Question about Lexmark X1240 All-In-One InkJet Printer
Cartidge prob?? Hi hope you can help. My son and I were doing a science project and couldn't purchase any ink at that time of day. The warning sign came up that we were low on light magenta, but we kept pushing ok to just print without it to finish. Then it came up cannot print to ensure printer health. Purchased a new cartridge and installed it but it still says "replace the following empty cartridge to resume printing. Have tried factory resets, unplugging, cleaning contacts etc
  • 983 Answers
You are good at taking things apart and not destroying them, then the problem can usually be fixed easily.
Remove the ink carts.
on either side of the carrage there is a screw, remove both of them.
CAREFULLY slide out the silver bar those screws are holding. Be sure to note its orentation for putting the thing back in later.
also carefully remove the silver "fingers".
remove the black clip/cover on the right side of the carrage that covers the ribbon cables.
lift the head (you see 4 nipples in there-- that is the top of the head assembly)
gently pull out the ribbon cables.
on the bottom of the head is 2 screws, remove them
now the head will come into 4 parts. Nipples, Gasket, nozzle block, and a metal guard.
get some windex with amonia.
soak the parts for a day or 2.
blot dry, then let it set for atleast 2 days to be sure it is COMPLETELY dry.
reassemble, charge the ink, do the printers head cleaning, and boom. back in business.
this works 90% of the time
any further assistance reply me
i am always here to assist you
thank you
bye
Posted on Apr 16, 2008
How do I change the ink cartridge on an epson sx215
Here's how you change the ink cartridge:
1. press the index sheet button and the scan button at the same time,
2. You then get setup menu. use" >" to select "change ink cartidge".
3. The ink cartidge will move to the opening position. 4. Lift the grey plastic clip at the back, and it
will open towards you.
5. Then you can just pull it out.
Hope this helps
Good Luck!
Thank you for choosing Fixya!
Mar 10, 2011 | Epson Office Equipment & Supplies
Hi dear, I've HP 2550 color laser printer. I've replaced the yellow cartridge. then started to print, but the paper comes out without ink.
make sure all othe cartidges are full not empty.
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 27, 2010 | Office Equipment & Supplies
I have had my ink cartridges refilled rather then replace them, but display is still showing as out of ink, please help!!
it are posible thad you have to reset the cartidge normaly you can ignore this warning by pressing ok
Sep 27, 2009 | Office Equipment & Supplies
Incompatible print cartridge
If you purchased the cartidge recently (30 days or less), then just bring it back to the store and tell the associates that it simply stopped working, they may be able to exchange it for you.
If not, you will probably need a new cartidge. The good thing about HP cartidges is that the print head (which is probably your problem) is built in, so issues are usually solved by just buying a new one. This, of course, means you have been replacing your print head every time you run out of ink, which adds up quickly in costs; but thats another subject
Hope that helps, Good Luck!
Aug 05, 2009 | HP OfficeJet 6110 All-In-One InkJet...
HP PSC 2410xi color printing issues
Try using warn distilled water and Q-tips to gently clean the area where the ink cartridge and the carriage mate up. You may have dried old ink in there which is clogging the print nozzles. Allow to air dry, reinstall cartidges, start machine and let it go through its cleaning cycle. Also check www.hp.com. Hope this helps.
Jan 30, 2009 | HP PSC 2410 All-In-One InkJet Printer
Dell 924 all in one printer cannot remove low ink warning
This happens if you are not using the Dell ink Cartiridges. However there are few work arounds on this issue.
Firstly, Please try to remove cartridges and then clean cartridge slots and make sure that printer is OFF and completed disconnected from Computer. Remove the cable between Printer and Computer while you do this.
After that restart the computer and then try to reconnect every thing and check if this happens
if else, then open the printer properties or printing preferences and locate the option that says Calibrate the cartidges. and do the calibration of cartidges. Calibration is compulsory once if you replace the ink cartidges.
if still fails then reinstall printer software. This should resolve the issue.
Thank you.
Dec 31, 2008 | Dell 924 All-in-One InkJet Printer
Still says "replace ink cartridge" even after I did replace it
you are good at taking things apart and not destroying them, then the problem can usually be fixed easily.
Apr 13, 2008 | HP Photosmart C6180 All-In-One InkJet...
No Yellow Or Cyan Ink
Hi do the following and hopefully it will help you. If it doesn't then you have a fault carriage or main PCB.
  • Remove ink Cartridge
  • With a soft cloth wipe clean the gold contacts on the carriage unit and the same on the ink cartridge
  • reinstall the ink cartridge
  • Click start
  • Select printers and faxes
  • Right hand click on the printer icon
  • Select Properties
  • Click on Services Tab
  • Click on clean print heads
  • Then click on Prime.
Hopefully this will work
Thanks J
Dec 01, 2007 | HP DeskJet 990cxi InkJet Printer
Lexmark X1240 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
