Question about Armitron Watches
Need Directions on How to Set an Armitron EL All Sport Watch
I need directions on how to set this watch and use it's various features. I have included the numbering information on the back of the watch in case that is helpful to finding a solution.
Thank you
Tammy
5 Suggested Answers
SOURCE: changing the time on my wristwatch
Hold the "reset button" about 30 secs, than the hour starts flash and you can change them pushingst/sp button. Martin
Posted on Mar 21, 2009
SOURCE: Armitron Pro Sport Watch Hourly Chime
Based on insructions for another watch, I just figured this one out. The steps would be:
Get in Alarm mode (press mode button)
Then you can cycle through the following by pressing the ST/STP button
1. Alarm on
2. Chiime on
3. Alarm and Chime on
4. Alarm and Chime off
You can see this with a magnifying glass and watch the center and right hand circular icons at the top of the display.get highlighted.
Posted on Jan 16, 2009
escapement
  • 2334 Answers
SOURCE: I have a Ladies Armitron All Sport watch Model
Follow this link and find instructions for your watch:
http://www.armitron.com/watch_instructions.asp
Do not forget to rate, please.
Posted on Mar 09, 2009
escapement
  • 2334 Answers
SOURCE: need instruction manual for armitron all-sport
Find it in my tips.
Posted on Jan 26, 2010
  • 51 Answers
For the Amritron 45/6975:
From the "Time Telling Mode" (date/time displayed): to set the date and time: Press "reset" unit the date disappears--release; press "mode", the "hour" will flash2_bing.gif, press "st/stp" to adjust hour; press "mode", the "minute" will flash, press "st/stp" to adjust minute; continue same sequence to adjust date; when done, press "reset"
Posted on Feb 27, 2010
Set the time on a 3-button Armitron All Sport 45/6963
I have the same watch. I've figured out how change in and out of 24 hour time.
1. press and hold "ST/STP" until the month/day screen is visible.
2. while holding "ST/STP", press "MODE". A 'p' visible below the month/day indicates 12 hour mode. The absence of a 'p' indicates 24 hour mode.
Manual for 4-button version is here, but all the directions are applicable. https://www.armitron.com/images/upload/XNAPE01.pdf
Nov 05, 2012 | Armitron Watches
I have a 45/6975 all sport watch and have lost the directions for setting alarms. Can I get a copy of the manual directions.
You can get instructions from the Amitron web site.
Copy "www.armitron.com/watch_instructions.asp" into your search engine
and you will see a list of illustrations of watches and associated
instructions.
Choose the one that looks like yours and download the PDF file
Aug 06, 2011 | Armitron 456975 Digital Sport Watch
I can't set the time. I follow the directions and
you have to press it and hold for at least five seconds.
Jul 27, 2011 | Armitron Digital Sport #45/6967PNK Watch
Do you have directions for armitron mens pro sport watch 49/1000
Hi robinmsavage,
I will be glad to help you with your concern regarding your Armitron Wristwatch, what exactly would you be experiencing? cause I only put info on how to set time and date on the Watch.
Please see below steps:
  • Your Armitron Watch will have Four Button on the side of the watches rim.
  • Button on the upper Left is MODE.
  • Button on the lower Left is LIGHT.
  • Button on the upper right is DATE.
  • Button on the lower right is Alarm.
See Steps below:
*Setting the time*
  • Press and Hold down the Mode Button til the Hours flash
  • Then push Alarm Button to set the Hours
  • Press and Hold down the Date Button till the Minutes flash, then push Alarm Button to set the minutes
  • After setting the minutes on your watch, Press Date till you get the month flashing push Alarm to set the month
  • Press the Date again till the Date flashes, then push Alarm to set date
  • Press the Date again till the Date on your watch flashes, then push Alarm to set the date
  • After setting everything push the Mode Button again just once to set everything or finalize your settings on the watch.
I hope that this will be of help regarding your query on how to set the time on your Armitron watch, I also included the setting of the time and date just for further details.
Thank you for choosing Fixya,
mvincentc
Apr 21, 2011 | Armitron Chronograph Sport #204345BKBK...
How do I turn off the alarm on my Armitron watch?
I don't know whether this is what you are looking for, as the watch comes with no packaged instructions OR general support, on their website, XD,
Nik.
http://home.earthlink.net/~eldonenew/armitron.htm
or
http://www.ehow.com/way_5786808_armitron-all_sport-watch-instructions.html
Armitron All-Sport Watch Instructions By Brian Walker eHow Contributor 9 Found This Helpful The Armitron All-Sport is a unisex style of watch made by Armitron that features a digital readout and four buttons around the outer dial for adjusting various aspects of the watch. It can set alarms, keeps the time as well as the date, and has a built-in backlight. Accessing and adjusting these various settings is a fairly simple process.
Other People Are Reading
Setting Date, Time and Alarm
  • To enter the date and time setting mode, press and hold the "mode" button, located on the top-left of the watch. Continue holding this button until the display begins to flash. This first display is the alarm setting, should you choose to set an alarm to go off. If you'd like to set the alarm, use the "alarm" button on the bottom-right of the watch to advance the hours to the desired one. Then press the mode button again; this will cycle through the minutes and seconds of the alarm to allow you to set those as well. Once you have set the alarm, you can press the "date" button at the top-right of the watch to proceed to the regular time setting. These numbers, which will now be flashing, also are adjusted by pressing the alarm button to change them. Pressing the date button again will now cycle through the hours, minutes, seconds and the date. As you continue to press the date button, the All-Sport will continuously cycle through these options; don't worry if you forget to set one, you can simply press the date button a few times until you get back to the setting you need to change. Once the alarm, time and date have all been set, you can press the mode button one more time to exit to the normal watch mode that will display the date and time.
Using Chime and Alarm
  • The Armitron All-Sport features both an alarm and an hourly chime. The alarm function will cause the watch to continuously beep at the selected time until you turn it off by pressing a button. The chime will cause the watch to beep once every hour. You can turn both these features on and off by pressing and holding the alarm button and while holding it pressing the date button. The first time you do this, the chime will turn on and a small house symbol will be displayed on the watch face. Performing this button-pressing sequence again will turn on the alarm, which in turn displays a small clock icon on the watch face. Each successive pressing of this button sequence will alternate between the chime and the alarm, turning them either on or off.
Backlight
  • The All-Sport also features a built-in backlight to help you view the watch in dark conditions. This light can be activated by pressing the "light" button on the bottom-left of the watch. Pressing this button is the only way to activate the light, and doing so will only cause the watch to illuminate for a few seconds at a time.
Read more : http://www.ehow.com/way_5786808_armitron-all_sport-watch-instructions.html
Jul 20, 2010 | Armitron Round Digital Sport 408089 Watch
Unable to set day/date/year &time
Follow this link and download instructions for your watch:
Mar 11, 2009 | JCPenney Armitron Sport Watch
Can't set time on a 2 button armitron watch
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Armitron says if the model is not listed on their site call them 718-784-0700. I did and they promptly e-mailed me PDF.file instructions for my M516 watch. - David
Mar 10, 2008 | Watches
Watches Logo
202 people viewed this question
Top Armitron Watches Experts
Michael Vincent Cruz
Jimmy Accardi
Are you an Armitron Watch Expert? Answer questions, earn points and help others
