Question about Whirlpool Ovens
I moved into a new flat and the AKP 239/01 IX stove was already built in and there is only user manuals in every other language except English!! The owner does not have it and no-one knows where it is! I am unable to use by stove! I could figure out the temp setting and the function but how do you know when the stove has reached the correct temp you set it on? Thank you!!
    Top Expert:
  • Whirlpool Master
  • 53,745 Answers
Google -- user manual for ( make and model of stove ) and download the pdf version
failing that go to places like Jaycar and buy an infrared thermometer
you aim this unit at where you want to read the temperature and it reads it
so aim it at the oven glass and you have the temp
or aim it at a hot plate and you have the temp
Posted on Sep 08, 2017
SOURCE:
Amigaman
  • 248 Answers
SOURCE: Whirlpool built-in single oven AKZ451/IX/01
If this is an older oven, check to see if it has a control knob or switch labeled "manual and "hold". Make sure it's set for manual. The hold setting maintains temp at about 140 degrees.
If not the case, is this gas or electric?
Posted on Nov 11, 2007
SOURCE: Setting Clock and Timer
Worked it out for myself - no solution needed now thank you.
Posted on Jun 22, 2008
SOURCE: omega europa 40-1 oven settings?
I had the same problem when I moved into my current apartment (mine's the 20-1 model). I was at a loss as to what all those symbols meant, so emailed info@hagemeyer.com.au and they sent me a pdf copy of the manual. It's not exactly the same model as you have, but I assume the symbols are the same. I'm happy to email you my manual if you'd like. Otherwise, the controls (for the 20-1 at least) are as follows:
Fan symbol - defrost (fan only - does not use thermostat)
Fan symbol within a circle - fan forced oven
3 little triangles - static grill (keep oven door open)
3 triangles above the fan symbol - fan grill (keep door closed)
I hope that all makes sense.
Posted on May 12, 2009
  • 18 Answers
SOURCE: Whirlpool - akz451/ix/01 - Fan oven blowing out cold air
could be a blown element if not it could be a safety cut out or the stat
Posted on May 17, 2009
SOURCE: No heat from oven but fan and light works
Timer might be blocked on auto, you need to get it back to a manual setting.
Posted on Oct 18, 2009
I need a user manual for my very old Ariston FM81R AUS. I have just moved into a rental property and most of the symbols have worn away on the controls
Hello, Karen -
I am answering from the USA.
I have not found a manual to download for your model of Ariston oven. The Ariston website does have manuals which can be downloaded, but your older model is not listed:
https://aristonbrand.com/user-manuals/
Therefore, I suggest you contact Ariston Customer Care and ask about the availability of a user manual for your model. This is the link to the Ariston Contact Us web page:
https://aristonbrand.com/contact-us/
Most likely the company holds a copy of a user manual for your model in its archives. If it does, there may be a charge to make a copy of the manual and send it to you.
Best wishes.
Aug 30, 2018 | Ovens
I have a whirlpool built in oven AKP 239/IX/02 When I try to turn the oven on (both dials) the sign "- - - C" discpays on the digital display screen and the oven will not turn on.
We're sorry to learn of your experience. For further assistance with your Oven, we recommend the link below. You may contact our counterparts in your Region due to you are outside the US.
http://www.whirlpool.co.uk/
Jan 17, 2018 | Whirlpool Ovens
Whirlpool Absolute Built-In Oven in Stainless Steel AKP 7460 IX user manual ?
Dalene, we recommend the link below for the User Manual.
http://www.whirlpool.co.uk/appliances-1/ovens-3/whirlpool-absolute-built-in-oven-in-stainless-steel-akp-7460-ix/857774601700/
Jan 16, 2018 | Whirlpool Ovens
How do I remove the glass panel from the door of the AKP 216/IX?
open door a little and lift off hinges . lay on floor and unscrew the screws around outer edge . lift half off and carefully take glass out to wash . reverse process to reinstall .don't forget to vote if this was helpful
Feb 29, 2016 | Ovens
Whirlpool Manual
Call this number and tell them your situation 1-866-698-2538. Canada 1-800-807-6777
Oct 28, 2013 | Ovens
Apr 12, 2009 | Ovens
Ovens Logo
244 people viewed this question
Top Whirlpool Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
