Question about Sharp AL 1631 Copier
Copier runs but copy is not made
When Copy is pressed it sounds like the drum or toner is moving there is a clicking sound but no paper is moved or comes out.
  • Anonymous May 30, 2008
    after every three machine make a grinding noise the laste time i change the drum start working on till now
  • 62 Answers
Please replace the toner cartridge.
sometimes it doesn't show that toner is empty
Posted on May 13, 2008
Why do we have blank copies on Xerox XC830?
is it problem when you try to copy vis adf or its aucord in platen glass also?
Sep 17, 2012 | Xerox Office Equipment & Supplies
On my AL-1631, it has stopped making copies. All other processes are normal, using either the paper feeder or from the screen, paper goes through system but fails to copy. Toner cartridge is fairly new...
Sounds to me like your lamp is stuck. There is a scan latch that can catch the lamp. it is on the under side of the scanner on the left side.
Or is your lamp not coming on at all.
If it prints , it eliminates the laser, drum and developer unit. Try making a page with the top up and see if the lamp is moving back and forth.
Apr 21, 2011 | Sharp AL 1631 Copier
Np 6412 copy dirty lines length of paper
Sounds as if the drum needs to replaced. How long has it been in the copier? They are supposed to be good for 30,000 copies or one year. It could also be dirty optics ( mirrors and glass ). Drum is easily installed by the customer. Just practice with the old drum - removing and re-installing before using the new drum. Too expensive to damage when installing. **** open the copier, Look under the control panel and you should see two levers. Move the right one to the right - this moves the developer away from the drum. Then move the left one down and this releases the drum for removal. Reverse procedure and power up the copier. It will automatically run and set the new drum settings into the copier.
Dec 08, 2010 | Canon NP 6551 Black and White Copier
When the "add toner" and "toner disposal" lindicators lit, I continued copying, until the indicator "memory overflow/data error indicator" lit - and no more copying was possible. Then I replaced the toner...
you have to reset the tonner counter and the drum ..and after that try again ...you will also have to empty the memory so to be able to take jobs ..Im not sure about the reseting procedure..but try to shut it down ..than unplug ...plug it back and press the power button and keep it pressed until it beeps ..will be about 15 seconds or so ..If this will not work ..take a look in the manual and see if they explain the exact procedure..
For other similar models you have to open the front door to get it into service mode..than from the service mode with the arrow select reset ..than one by one reset all ...toner counter ..drum ..and waste tank ..after that will do ..
Aug 20, 2010 | Panasonic Workio DP-4530 Copier
Clean the drum on a Aficio copier
cleaning the drum wont help sounds like waste extraction coil is blocked
very very very common on those copiers and cleaning blade is contaminated,or you didnt keep it level when u moved it.In any case ull need engineer to fix it,unless u brave enough to take the drum unit apart and hoover all the toner/paper dust from the waste coil.Just dont touch any metal bits on your hoover ull get electric shock, have fun.
Mar 30, 2010 | Ricoh Aficio 1015 All-In-One Laser Printer
How to know if My copier need a new toner
For the toner you will have message that you need exchange it.
How many copies do you have? (press COPY key by the display and hold until the no of copies is displayed)
Where does the paper jams? ( on drum, on fixing roller, in cassete, in doc. feeder,...)
try to clean the pickup, feed and separation rollers
Feb 28, 2010 | Sharp AR-5316 Advanced Digital Imager...
How many copies should a copier produce before changing a drum
I bought a km1620 copier. but copied only A4 size paper. No longer paper can not print except A4 paper. how can I change copying system. And how can I count copy. pls. mail me.
mizan
Jun 12, 2009 | Kyocera Copystar CS-1620 Black and White...
Copier does not print copy
this noise could be coming from the by-pass , because toner fall down pain in *** to take out. dale
Jan 18, 2009 | Sharp AL 1631 Copier
Sharp Al-800 Skewed Copies
one problem with this machine, a small pin comes out on the paper release handle in the back, which lets on side of the paper lift tray to come up higher than the other. might look in that area. good luck
May 15, 2008 | Sharp AL 800 Copier
Cannon Copier
Sounds like your drum cartridge might be bad.
Something you can try that might narrow down the problem is to make a copy of something and shut the copier OFF in mid copy.
(Basically, when the light is about 1/2 way finished scanning.)
Then, open the machine up and removed the jammed paper which should be 1/2 way through your machine and hopefully about 1/2 way under the drum/toner cartridge unit.
See how the copy looks at that point. **** FYI **** The toner on the paper is NOT FUSED so it will RUB OFF. Keep the paper away from your clothes and toss it.
IF your copy has smudges on it, then there is a real good chance that your drum unit is bad and needs to replaced.
If the copy looks good, then there is a possibility that the fuser unit is bad and needs to be repaired.
I would say that your drum unit is bad with my experience with Canon Copier.
If you still have more questions, feel free to ask.
Have a good day.
Good luck.
Mac
Mar 23, 2008 | Canon PC-D320 Copier
Sharp AL 1631 Copier Logo
42 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
