SOURCE: blue tinting appearing on the right side of screen on vpl-es1 projector
A warning in the manual was given as to be carefull when using this projector with games as some parts of the screen will not move, just like if you watch Tv on it and there is a channel logo in one corner that doesn't move! It burns the display like it would on a pc monitor if no screen saver set. This is not a problem you can fix, that is perminant damage to the lcd in the projector!! S Platt
SOURCE: image.xson Power Lite 730c
I had this problem with a Mitsubishi and it turned out to be the cable.
SOURCE: Blue tint on screen!!! Please help
Found out it is because the internal filters have burnt out. Only solution is to replace all internal filters in the machine $$$$
SOURCE: Projector gives off pink tint
when you have a tint on the projector its not a lamp issue, it is a connectivity issue you have to check the cables if they are connected firmly, or swap the cables with good known cables , if this doesn't help you have to send the projector to infocus repair center, since it is a DLP projector this may require engine /major repair
SOURCE: Hitachi cp-s240 blue tint cloud problem
This might sound like a worn spot in the (blue) lens from heat, or a bad color driver on the mother board. It could possibly be dirt or condensation behine the lens(s)
