Back to:
Tags:
D-Link AirPlus DI-524 Wireless Router
Everything is working very well on my di524
posted by joe036 on Apr 15, 2008
but I wabt to know how to create a password to avoid being copied
Comment by joe036, posted on Apr 15, 2008
joe036 thanks you for helping everybody to solve our problems. see you around
jose burcas
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Apr 16, 2008
Not Rated (0)
Benimur
Rank:Guru Guru
Rating: 87%, 2758 votes
To my knowledge, the only password that could be set/changed is when you log into to your DI524 web configuration page. Once the WiFi router is setup and running, you can also changed. There is no password required for your wireless clients (users). There is however a provision for Security key which could be WEP, WPA or WPA-PSK. All of these could be accessed upon entry to the web configuration page of the DLink DI-524.
This page is an emulator that can help you be familiar how things are done to configure your WiFi router.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Everything is working very well on my di524:
I don't want to Accept this solution
Can you Help with these Routers problems?
hi im jaffar bayati i bout new oryx scannar model 600u its...
I had wireless connection before having to unplug and move...
I have a router D-link 524 which i have to configure, ii...
I have a di-524 dlink router hooked up to a cable modem....
unable to use wireless
Loading problems.
Repair Service
Prescreened Contractors
Get Matched to Prescreened Computer Networking Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
