SOUND LIKE AIR CONDITIONER NEED A CHARGING OR YOUR COOLING FAN NOT RUNNING WHEN AC TURNED ON.COOLING FAN HAS TO RUN TO COOL DOWN REFRIGERANT IN CONDENSOR.
it could be several things could be the switch,also there is a flap in the dash that may not be opening,but if the compressor is kicking on and you are able to hook a gauge up to ensure you do have enough freon in the system this is a must try those things and let me know good luck!!!
If it is not blowing out enough cold air it appears you may be low on refrigerant. The latter will cause the compressor to short cycle with resultant warmer than normal output temps.
i assume you emptied the system first?are you using air conditioner in a can?or proper freon ?those cans are designed get used up really fast so you have to buy more of them.but yeah add another can.i use propane in my system it works great and is alot cheaper but illegal so im not recommending it but it will solve your problem.
car air conditioner blowing hot air is cause by either a leak or a clogged condenser, since it has a freon in it then it might be a case of clogged condenser but this is just a contributing factor, it is possible that the leak is small that you wont even notice that the freon is not enough for the a/c to blow cold air.
This means you need to add more freon, you can take it in to get added or just go to your nearest auto shop and buy some with a connector and just turn your car on with your air conditioner on high, and connect the line to your can then to the low side of the air conditioner lines and hold the can up right so you let the gasses in, not liquid. when can is empty remove from low side and be careful disconnecting from can because freon is very nasty stuff and may still have a little in the can. and repeat until necessary.
