Question about Nikon Speedlight SB-600 TTL Flash
Nikon SB600 flash menu locked.
I accidently got into wireless flash mode in Nikon SB600, and can't get
OUT of it.
Tried pressing on AND mode for several seconds, flash window lights, but nothing happens.
It shows lock, chanel 4 and "R".
Does anyone know how to get out of this and back to operational flash?
Then, a question -- can I use a Vivitar 283 on the D40x hotshoe or is
that wrong voltage?
Appreciate advice. Thanks.
ed61115@yahoo.com
Nikon hot shoe is rated up to 250V (canon's is rated up to 6V) so you can use almost any tipe of flash, except maybe for old studio flashes.
Vivitar 283 (older versions) is ~200V rated, and much lower on newer versions. It should work.
Posted on May 09, 2008
  • bchendran May 09, 2008
    try resetting the sb600 by pushing "on/off" and "mode" buttons simultaneously for several seconds
Speedlight SB-600 TTL Flash: When I set my SB600 (mounted on D70) to TTL or TTL...
the sync speed for the sb-600 is onlt 1/200 on most cameras i think so if your shutter is faster then that then all you will see is black/ the curtans behind the shutter.
basicly just try again with a slower shutter speed
May 07, 2010 | Nikon Speedlight SB-600 TTL Flash
Underexposure with Nikon SB-600 flash
1 - Make sure you don't have your diffuser screen pulled down. This is easy to overlook and will produce that effect.
2 - Reset your flash - hold down the "Mode" and "On/off" button together for a few seconds. This gets you out of any funky mode you could have accidently put yourself in
3 - Put camera in fully auto mode. That clears any weird modes you could have gotten into there
4 - Clean the contacts on the flash and camera. I use a pencil eraser and wipe with alcohol and paper towel. Dirty contacts can cause flash misfire or cause full flash during the preflash mode, which gives you dim or dark photos or sporatic flash operation.
Mar 07, 2010 | Nikon Speedlight SB-600 TTL Flash
Sb600 flash has no communication with d70 camera
Have you tried using the wireless mode? Even if there is a problem with the hot shoe interface, it might still work using the wireless mode. To do this you have to set both the camera and the flash. On the D70, under the menu with the icon that looks like a pencil, select Flash Mode|Commander Mode|TTL|OK. On the flash, hold down the Zoom and [-] buttons to get the CSM menu. When you see the zigzag arrow, push the Mode button to turn on the wireless mode.You may have to use the [+] or [-] buttons to cycle through the menu to find the zigzag arrow.
Now you should be able to use the flash detached from the camera. Just pop up the D70 flash, which will tell the SB-600 what to do via light pulses. There are other settings that may be required (channel and group settings must match between camera and flash) and be careful not to block the light sensor on the side of the SB-600. If the wireless system is still working, you may find you like it better than hot shoe operation.
Dec 01, 2009 | Nikon Speedlight SB-600 TTL Flash
Nikon SB600 / D90 out of sync
Check that the terminals on the flash and the camera foot are clean Use a pencil eraser to clean thyem by using a gentle rubbing motion. reconnect and test.
Please rate my help++++Thanks for using FIXYA
Nov 30, 2009 | Nikon Speedlight SB-600 TTL Flash
I want to know how to use the 952AF/Nik with the nikon d200 using multi flash units with the commander mode set to channel 1
The vivtar 952AF flash is not compatible with the D200 in commander mode. Only the Nikon SB600, SB-800, SB-900 will work with that camera wirelessly.
Oct 11, 2009 | Cameras
Nikon sb600 flash
Auto zoom only works when on the hot shoe of the camera. You also need to make sure that its in the righht mode (make sure that above the word Zoom on the display it doesn't have a "m").
Oh and of course you have to have a CLS (Creative LIghting System) compatible camera.
Sep 07, 2009 | Nikon Speedlight SB-600 TTL Flash
Sb-600 and d80 sync, connecting, off camera..
  1. On the SB 600, activate the custom settings menu by pressing the ZOOM and '-' buttons simultaneously for a few seconds.
  2. In the custom settings menu, set the Wireless Remote Flash option (indicated by a curled arrowhead) to 'ON' (use + and - buttons to toggle between options)
  3. Set the flash mode to Master (do not set it as AA or A)
  4. Press Mode button and select one of the four channels available (ensure that you set the camera also on this channel)
  5. On the D80, from custom settings menu, select Built-in-flash
  6. Set the built-in-flash to '--' if you do not want the flash to show up in the scene
  7. Set the mode of the group to i-TTL (this menu can be used to control multiple flashes in different groups. since you are using only one remote flash, select the group you have set in the SB600)
  8. Set the channel to the same as in step 4
Now you are ready to use the remote off-camera flash.
Jan 24, 2009 | Nikon Speedlight SB-600 TTL Flash
Sb600 wireless mode not working...
Remember that even though sb-600 is wireless, it is based on infrared. This usually means having a clear line-of-sight between flash commander and remote flash. Any object that gets in way can block signal from flash commander. Weak batteries in flash will also cause remote operation to be sporadic.
Mar 13, 2008 | Nikon Speedlight SB-600 TTL Flash
Nikon SB600 flash behaving strangely
I have sent my SB-600 to Nikon twice in the past 6 months to resolve this problem. They have fixed it both times, but never told me what the problem was. I've had it back for exactly 1 day now, and it's started back up again already. If I receive a solution (or replacement), I'll let you know!
Nov 13, 2007 | Nikon Speedlight SB-600 TTL Flash
Nikon Speedlight SB-600 TTL Flash Logo
373 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
