Question about Nikon COOLPIX L4 Digital Camera
Turning it on
When I go to turn it on the lens doesn't come out all the way. Any help!!
If you cannot find a solution to your problem you may want to email fixityourself@gmail.com. He has good advice and good used parts at a fair price.
Posted on May 22, 2008
I have been using this lens on my Canon Rebel EOS for years, but this morning it won't detach from the camera.
While turning the lens look at the lens mount. Does the lens turn but the mount stay stationary? If so maybe there is a connection issue. With the release button pressed then rapidly turning the lens back and forth, maybe it will release. Maybe something simple, or the lens connector to the lens mount or lens mount itself is the issue.
Feb 04, 2016 | Quantaray 70-300Mm Tele-Macro Camera...
Hi. my problem with my camera is that my niece play with it and she pushed the lens mechanism while the camera is on. now, the lens was stuck and doesn't comes out anymore. when i'm turning on
Force it out like it was forced in. Try to rotate the lens. Remember it has to be off. As soon as the lens is half way out, turn the camara on and the lens will go to its position. If not, while the lens is out turn it left or right until it's back to its position.
Good luck.
Aug 24, 2012 | Sony Cyber-shot DSC-W55 Digital Camera
I have a Canon PowerShot A430 camera. When I turn it on, the lens doesn't open and it shuts off. The message on the screen says " Lens error, restart camera." Please advise. Thanks
The Lens Error is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
You can reset the Camera back to factory default by performing the following steps:
Press the power button.
Press and hold the MENU button for more than 5 seconds. Default Settings will get displayed.
Use the arrow buttons to select OK and press the FUNC./SET button. This will reset all the settings back to factory deafult.
This should resolve the issue. If the issue persists, service may be required.
Thanks for contacting FixYa
Aug 10, 2011 | Canon PowerShot SD500 / IXUS 700 Digital...
My camera can't focus when i press halfway down to focus before i press all the way down to snap the photo. it is only a problem with my 18-55mm lens. all my other lenses focus and take photos...
First off, try gently turning the focus ring on your lens while it is on auto focus mode (DO NOT force it). Sometimes a minor bump on the lens can cause the focus ring to come off the tracks. Try that and see if the lens start auto focusing again. I find that this solves the issues a lot of the time. If that doesn't give you any results then you'll need to take your lens to an authorized Canon service center for repairs. Hope this helps!
Hiram
Photo Tech Repair Service
110 East 13th Street
New York, NY 10003
212-673-8400
Jul 06, 2011 | Canon EOS 7D Digital Camera with 1855mm...
TURNING ON CAMERA ZOOM LENS DOES NOT COME OUT AND SCREEN SAYS 'TURN OFF THE CAMERA AND TURN ON AGAIN' WHEN THIS HAS BEEN DONE NOTHING CHANGES. COVERS DO NOT COVER LENS COMPLETELY AND ZOOM...
Here are some troubleshooting steps that you can try that may correct the problem. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Jul 04, 2011 | Cameras
I have a Polaroid t1035. When turning the camera on and off the lens will not collapse and makes a clicking noise.
This is a common issue with retractable lenses. A grain of sand, accidentally pressing the On button when still in the bag etc.
In most cases the problem is of mechanical nature - meaning one of the gears is stuck. The small motor doesn't have enough power to push through it.
Depending on the model - there are sometimes tricks to get the lens going again. It involves manually helping the lens to come out. There's a risk of permanent mechanical damage.
Jun 30, 2011 | Cameras
This lens makes a whirring noise when attached to the camera body. It will not focus in either manual or automatic. The camera works well with the other lens.
Sounds like the focus mechanism is broken on that lens. There's a small screw on the back of it where it meets the camera body, the motor in the camera body turns that screw to autofocus. To me it sounds like the screw is turning, but the lens isn't focusing. You said it also doesn't focus in manual mode, so there is probably something inside the lens that needs repair or replacement. Your best option is to take it to a camera repair shop and ask them for an estimate, camera lenses are not the kind of thing you can take apart and fix on your own. Hope that helps.
May 03, 2011 | Nikon 35-70mm f/2.8D AF Zoom-Nikkor Lens
I have a Canon S400 digital elf. Suddenly, the lens doesn' open....after recharging battery. I get a beep followed by buzzing....and the screen says 'E18'? Can you help. Thank you Mickey Chasse
This is a very common problem with several digital cameras the buzz sound it the motor being obstructed. and it is giving you a lens error some times you can tape the camera on its side gently while turning it on and free the jam some times not. if not you need the camera serviced. I repair these all the time because of this problem. Cost for repair are normally 65.00 plus 10.00 labor and 8.00 for shipping the camera back let me know if I can help you any further on this issue.
Apr 25, 2008 | Cameras
Focusing problems????
Cleaning the lens worked well for me
Oct 30, 2007 | Fuji FinePix A500 Digital Camera
Nikon COOLPIX L4 Digital Camera Logo
19 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
