Question about Car Audio & Video
2007 Mitsubishi Outlander Rockford/fosgate stereo system clock/radio cuts out periodically dealership can't figure out whats wrong changed out the face plate of the radio said it was a deeper electrical problem
duby1990
  • 370 Answers
SOURCE: Rockford Punch HE2 wiring question.
if your sub will handle it, bridging it will give you more power. The best thing to do is to find out how much power the amp puts out ( RMS ) and if it is in your power handling range bridge it. It sounds better and gives you a harder punch because of more power.
Posted on Feb 06, 2009
etirbynnor
  • 655 Answers
SOURCE: face plate removeal
Hello capthowdy148,
Here's the removal/installation procedure:
1) With the unit off, press OPEN to allow the front panel to slide
down.
2) Gently squeeze the release tab located on the bottom center underside and pull front panel down and away from unit to remove.
3) To install, insert left side first, then push right side to secure.
Hope this helps. If it does, please rate as "FixYa.
Posted on May 05, 2009
jpenn1192
  • 58 Answers
SOURCE: Rockford Fosgate P2 12" cone
TRY GOING TO, SONICELECTRONIX.COM, OR WOOFERSETC.COM
Posted on Jun 18, 2009
Suzman
  • 642 Answers
SOURCE: Hi, i have a problem
On earlier models moisture under the passenger side front seat caused problems with the amp and wiring located under the seat, which could possibly give the Error DC warning. If this is the case you will need to ensure that the carpeting under the seat is dry and also the connecting plugs on the harnesses. Hopefully there is no damage to the system as yet because these only carry a 6 month warranty if I'm not mistaken.
Posted on Oct 31, 2010
  • 1116 Answers
SOURCE: I bought a 2004 boat
Kenwood TDF42D Detachable Faceplate may be purchased here:
http://www.partstore.com/Part/Kenwood/Kenwood/KDC225MR/Kenwood/Kenwood/TDF42D/New.aspx
Posted on May 24, 2011
How can I add bluetooth to my 2009 :'( acadia so I can answer phone calls while I'm driving
Hello Robby Clark,
Look up Rockford Fosgate 3Sixty.3
(as I recall about $600 to add hands free Bluetooth).
I have found a couple of opportunities...
by going onto Crutchfield.com...
You put in your vehicle specifics... and what you are trying to accomplish... a lot of AFTER-MARKET radio opportunities present...
In my case MY STOCK RADIO NAVIGATION SYSTEM... touch-screen VIDEO... w/THX (theater sound) was already pretty nice...
rockford fosgate 3sixty Crutchfield Car Stereo Speakers Home
Theater Pro Audio 4k TV
Amazon com rockford fosgate 3sixty 3
May 29, 2016 | Cars & Trucks
The fm part of my car radio does not work, can someone tell me what the problem would be for this
This kind of description defies any sense of the complexity of these devices. It can be anything from a bad solder joint to a defective IC to an antenna connection. I have worked on all kinds of Radios and it is hard to tell what is wrong without looking at the device. I doubt anyone in the world can come up with a one line answer.
Jan 31, 2013 | OEM 2007 Mitsubishi Outlander Radio / CD...
Hello, My rockford fosgate in dash unit is not
Are your rear speakers smplified or ran directly off of the radio?
Jul 29, 2011 | Rockford Fosgate Stereo Audio+video Rca...
I would like to ask what are the things needed to replace my single in dash stereo with a 6 cd changer rockford fosgate stereo? My car is 2008 mitsubishi eclipse gs.
what you will need is
1 new radio
2 dash kit
3 wire harness
4 antenna adapter
5 maybe a radio interface to adapt the new radio
caraudioquestions@gmail.com
online store comming soon
http://www.tintingbyfredjohnson.com
can ship you any thing you need take visa master card
Oct 14, 2010 | Mitsubishi Car Audio & Video
How do you do the video bypass for a fosgate lancer navigation?
You need to pull out your stereo. Find the parking brake wire on the back, leave plenty of room and cut it. Now wire it right back to the radios ground wire in the harness. This will tell the radio that you are always in park.
May 14, 2010 | Rockford Fosgate RAVDVD2 Car DVD Player
Where is the aux plug for this radio; Eclipse's optional Rockford Fosgate premium audio system
The Mitsubishi Eclipse with the Rockford Fosgate premium audio system does not actually have an aux plug. When you are scrolling through the sources, one of them listed is an AUX. This implies that there is a headphone jack somewhere in the vehicle where you can plug an iPod into and play it through the system. The port, however, was never actually installed on all pre-2009 eclipses.
The only way to access this feature of the stereo is to obtain an AUX cable from the mitsubishi dealer, which will be a wire harness that connects to the back of the head unit and provides an additional AUX port cable allowing you to plug in your iPod. You can talk to your local mitsubishi dealer about the cable, from what I hear, its rather expensive, and then go to best buy, somewhere similar, to have them install it.
Aug 06, 2009 | Rockford Fosgate Car Audio & Video
Error code E 03 on a Rockford Fosgate 6 disk CD player
I am having the same problems. Did you ever figure out what was wrong?
Jul 25, 2009 | Rockford Fosgate Car Audio & Video
AM Band in Rockford Fosgate 6 Disc Changer not working
check it out w/dealer and some mitsubishi seems like there is an issue with some corrosion in the antenna base on some models from 2007. Under warranty replaced the antenna base.
Jun 18, 2009 | 2007 Mitsubishi Outlander XLS
Car Audio & Video Logo
367 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
