Help! how do i plug up the speakers to the subwoofer? The subwoofer is working but the smaller speakers are not and I know its because i don't have them plugged in correctly.
1 ounce of gasoline and a match should fix the problem.....if not at least you'll be left with the piece of mind the you have won the battle .....lol
Posted on Apr 19, 2008
My Edifier M1360 speakers will only work when plugged into the headphone jack and I can't get all three speakers working at the same time. What can I do?
the sub woofer green 1/8 inch plug goes into the audio card either the front or the back of the pc. the jack it plug into is normally the green one. the two speakers normally join together on one card and plug into the subwoofer. also look for a on/off know to the speakers for power. normally on one of the little speakers. make sure it is on.
Nov 09, 2014 | Edifier M1360 2.1 Multimedia Speaker...
My Mackie SRM-450's both make excessive white noise, one of them crackles quite loudly.
This type of active speaker by Mackie has a issue with operational amplifier ic's inside, they are just those little black things with 8-pin soldered to the pcb, you may have some of them damaged, because of the erratic operation of the units, let me know if i can help more.
Jul 04, 2013 | Mackie SRM-450 System
Don't know how to recharge
Just use the combined USB/audio cable. Plug the standard USB side in your computer, or even in the back of some modern TVs, and then plug the other side with the smaller USB plug into the speaker.
Sep 29, 2012 | xMini X-Mini II Portable Capsule Speaker -...
My left speaker is not working and it isn't the cable connection. It has been checked and the plug is in all-the-way.
You could just have a loose wire inside the speaker but sometimes one speaker will just go to speaker heaven. Sorry I can't give a better answer and I don't know that brand so I don't know if you can open up the speaker easily to see if there is a loose connection. Now, sometimes the plugs can just wear out too which can be replaced if it is a great set of speakers but again, back to the lack of knowledge about that brand and how hard it is to work on.
May 22, 2012 | JBL Audio Players & Recorders
Durabrand Home Theater System Model HT-3917. It was playing ok a little crackle from the front side speakers for a couple days now and it just went off. I checked the fuse no,I checked the power strip and...
You (we) still don't know if the speaker or electronics are at fault. Swap the speakers left-to-right. Use test tones to test all channels. Could be a loose speaker wire, too.
Jul 24, 2011 | Durabrand HT-3915 System
Help! 63-yr.-old lady trying to install subwoofer and two smaller speakers...please???
3.5mm connector plug into phone jack back on the pc ,(usually green color ), and the two smaller speakers plug into the back of the subwoofer with the right color.
Oct 29, 2010 | Computers & Internet
I just got a used set of altec lansing ADA745 computer speakers and can't get power to them. I have never seen computer speakers w/ two wires for input to the computer. I plugged the usual green colored...
https://support.dell.com/support/edocs/acc/ada745/ada745.pdf
That is the setup guide for the speakers.
The two wires plug into a cable that then that single cable plugs into the computer, this way you have sound coming out of the left and right hand speakers.
Feb 05, 2010 | Altec Lansing Multimedia Computer Speakers
I just bought the logitech LS21 speaker system for my dell and there is a subwoofer and then a left and right speaker to hook up. Where do i plug the subwoofer in at on the back of the compuer and where do...
The set up should be as this.cable plugs into headphone jack on your pc. that connectects to your powerd subwoofer it is power correct! then your small speakers connect to the sub box or thew should? look on the sub box usually front and on the bottom.if thee actual speaker connections then they will be on the rear.
Jun 11, 2009 | Dell Dimension 4700 PC Desktop
Speakers
check all the wires and attach your music system to any other system to see if its is working..if not there might be a hardware issue with your music system .show it to any tehnical shop who repairs computer devices like woofers to find problem.
Please let me know your feed-back.
Thanks
dilipbagdi
Technical Associate
Apr 10, 2008 | HP ProMedia Computer Speakers
130 people viewed this question
 Grubhead
Grubhead
