Question about Philips Magnavox 27MS343S 27" TV
Magnavox resistor problem
Model TS2779 C121
serial # 4575839
trying to replace burned out resistor...tv has grey screen, diagonal lines, auto shuts off after 8-10 sec.
how do I locate the resistor need replacing? other help sites list finding it on the CRT board. where is this board?
Thanks.
Kristin
  • 2,326 Answers
The CRT board is the one that connects to the back of the CRT.
Follow the 200VDC line to locate the burnt resistor, is normally a low value fuse resistor.
Posted on Apr 15, 2008
Toshiba television, rear projection, HDTV. - Model #: 50H13 - Serial #: 15703904 - Chassis #: TAC 0360 Blue horizontal arcing line about 1/3 from bottom of screen, a few inches thick. Text...
ok turn the tv of for 40 minutes by the power point and back on that way it will reset all picture - and should go back to normal please let me now how this goes's
Make sure you un plugged it by the power point
Sep 15, 2008 | Televison & Video
Grey lines
this a vertical circuit, and HV Circuit Defective, send to repair
Jan 15, 2010 | Philips Magnavox 27MS343S 27" TV
The tv comes on and then goes completely out after about 20 sceonds. While it is on there are diagonal lines on a lime green field that do not move.
yes. if you have a black bright screen with about 16 to 20 horizontal lines going across, you have no video. suggest local service center. if it is a magnavox, this is easy. you have an open 1 ohm(approx. value) resistor on the crt board.
Nov 12, 2009 | RCA Televison & Video
Few water drops in the TV - 1997 Magnavox
check the vertical section,look for burn resistor or try replacing the vertical ic.
Aug 06, 2009 | Quasar SP-3235 32" TV
Magnavox MODEL # HD1905 C121 CHASSIS # 19E604-00AA SERIAL # 43468127 My Magnavox is stuck in a demo mode. I cannot turn the power on or off, and NONE of the buttons work, nor does the...
on the set press and hold the up and down volume buttons together till the tv turns off then press power to turn back on and everything should be fine
Jun 10, 2009 | Philips Magnavox 20MS3442 20" TV
Reference to Phillips Magnovox Model PR1302 C121.
turn on tv,it turns back off,without lighting screen.
May 04, 2009 | Philips Magnavox 27MS343S 27" TV
Tv Philips Magnavox won't turn on
Its Broken And Now Dangerous i would not even try getting it fix. That burnt smell is never a good sign
Sep 07, 2008 | Televison & Video
Have power but no sound or picture
Do you have high voltage? Check by turning up one of the screen controls to see if you have retrace lines.(pinstripe diagonal lines across the screen) If present turn the screen control back down until the lines just disappear. Check diodes 6003, 6012, 6025, and resistor 3669. If you don`t get a retrace line by turning up the one of the screen controls, check for missing voltages or shorted components in the horizontal output and power supply circuits. Note: Philips TV`s can be tricky even for experienced technicians. Good luck
May 22, 2008 | Philips 50P8341 50" Rear Projection...
Philips magnavox 25tr19 c121 problem
Still need info..? Can you replace soldered in parts.? Let me know.........................T.
Nov 16, 2007 | RCA F31672ET TV
Philips Magnavox 27MS343S 27" TV Logo
190 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
