Tally 6312 Matrix Printer Logo
Posted on Jun 25, 2010
My lipi 6306 line printer showing error "paper out" I am unable to clear it
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 01, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1546
Points
7
Dear Sir,
Problem in paper calibration, u can go through given details 1) Offline, Test, Daig, Calib, Paper out, Enter, then u see Remove paper. then press enter. sum reading will come (4.something). After insert paper, (2.something). And Save == Offline enter, config enter, configuration enter, save enter, Power up. enter.
Next option 2) U can check the paper out sensor front one black sticker missing.
Parashuram Patil
  • jitendra Jun 29, 2012
    sir i have tally 6306 printer and my issue is my printer skipping one paper blank so what can i do plz tell mi
2helpful
2answers
In Lipi 6306 line printer "Checksum fault block 8".It is not going on offline.What should I do now.I have not faced this type of problem before.
In Lipi 6306 line printer "Checksum fault block 8".It is not going on offline.What should I do now.I have not faced this type of problem before. os window xp
2answers
Faulty Hammer voltage-2 earr
There is most likely a fault with one of the hammer coils, this would need investigating, other possible causes;Faulty / damaged ribbon cableFaulty main boardUpdate firmware, the error should change to a more meaningful error with later firmware
Paper moving fault
If the paper is moving freely in the printer and you are not experiencing any paper jams etc it may be possible the error is being indicated falsely.I would recommend firstly to ensure the tractor feeds on the printer are clean and free from a build up of paper dust etc. As the paper motion sensors are located on the tractor feeds.
If after the printer is cleaned the error is still see the problem may be related for a setting for the Paper Motion Threshold in the printer. this is the point at which the printer detects an error. This value is dependant on a number of factors; Paper Type, condition of the printer etc.
  1. Put the printer OFFLINE
  2. Press and Hold down LINE FEED and ENTER until TECH ACCESS ON is displayed (approx. 5 seconds)
  3. Press the MODE button
  4. Press the DOWN ARROW until TEST is displayed
  5. Press button 1
  6. Press the DOWN ARROW until DIAG is displayed
  7. Press button 2
  8. Press the DOWN ARROW until PMOTTHR is displayed
  9. Press button 3
  10. Press the Either ARROW to set the value to 170 and then press ENTER to save the value.
Once you have completed the above sequence press and hold down the LINE FEED and ENTER KEYS to turn tech access off, you can then test the printer. If the above does not clear the message try increasing the value further.
If the problem persits you may have a faulty paper motion sensor.
3helpful
Will lipi t6050 work with windows xp
how to solve technicle problem in lipi line printer 6306
26helpful
3answers
Problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
21helpful
4answers
The 6306 L showing HAMMER VOLTAGE 1 ERROR WHAT SHOULD I DO
ERROR IS BECAUSE OF DRIVER IC FAULTY IN LOGIC CARD
PLZ CHANGE THE HAMMER DRIVER IC IN LOGIC CARD
Image not clear whole the pages
Try going through cartridge alignment process on printer.
7helpful
4answers
Lipi 6306 Line printer
i want to knwon the which operating system supports the lipi tally genicom line printer model 6306
Top Tally Office Equipment & Supplies Experts
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
