probably you have a busted DMD chip, have your technician replace that, better yet buy a new projector because replacing that chip costs almost a brand new unit.
Nov 19, 2011 | BenQ Office Equipment & Supplies
I have a Promethean Interactive Board in my classroom that is paired with an Epson 83C projector. The picture that is blurry. How can I focus the picture on the Promethean Board? Thanks!
the light is blerry ,
Pls check the lamp,(if it is bright enough )
check the color if it is correct and brite-colored (if the LCD panels is work well)
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color
wheel,
motherboard, powersupply ... with high quality and competitive price.
Lampdeng Limited
Jerry
Oct 01, 2010 | Epson 5300 7200 7300 Replacement Lamp -...
The projector is approximately 4 years old & on average runs for about 60 hours per week, 40 weeks of the year. After fitting a new lamp last October & resetting the projector, the image is still...
Additional information is required for us to assist. Can you better describe what you mean by "poor image"? Are the colors separated? Is the picture out of focus? Are the colors wrong?
Please describe the picture or post a picture of the screen if you can.
Thanks,
Dan
Feb 03, 2010 | Sanyo PLC-XP57 LCD Projector
My In Focus
if the lamp is relatively new, the colorwheel might be coated with dust. the heat bakes it on. you can try to clean it, but you might end up having to replace it. try av solutions in ny. they're pretty good.
Nov 02, 2009 | InFocus ScreenPlay 5700 Multimedia...
I just replaced the lamp in my Sony projector with the recommended LMP-H130. Two problems. 1. I, my wife and my son all agree that the picture is not as bright as it was prior to replacement and 2. I...
this is our chat session, please rate it inappropriate it will spoil my rating.
vsurg: thanks
cmptrlink: welcome
vsurg: I purchased the bulb through electrified.com. OEM replacement for $249. Is there a difference between bulbs?
Read more cmptrlink: yeah the lamp should be purchased after proper specifing the device model, or the recommended lamp specified by the vendor
vsurg: It is the right lamp. Of that I am sure. The projector is a Sony VPL-HS51.
cmptrlink: hang on i will tell you the correct lamp number
vsurg: Manual says LMP-H130.
cmptrlink: is that the same one you got?
vsurg: Yes
cmptrlink: why dont you consult to a authorized sony service center.
cmptrlink: the lamp no. LMP-H130. is correct. but there must be some problem with the lamp or projector! is the lamp was packed when you got it?
cmptrlink: the projector normaly comes with 3 year warrenty
cmptrlink: To reset the lamp timer: 1) With the projector plugged in and turned off, press the 'ON/STANDBY' button to put the projector in 'STANDBY' mode. NOTE: You have to press the button on the projector itself, you cannot use the remote for this step (this
cmptrlink: is not clear in manual). 2) Now, using the remote, press the following keys in order: RESET, <--, -->, ENTER. 3) Timer should now read '0'.
cmptrlink: hello
vsurg: I got disconnected
vsurg: how do i get back on?
cmptrlink: hello sir
cmptrlink: are you there?
vsurg: Iam back
vsurg: How do I get back to the live session?
vsurg: I think I figured it out. I am back
vsurg: Please respond. I can't keep this up much longer
vsurg: How do I get back to a live session please?
Jan 16, 2009 | Sony VPL-HS51A / VPL-HS60 Multimedia...
51 magnavox projection tv-color mixing wrong
The are controls on the inside of the tv above the circuit boards for focus and to turn up intensity of the projector lamps (red, green, and blu). If you turn it up too far all three projector lamps kick off. If this happens, power off the set and turn down the lamp that you turned up. Power it back on and slowly turn the projector lamp up until the picture looks OK. You have to take off the panel on back of set to get to the controls.
Nov 19, 2007 | Philips Magnavox 51MP392H Rear Projection...
Dark Picture
If the Lamp condition is okay then check the FE lens just next to the lamp in the projector after removing the lamp out of prj. replace if that is burnt.otherwise replace Lamp.
Viren
Nov 13, 2006 | NEC VT460 Multimedia Projector
Distorted Color and geometry of Picture
I've posted this solution several times but here goes. Try setting up the convergence through the menu by accessing the convergence setup menu. If this fails to work you have a bad digital convergence box and need a tech to replace it. About $60 to $100 fix.
Nov 03, 2005 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-AE900U Multimedia Projector Logo
168 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
