Question about Belkin Wireless Pre-N (F5D8230-4) Router (F5D82304)
Need to frequently reset router
Our Belkin Pre-N router seems to work fine, then will give us a DNS error. If we unplug the power to the unit and plug it back in, it will work for awhile again. Is this a network (GCI DSL) problem, or a router issue?
  • gregorcarp May 03, 2008
    I still am having problems after adding a power conditioner/backup. I also tried re-installing the firmware per the tech guy from Belkin. The problem disappears when I bypass the router, so I think the modem is OK. Looks like it's time for a new router.
Get help from Belkin pre-n router website. Change Auto Channel to a set channel . Hope that helps.
Posted on Jul 20, 2008
  • 202 Answers
Hello gregorcarp
It could be a flakey router or DSL modem or signal from the ISP, or, another thing to consider, issues w/ power supplied to your network devices (DSL modem, router, etc).
W/ respect to your ISP, you can check w/ them to see if they have a log of "events" that have occurred involving service to your DSL modem. You can ask them to check the strength of the signal to you modem as well.
W/ respect to "locally", I'd address the possibility of a power issue. After checking w/ your ISP, this would be tne next logical course of action to take w/ an intermittent problem like the one you're experiencing. You want to at least get the possibolity of there being a power issue ruled out.
If the power is dirty (noise on the line), sagging or spiking (out of recommended peak to peak tolerances), it can cause your networking equipment (in fact, ANY electronic equipment) to "behave irratically".
Most people are unaware of this but "bad power" is a slow killer of electronic equipment. It eats away at your equipment - little by little damaging your equipment's sensitive electronic components - resulting in or causing spurious or intermittent problems that can drive the best techs crazy trying to pin down.
If you don't have good power protection in place already, I recommend the following:
Place ALL of your network devices (ALL of your computer-related equipment as soon as you can manage) on one or more quality UPS'.
A quality UPS works far better than a surge suppressor for protecting you sensitive electronic equipment - even a high quality surge suppressor. That is because, not only will a good UPS dampen spikes as quickly as a good surge suppressor but it will also pull up sags in power. (Surge suppressors cannot do this.)
When your power goes out of tolerance w/ respect to peak to peak voltage or noise on the line, a good UPS will kick in and take over supplying clean power at the correct levels until the building or house power comes back into tolerance.
If your power is r-e-a-l-l-y bad, then you might want to consider using a power conditioner, too.
Please, post back here w/ any questions, comments, what you've tried so far and the results, etc. We'll keep working w/ you to resolve this issue.
Thank you
BJ @:)
Posted on Apr 15, 2008
  • 2 more comments
  • B Joan Rapier
    B Joan Rapier Apr 15, 2008
    Once you assign ratings to the experts' contributions, the problem will be automatically closed and we'll no longer be able to assist you. So, please, wait until your problem has been resolved - *then* rate the solutions and choose a "Best Solution". As long as the problem remains open, we will be able to continue to work w/
    you on it.
  • B Joan Rapier
    Below are some very informative links regarding power and how power anamolies can impact your electronic equipment.
    The Problem with Power on
    What is a Power Event on
    Determine Your Risk on
  • B Joan Rapier
    B Joan Rapier Apr 17, 2008
    Hello gregorcarp,
    Hello patsyzara
    How did it go? W/ the information and recommendations I provided, have you been able to resolve the issue w/ your router having to be reset?
    I DO hope that is the case. :) If it isn't, just post back here and we'll continue to work w/ you on the issue.
    it is the case, would you kindly take just a moment to reward my efforts at
    helping you w/ a FIXYA rating for my "solution"? I would be very grateful for your kindness and the show of appreciation.
    Thank you once again for using FixYa! Have a beautiful day.
    BJ @:)
  • B Joan Rapier
    My apologies for the "Hello patsyzara". I had been in contact w/ her and had neglected to remove the "Hello patsyzara" from my notes. Again, my apologies for any confusion.
    Thank you again
    BJ @:)
Can't set up Belkin 54g Router with MTNL broadband
You should reset your router to clear all information from it. The best procedure to fully clear your device would be to press the reset button with power on for 30 seconds; while continuing to press the reset button, remove power from the unit; and while continuing to press the reset button restore power for 30 seconds.
You should now be able to access the menus after the unit boots up with the default user name/password for the unit. If you do not know them, just Google [your router name] default user name and password. You can now set up the router to meet your requirements. There is a lot of information that will help you on the Internet, but having a clean booted router is important to start with.
Mar 17, 2014 | Gateway Belkin 54g Wireless DSL/Cable...
Had to get a new router now my roku says my network is not shown
The quick fix: make sure your router's DNS settings are properly set to an External IP address. If DNS1 or DNS2 show up as internal IPs such as: 192.168.1.x, then your Roku won't connect to the Internet.
Here is the detailed fix:
  • Login to your router. (typically this is done through an internal ip address like You enter this IP address directly into your web browser same as you would a website. **NOTE some people actually enter web addresses into Google, and then navigate that way. This won't work. Enter the IP address directly into the browser's Location or Navigation bar at the top. This will take you to your router's login screen. *NOTE sometimes the router's default password is "password". But it's possible that your password was changed during installation. If you don't have your router's password, contact your Internet provider.
  • Once logged into your router, navigate to its DNS settings. My guess is that if your Roku isn't working, it's because rather than an external IP address being used for your DNS, the router is set to use an internal IP address. (Your computer is able to overcome this because it has built-in DNS settings, but the Roku looks to the router for this information.)
  • Replace the internal DNS address with a public DNS address. What worked for us was using Google's public DNS. So set DNS1 to and DNS2 to .
  • Save your settings.
  • Run the Roku setup again. If you still aren't able to connect to the Internet, then bounce (unplug) the router. Leave it unplugged for 15 seconds. Then power it back up. Try again with the Roku. If that doesn't work, bounce the Roku. Leave it unplugged for 15 seconds, plug the power back in. The 15-second rule with computers and hardware is surprisingly effective.
  • If you've set the DNS properly, your Roku should now (finally) connect to the Internet. When this happens, it will complete its setup process and you should be good to go.
In case You Still having Belkin Basic Wireless Router Issue Then Visit
How to Fix Roku that Wont Connect to the Internet
Or Follow Us For online Belkin Wireless Support On: Belkin Support
Feb 28, 2014 | Belkin Basic Wireless Router
I have just bought Belkin Powerline AV starter kit. I have a Belkin N1 Wireless Modem Router connected through a Carrier PoE adapter. I have tried to connect my Sony TV and PS3 through the powerline units...
Try reset the device and start a new configuration.It seems that your networwork have issues between the router and the powerlines.All need to be in the same network as per router configuration.Connect one adapter to your router and plug it into an available electrical outlet. Plug the second adpter into an available wall outlet and connect the other end to any device with an available Ethernet port such as a gaming console, set-top box, or computer.
pd: OS to use the adapters; Windows 2000, XP or Vista.
Feb 24, 2011 | Belkin Powerline F5D4050 Network Adapter
Hi. My Belkin wireless pre-n has no power, no lights. Tried different power adapter and reset, but no lights. Mark
If you cant get power to it try another power adapter with same amps if that dont work its most likely shot its most likely a diode if you can solder you can take it apart and with ohm meter figure out the one that is burnt most likely be better off purchasing one,
Jan 19, 2011 | Belkin Wireless Pre-N (F5D8230-4) Router...
To restore the router to factory default settings, please do the following:
1. Unplug the router's power supply
2. Press and hold the reset button on the bottom of the router
3. Keep the reset button depressed and, at the same time, plug the power supply back in
4. Keep the reset button depressed for another 10 seconds
5. Release the reset button
Apr 02, 2010 | Belkin Wireless Pre-N (F5D8230-4) Router...
The ''wireless'' light on my wireless router is flashing amber
Contact Belkin for Care at 1-800-585-2494 Toll Free,,
Jan 09, 2010 | Belkin F5D8236-4 Router
My belkins wireless light wont come on anymore?
* try connecting ur belkin router to different power socket * try with different power adapter * or else press the reset key for more than 1 min while holding the reset unplug the router power cable and plug it back again 3 times.--- while holding the reset u shouldnt release the reset while u unplug and replug. the interval between each unplug and replug should be 15 seconds. * then release the reset then unplug the power cable and plug it back * it has to work or else replace it with the belkin tech support
Nov 15, 2009 | Belkin (F5D72304F5D7000) Router
First, try to reset the router. Hold the reset button at the back of the router for 20 seconds then unplug the power. Make sure the modem is off as well. While the modem and router are off, double check your physical connection. Make sure the modem is plug into the Internet port of the router and your PC to port number 1. Power on the modem first, wait for the lights to go solid then power on the router. Check if the internet works fine.
Hope that helps.
Sep 15, 2008 | Belkin Computers & Internet
Belkin router not working
Are there no leds when you power up the router? If there are no leds make sure the 110 volt circuit the router is plugged into is not tripped. If you have leds try holding in the reset button on the back of the router with a paperclip the botton is a small hole located by the internet/wlan port, hold for 10-15 seconds this resets the router to factory defaults. BPCS
Dec 28, 2007 | Computers & Internet
Belkin Wireless Pre-N (F5D8230-4) Router (F5D82304) Logo
944 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
