Question about Roper REX3614KW Electric Dryer
Dryer wont start.
Push button and nothing happens. It is not the outlet, already checked that.
  • 525 Answers
If your dryer doesn't work at all, it could be because of problems with:
Power from the house
Door switch
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 22, 2008
Dryer will not turn on
Normal 0 Hi, UNPLUG the dryer! Remove the rear panel of the dryer and locate the fuse. It is white and ¼” wide and 3” long. It is located on the blower housing. Remove the wires and check to see if it has continuity. If it does not, you need to replace it.
Please let me know if this help or if I can assist you further.
Thanks
Vic
May 30, 2009 | Dryers
Kenmore 80 serirs dryer wont start..
hi..check your circuit breaker,may be the power cord
is tripping it.If this is not the problem,check and see if
there is a reset button on the outlet where you plug in
the dryer.
try this out..
thank u..
kindly rate my response..
May 15, 2009 | Kenmore 44832 Front Load Washer
Nothing happens when I push the start button on my Gas Dryer
Three things you can check the door switch is it clicking? The thermal fuse you want to make sure there is continuity or worse case would be your motor.
Apr 02, 2009 | Whirlpool LGV4634JQ Gas Dryer
My whirlpool dryer wont start.
check the door switch and also the push to start button. Timers will advance even if the unit is not on
Mar 30, 2009 | Dryers
Kenmore 110.69912990
Need more info. Check voltage at outlet. Check thermal fuse,
check thermal cut-off assy. Then you have question -what caused the thermal to fail? There are several.
Mar 17, 2008 | Kenmore 73952 Gas Dryer
Wont start
try turning the drum by hand...is it jammed? if not, then: the motor will not turn due to a number of reasons: 1.) simply burned out copper windings 2.) switch not turning on motor or not turning on motor starting circuit-depending on design ...if jammed, then try to find the interference to turning
May 31, 2007 | Estate TEDX640JQ Electric Dryer
Roper REX3614KW Electric Dryer Logo
138 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
