lInk to download pc suite 7 that new version pc suite. After you have installed the pc suite to your pc, then connect, it will ask you to install at phone.
IF YOU HAVE BLUETOOTH DEVICE AT YOUR PC/LAPTOP, THEN YOU CAN CONNECT IT . TRY CONNECT IT FIRST USING BLUETOOTH. THEN IF IT WAS CONNECTED, USING PC SUITE.
My best oppinion is no need to connect the Pc via Bluetooth.Instead of using bluetooth you can use USB cable via Nokia PC Suit.Coz During using bluetooth some interuption might comes When someone switch on their Phone's bluetooth.This may help you .Thanks
It is very simple provided that your system has a Bluetooth, and you have a very recent Nokia PC Suite, preferrably from version 7.1.18.0 and above. If you dont have, you can just go online and download a copy from either : http://europe.nokia.com/get-support-and-software/download-software/nokia-pc-suite or http://www.softpedia.com/get/Mobile-Phone-Tools/Nokia/Nokia-PC-Suite.shtml Just Install the Nokia PC Suite on your system, and make sure that your system 's bluetooth as well as your phone's bluetooth are switched on. Thereafter after installing the Nokia PC Suite, when you are prompted to select connection type, just select bluetooth and click next. The software will then try to automatically detect your phone and pair with it. It might ask you for a passcode, just use 1234, or any other number you like. Hope this helps you out. Goodluck!
1.
You can use the USB data cable to transfer data between
the device and a compatible PC or a printer supporting
PictBridge. You can also use the USB data cable with
Nokia PC Suite.
To activate the device for data transfer or image
printing, connect the data cable. Confirm "USB data
cable connected. Select mode." and select from the
following options:
• Nokia mode — to use the device for PC Suite
• Printing & media — to use the device with a
PictBridge compatible printer or with your
compatible PC
• Data storage — to connect to a PC that does not
have Nokia software and use the device as a data
storage device
To change the USB mode, select Menu > Settings >
Connectivity > USB data cable and the desired USB
mode.
2.
Set up a Bluetooth connection
Select Menu > Settings > Connectivity >
Bluetooth and from the following options:
• Bluetooth — Select On to activate the Bluetooth
function. indicates that Bluetooth is activated.
• My phone's visibility — to define how your device
is shown to other Bluetooth devices
• Search for audio enhancements — to search for
compatible Bluetooth audio devices. Select the
device that you want to connect to the phone.
• Active devices — to check which Bluetooth
connection is currently active
• Paired devices — to search for any Bluetooth device
in range. Select New to list any Bluetooth device in
range. Select a device and Pair. Enter an agreed
Bluetooth passcode of the device (up to 16
characters) to pair the device to your device. You
must only give this passcode when you connect to
the device for the first time. Your device connects to
the other device, and you can start data transfer.
• My phone's name — to set the device name for
Bluetooth connections
3. Take off you microSC memory card then read directly to your computer
there are 2/3 ways to connect to a pc. (1) data cable from your nearest nokia outlet (2) bluetooth you need to buy a bluetooth"dongle" and install software. (3) wireless as bluetooth you need wireless on pc and phone. if you visit www.nokia.com you can download the nokia suite for free.
hi, i seems u have installed the B T correctly, now to connect to the internet u need to creat a DUN (Dial Up Networking) there you can provide the ISP dial up No. Username etc...if u can see a Bluetooth icon on the right bottom corner, right click on it, u will have a option for DUN there,once there u will figure it out..let me know..
