Question about Mustek DV5300SE DIGICAM Digital Camera
Cant take picture
I cannot take a new picture because i always have a black screen on the lcd . I think the lens is not opening. Is there any solution please?
  • 983 Answers
I think the ccd sensor is gone ....
if you can access the menu options then it is confirm that there is no firmware problem ...
if you can access the menu options just try giving reset once...
if problem persists then exactly ccd sensor is out...
you must contact the service showroom ...
it is fixable....
any doubt reply me ..
i am always here to assist you ..
thank you
bye
Posted on Apr 16, 2008
I received a Leica Digilux 2 from a relative and i cant seem to see anything thru the viewfinder or the lcd screen. Its just black. Is the shutter not open? I can see all the numbers and settings around...
Open the back of the camera. **** the camera as if you were advancing the film. While looking in the back, push the shutter release, like you were taking a photo.
You see the mirror flip up and glimpse a flash of light as the camera cycles.
If you do not see the mirror flip up and return, the camera needs serious repair..
As for the LED Display, put some new batteries in it.
Feb 12, 2011 | Leica Digilux 2 Digital Camera
My lcd screen is black
From what I can understand, if the camera is sill able take pictures but is not displaying any thing on the LCD, then it is a problem with the LCD or LCD cable connecting to rest of the camera or LCD driver on main board.
It can be as simple as a loose flexible PCB connection to the camera main board.
' + '' + google_ads[i].line1 + '
' + '' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
' + '' + google_ads[i].visible_url + '
'; } } var adsByGoogleRight = "-40px"; if(dartRecieved){ document.getElementById("ga_300x250").style.clear="both"; document.getElementById("ga_300x250").style.left = "0px"; document.getElementById("inner_adv_caption").style.display = "block"; adsByGoogleRight = "5px"; } else if(isHealthinationExist){ var healthinationBox = $('healthonationBox'); if(healthinationBox){ var helthinationBot = getObjXY(healthinationBox)[1]+healthinationBox.clientHeight; var ga_top =getObjXY(document.getElementById("ga_300x250"))[1]; if(ga_top-helthinationBot >0){ document.getElementById("ga_300x250").style.width = "530px"; } else{ document.getElementById("ga_300x250").style.width = "410px"; } } $('boxAdWrapper').style.display = "none"; } else{ document.getElementById("ga_300x250").style.width = "530px"; $('boxAdWrapper').style.display = "none"; } //add "ads by google" var logo_img = 'abg-en-100c-000000.gif'+versionno+''; s += '' + logo_img + ''; document.getElementById("ga_300x250").innerHTML = s; var currl = $('related_links'); var currq = $('related_questions'); if(currl!=null && currq!=null){ var currltop = getObjXY(currl)[1]; if(currltop > rltop ) currq.style.clear="left"; } return; }; //--> var niB = document.getElementById("niBannerID"); if(niB && niB.style.display=="block"){ document.getElementById("q_answer").style.marginTop = (niB.offsetHeight+70)+"px"; } -->
Jun 20, 2008 | Panasonic Lumix DMC-LZ2 Digital Camera
When I turn it on the screen stays black. When I try to take pictures they are black. The flash is working. I can sight through the view finder. I can view existing pictures on the LCD screen so I am sure...
your dead right the lens is closed when the unit is turned on a small latch pulls away a black sheld that stops light (direct) from damaging the lens these latches fail some times and are real expensive to have fixed
im sorry but i think its time to go looking for a new camera
good luck
Jun 25, 2010 | Vivitar ViviCam 5385 Digital Camera
Problem with canon a420 digicam
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Note that your camera will not be able to take 15 second exposures, as per the above "fix". Instead, place the camera in manual mode, turn off the flash, and take the exposures in a darkened room. This should give you a couple seconds, just enough time to open the battery door while the red and yellow lights are flashing.
Sep 21, 2009 | Canon PowerShot A420 Digital Camera
My sony dsc-w1 got very wet, caught in a rainstorm and did not have the case. I have left it dry out for 4 days and it turns on, lcd works, can read memory stick and display old pictures on the lcd. But...
Maybe the shutter got wet and sticky. You can try look into the lens then press shutter button to take picture. If you don’t see the movement inside the hole, the shutter doesn’t open, it will take black picture.
Jul 08, 2009 | Sony Cyber-Shot DSC-W1 Digital Camera
Cant take photos with my Kodak ZD710
check eye settting or its a fungus inside lens black screen is due to virus
Jun 18, 2009 | Kodak ZD710 Digital Camera
Cannot take a picture
i think the ccd sensor is gone ....
it is fixable....
thank you
bye
Apr 13, 2008 | Canon PowerShot A95 Digital Camera
Canon sd300 cant see pictures taken
This may sound silly, but did you check the shutter on the end of the lens when the camera is on to make sure that the shutter is open? Sometimes some dirt or sand can get into the lens barrel and make the shutter get stuck in the closed position. If this happens, gently open the shutter with a a toothpick or something (NOT your finger because of the oils and NOT something that will scratch the lens).
If the shutter is open and the pictures turn out black both on the camera's LCD and on the computer once you download them, then I'm guessing something happened to your CCD, which is the tiny electronic chip that records the light coming through the lens. Either something inside the camera has fallen in front of the CCD and is blocking the light (unlikely) or the CCD chip has died. If that's the case, I hate to say it but buying a new camera would be more cost effective (and probably cheaper) than getting it fixed.
Apr 10, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
White screen, won't take pictures, battery door won't open!!
Sony customer support is the place to go but I suspect a new camera is likely to be a more economic option
Jul 28, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Mustek DV5300SE DIGICAM Digital Camera Logo
Top Mustek Cameras Experts
Mohamed Ismail
Mohamed Ismail
Are you a Mustek Camera Expert? Answer questions, earn points and help others
