Question about AcerScan 320U Flatbed Scanner
Which plug Actually, I have an AcerScan 620 U. I moved and don't know which plug to use. Can you tell me the input/output specs?
I hav acer 320 scan my system not accept it how can i solve it please send me solution
Posted on Apr 26, 2008
Need a replacement power supply for a Evernote scanner
Sorry Gregory, gave you the wrong number.
You could try something like this. Various voltages and currents with different adapter plugs. This is on Ebay UK but I would think there are others, don't know where you are.
Ebay item number: 201154296095
1.Rated Input Voltage: AC 110V or AC240V
2.Vibration Input Voltage Range: AC95V-265V
3.Input Rated Current: 0.4-0.6AMP
4.Input Power: 90W
5.Efficiency: >88%(TYP)
6.Out Power: 90W
7.Output voltage: 15V/16V/18V/19V/20V/22V/24V(0/+0.5V NOLOAD): DC15V-24V
8.Output voltage: 15V/16V/18V/19V/20V/22V/24V(-0.4/0.5V@rating load): DC15V-24V
9.Output current: 15-20V/4.5A@22V-24V/4.0A: 4.5AMP(max)
10.Overload protection: YES
11.Short Circuit Protection: YES
Dec 17, 2014 | Office Equipment & Supplies
Driver want'
WIA driver for AcerScan 620
*Follow this link from Microsoft to download the latest driver.
*This page provides a list of Windows Image Acquisition (WIA) devices with built-in drivers in the Microsoft Windows XP operating system. There is no need for additional drivers to get the WIA experience out of the box when installing these devices.
*For up-to-date drivers for specific devices, see Microsoft Update.
Jul 11, 2010 | AcerScan 620P Flatbed Scanner
Acerscan prisa 620p driver problem
You can download an up to date XP driver for this scanner from
You will need to register and login but it is free.
Jul 21, 2009 | AcerScan 620S Flatbed Scanner
Power-AC Adaptor Have input specs but not output
is a starting point this model is exceptionally bad with PSU's
You may have problems actually getting one as the company was not in business very long so not many people had gotten repair stocks.
apparently the 3 common parts to fail are the switch, primary & secondary input smoothing caps. and the input chip on the PSU
You may well be able to get it repaired at a decent tv repair shop.
Sorry I could not be of more help
Ifthis post was useful please click
Jun 01, 2009 | Astar MP-32HB 32" Television
Hooking it up to my PC after moving
Get a usb cable... look at the back of the scanner so you know what the connector looks like... download software from then go under United States then Product support then go under Acer Tech Support. Download and install these drivers then plug in the scanners USB cable to the computer.
May 11, 2009 | AcerScan 620P Flatbed Scanner
Plugs for Astra Scanner 1220U
Ran across your request for information about the cables needed for hooking up the Umax Astra 1220U scanner. The scanner require a standard older version USB cable that hooks the scanner to your PC. The second cable is the Power Supply Adapter cable. The information listed on the Power Supply Adapter is listed below. P/N 490081-03 Input 120 Volt @ 60 Hz 0.3 amps Output DC 12 Volts @ 1 Amp Model # RWP481212 You should be able to get the scanner to work as long as you can find any power supply that has the listed Input/Output ratings, an adapter that will plug into the scanner. Hope this help you. disaksen
Apr 07, 2008 | Umax Astra 1220U Flatbed Scanner
check for the drivers for windows xp in the manufacturer's site or try at and install the driver in windows xp that's all your machine will work.
Apr 05, 2007 | AcerScan 620S Flatbed Scanner
My amp turn on but for some reason it dosent push out any power to the sub
Make sure there is not an input level control and that you have the right RCA connectors from the head unit connected. If you do see an input control first see from the head unit specs on what the max. output is comming out from the head units VIA the RCA Plugs. then see from the amp specs what the max. input should be inputted to the amp . If the output from the head unit is higher then the allowed input from the amp, your going to blow up the amp the first time you crank it. I have seen this happen many times. if you do not know how to balace the input of the amp please read the instructions on the amp or seek a professionals assistance.
Oct 09, 2006 | Kenwood KAC- X810D Car Audio Amplifier
AcerScan 320U Flatbed Scanner Logo
51 people viewed this question
Top Acer Office Equipment & Supplies Experts
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
