Question about LG DLE2514 Electric Dryer
Lg dryer just found your posting about the 6 minute problem. you stated that you cleaned the sensors. Where are they? I am having the same problem. Someone else posted that they unplugged the unit for a while and that fixed the problem. Just wondering. If you could e-mail me directly I would appreciate it. My e-mail is joedoss1201@comcast.net. thanks
  • 489 Answers
The sensors are located in the filter screen area inside the drum.  If you stick you head inside and look down, you will find 2 metal curved strips.  Those are your sensors.
Posted on Apr 28, 2008
Dryer stops at 6 minutes on sensor cycle
If you have chosen the manual mode and the dryer works well , then the fault can be with the sensor. need to check if there is false reading or if the control board has a issue.
Try to clean the unit and reset for a trial.
Oct 18, 2011 | LG DLE2512W Electric Dryer
I have an lg dryer model DLG5966W and the check filter light is on. It takes two cycles to completly dry my clothes. I cleaned the lint filter and still doesnt dry on one cycle. I then removed the filter...
Check your vent. Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
If there's a restriction in the vent--the clothing in the dryer takes longer to dry.
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry. Bonus:
LG DRYER
Problem:
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour.
Solution:
LG gas dryers are VERY temperamental in long vent set-ups. If fabric softener sheets are used in the dryer--clean the two stainless steel strips of metal on the lint filter housing with a SCOTCHBRITE PAD--scrub back & forth several times to remove the waxy residue from the fabric softener sheets. Most,if not all manufacturers do *not* recommend using sheets in dryers that have a moisture sensor (electrodes).
However--using a SCOTCHBRITE pad keeps the wax off those sensors which can be seen if looking *into* the dryer drum and at the lint filter housing.
If only *liquid* fabric softener is used in the washer--clean the dryer sensors once a month. Liquid softener also contains wax which can slowly accumulate on the dryer sensors from the laundry washed in the washer.
Jun 17, 2010 | LG DLG7188 Gas Dryer
Not enough heat
You may need to adjust the air flow on your dryer vent.
LG gas dryers are more sensitive to venting length and air flow resistance. The gas burner can cause a rapid increase in temperature compared to an electric burner.
Rapid temperature rise in a gas dryer leads to premature burner shutdown (longer time required to dry laundry).
The gradual temperature increase of an electric element is more "forgiving" in homes where the dryer venting is less than ideal.
Problem:
Solution:
LG DRYER SERVICE MANUAL
LG PARTS
May 11, 2010 | LG DLG5988 Stainless Steel Gas Dryer
LG Electric Dryer DLE2515S - dryer timer is stuck on 6 minutes and continues drying until I manually switch off - sensor dryer does not appear to be working either.
OK, test the dryness sensor for its operational value. if the test confirms sensor function, you will need to replace the main PCB board in this case.
Now, if the sensor test reveals a faulty sensor device, simply replace the sensor. In most cases, this iwll be a fualty PCB main and, replacing it will usually fix this issue.
Jun 01, 2009 | LG DLE2515S Gas Dryer
Drying timer on auto dry
I called LG...they said to unplug the dryer for 5 min. to reset the timer ...this solved the problem.
They also said not to use dryer sheets during the sensor dry cycle as the coating on the dryer sheets causes the sensor to malfunction as it can't read the humidity level in the dryer.
Dec 28, 2008 | LG Dryers
My LG Dryer timer gets stuck on 6 minutes everytime
Look inside the drum on the right side of the filter. You will see two metal strips, thee are humidity sensors. Wipe them down with soap and water. It worked for me. The info came from LG tech support.
Nov 12, 2008 | LG DLE2512W Electric Dryer
We had this problem three times. First two times we just removed, cleaned and put back the moisture sensor (metal strips inside). The last time we did as well but it didn't help. We phoned to a service guy and he said unplug the power cord for 20-30 minutes. And it worked!
Nov 12, 2008 | LG DLG2524 Gas Dryer
Longest 6 minutes ever
I wiped off the two rows of sensors located behind the lint trap inside the drum. Now my dryer shuts off at 0 minutes. The clothes are still a little bit damp so I let the dryer run for 10 more minutes. Try it before replacing the computer board.
Apr 03, 2008 | LG DLE2514 Electric Dryer
LG WD-3243RHD Front Load Makes grinding, crackling noise
Fixed!
"LE" code Stator/Motor Error.
It was a simple fix and only cost $17.68 at PartStore.com no affiliation.
Hall Sensor 6501KW2001A
http://www.partstore.com/Part/LG+Electronics+Incorporated/LG+Electronics%2fZenith/6501KW2001A/New.aspx
Here is the Service Manual
http://oasisappliance.com/products/lg/LGComboServiceManual.pdf
Bonus, it actually completes a wash cycle and does not stick at 6 minutes, drying forever.
Freakin service tech stated it was the Power Control Board, IDIOT!
While I was in there, I cleaned out the heater blower assembly and sensors. They were full of caked on lint and the sensors had debris all over them.
Also cleaned out all the lint and debris around the rubber seal, this will eliminate those annoying mildew oders.
Hope this helps someone, Happy New Year!
Feb 11, 2008 | LG WD-3243RHD Front Load Washer / Dryer
LG DLE2514 Electric Dryer Logo
181 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
