Question about InFocus ScreenPlay 4805 Multimedia Projector
Infocus X2 shadow on right side
After (gently) replace a lamp last Friday, there is now a vertical shadow on the right ~8" of the screen. Amazon's review forum indicates optical system coming unglued. You noted "Tunnel problem." in an earlier post. Would you kindly explain if this is applicable to the X2 model, and offer a resolution?
  • marvin613 Jul 16, 2008
    The left side of the screen has a gray vertical area about 6 inches wide from the top to the bottom of the picture
I fixed the light tunnel by replace it by a fold and cut stanless metal came from a dog food plate. ( use one who is shiny like a mirror)
You just have to cut the plate with a metal cissor and calculate exatly the size of the parts to replace.Not easy to fold so use a vice and a hammer to make 2 metal parts L shape, and joint it together with a aluminium tape, works Fine ! 7 $ fix ! Very solid !
Posted on Aug 16, 2010
  • 26 Answers
You are describing a light tunnel failure. Unfortunately, Infocus has decided to discontinue any parts for the X series. Your only recourse is to repair the tunnel with superglue. Or buy a new projector. If you do attempt repair, note that the corners do not line up, rather the sides are offset slightly.
Posted on Apr 17, 2008
I have the same problem, my tunnel is completely collapsed, Thanks for this info!
Posted on Feb 06, 2013
I had the same problem and managed to fix it. One of the sides of the light tunnel had become unglued and had collapsed into the tunnel. I reglued it and it has worked fine ever since. You need to remove a few brackets and the color wheel in order to access the tunnel from memory, it was a while back that I did it so cannot quite remember. I took photos incase I was able to help someone else.
Posted on Jul 04, 2008
2 Suggested Answers
projdoc
  • 2236 Answers
SOURCE: I have an infocus X2 projector that has a shadow
the light tunnel has collapsed and needs to be replaced. it's pretty simple to repair. there are directions on the "tips" part of my profile. so, you can get the part from an infocus service center and do it yourself or send it in to them for repair. either way, try www.avsolutionsny.com. they're really good.
Posted on Jan 29, 2010
I have a vertical shadow about 1-2 ft in width running up the right side of the projected picture. The bulb was just replaced this year and the shadow didn't start until some time after the bulb was...
The light tunnel has collapsed. Google "infocus light tunnel." You can glue it, as I did, but it tends to break again. From what I have read nobody has a good fix and the manufacturer has ignored the problem which has alienated a lot of customers. They won't even sell a replacement tunnel. Good luck!
Dec 01, 2010 | InFocus X1 Multimedia Projector
Have Infocus X2 projector. When on a dark shadow line appears down the left side of screen. Could it be a bad lamp?
no it is not lamp problem. it must be light tunnel problem.
after lamp there is tunnel for light travel, made from 4 pieces of mirror.
this tunnel is glued. glue tend to break in time so the tunnel is no longer doing its purpose.
open this part of projector, there should be 2 little screws holding it. repair it by reposition mirrors and glue them from outside by little drop of temperature resistant and elastic glue. that's it !
Oct 03, 2010 | InFocus Projector Lamp for LP340, LP340B,...
X2 projector A somewhat irregular vertical line has appeared near the middle. A slight rainbow affect at the line, right of the line gets progresively darker. The blank screen is normal. The projector is...
this projector does not have lcd's. it has a colorwheel and a light tunnel. the light tunnel has probably collapsed and needs to be replaced if you have distortion in the middle of the display. if it were to one side or the other or a the top or bottom it may have been adjustable. But wiith it being in the middle, I'd have to say you needed a new light tunnel.
Mar 12, 2010 | InFocus SP-LAMP-018 Projector Lamp for X2,...
A shadow on the right side of the screen
the light tunnel has collapsed and needs to be replaced. you can get the part and do it yourself. it's pretty easy. it's located between the lamp and lens, and under the colorwheel.
Mar 11, 2010 | InFocus LP 600 Multimedia Projector
It has a shadow on half the screen
the light tunnel has collapsed. you can get the part from an infocus service center and do it yourself or send it to one for repair. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Jan 18, 2010 | InFocus ScreenPlay 4805 Multimedia...
Infocus X2 projector shows picture in black and white only...
that little glass square broke off of the colorwheel, and it needs to be replaced. that yellow/gray line is from the light tunnel collapsing. both parts can be purchased and replaced by you. if you don't feel comfortable doing it, you can send it in to an authorized service center. try av solutions. they're pretty good. you can purchase infocus parts from them, too.
Oct 27, 2009 | InFocus Office Equipment & Supplies
Infocus X2 projector, white vertical strip on right quadrant.
on the X2, the dmd chip is attached to the main board on the bottom of the machine. you need to take the top case off, as well as the 2 power supply boards. push the dmd chip (behind the lens assembly) back onto the board.
Jun 04, 2009 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Infocus 70+
We have had similar issue w/ multiple LP70+ projectors. The units get to be 1-2 years old and suddenly the right vertical edge of the display is distorted. There is usually a shadowed vertical bar that clouds about 3-5% of the horizontal space from the right edge.
What's the cause?
Nov 13, 2007 | InFocus LP70+ Multimedia Projector
1/2 the screen is viewable
You would be wrong. Lamps do not do that. They either work or they don't, they do not cast shadows or give half an image.
What is going on is the light tunnel has failed. It is a small, 4-sided mirrored tunnel that focuses the light into the optical chamber. It is directly behind the color wheel. I've seen this probelm dozens of times.
Mar 30, 2007 | InFocus ScreenPlay 4805 Multimedia...
InFocus ScreenPlay 4805 Multimedia Projector Logo
1,787 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Juan Carlos Pacheco
Level 1 Expert
Electro Med Services...
color wheel light...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
