Question about Canon ImageRUNNER 330s Copier
Error E005 Help ! I have the same error E005 on my ImageRunner 330s. I have replaced the web cleaning roller and I still get that error when I start the machine. It tells me to turn the main power off and on. I do that but nothing changes. I have not been able to reset the counter on the solenoid or reset the error message because the error message is on the same screen that I need to punch in the * to get to the programming and I can't get it to go away. I thought that maybe i needed to reinstall the web cleaning roller again and I did that but still the same error. I am stuck. Am I missing something? Any help would be appreciated.
  • 2 more comments
  • tgreen3101 Apr 15, 2008
    That did not work. Still showing the error
    That didn't work either
  • tgreen3101 Apr 22, 2008
    The belt looks like it is in great shape.
  • tgreen3101 Apr 23, 2008
    Thanks,
    I am off for the next couple of days but I will try it when I get back to work. I'll let you know what happens
  • 3,037 Answers
Hold down the numbers 2 and 8 when you power up the device and you should start in safe mode. This will allow you to reset the error.
Let me know if this doesn't work and I can further assist you.
Thank you for using Fixya and Good Luck!
Posted on Apr 15, 2008
  • Benjamin Patri
    Benjamin Patri Apr 16, 2008
    try replacing the feeding belt if it looks bad, this might just be your problem
  • Benjamin Patri
    Benjamin Patri Apr 23, 2008
    After much time I found that this may be what you need to do, let me know if it still doesn't help.
    If
    the first sensor on the front is blocked, you get a message to replace
    web. If the second is blocked, you get E005. Neither one of those
    should be blocked.Before you lower the top part, pull the sensor arm
    away from the sensors and then lower the top and click it back in place.
    The most likely cause of your problem is the connector on the DC
    Controller for the second web sensor. The connectors on pcb's in that
    model were prone to the terminals in the harness block stretching open
    and breaking contact at random. The best cure is to gently tighten each
    terminal for that connector with forceps and then use a contact
    cleaner/enhancer before reattaching the cable. I don't remember off
    hand which connector number it is, but I'll try to find out for you.
    Master:
    Sergeant:
  • 461 Answers
Try to reset it as below.
1. turn it off
2. remove the power supply contact.(make you remove the plug out from the socket).
3. Leave it for about 10 to 15 min.
Turn it on again.....
What does E005 mean?
The error code means that fuser cleaning web is about to run out or has run out. The fuser cleaning web cleans off the upper fuser roller (the hot one) and it also lubractes the roller. Most of the time when it runs out it starts to ruin the upper fuser roller. The best thing to do is to have the web replaced and the counter rest. If you just rest the counter, you may end up causing my damage to the fuser unit. Good Luck
Apr 10, 2012 | Canon imageRUNNER 400S Copier
I have the e005 code, where are the upper and lower fuser roller located in a ir 400s?
A E005 error code means that the cleaning web needs to be replaced & the web counter needs to be rest. The fuser unit is on the left side of the copier, the side that the paper comes out... Good Luck
Jan 22, 2011 | Canon imageRUNNER 400S Copier
E005 error
this error is related to web roller in your machines fixing unit.You must be check your web roller condition or replace it.try to clean all the sensor related to the same. if still not working then you clear error through service mode.for service mode press "addition function" then press 2 and 8 at the same time and again press "addition function". then go to COPIER > FUNCTION > CLEAR > ERROR. and press ok.and you clear web counter also in COUNTER .in under misc field > counter >web conter.
Jan 13, 2011 | Canon imageRUNNER 400S Copier
E005 Error How do solw, detail give
A E005 means that you need to replace the cleaning web in the fuser. If the web is not replaced the upper fuser roller will be worn out quickly
Oct 04, 2010 | Canon imageRUNNER 400S Copier
Ir 405 copier code as displayed e005. but what is problem i am changed web roller but still e005
Hi
Error E005 means the fuser cleaner roller has run out & may need a replacement. If the error is false it will disappear by following the reset procedure. To clear this error code press * 2 and 8 * in that 2&8 are pressed simultaneously. Go to the web counter and clear the counter back to Zero (0). Machine will now restart your machine & error code will disappear. If this doesn't help then try clearing both web counters in service mode, COUNTER>MISC>FIX-WEB> and COUNTER>DRBL-1>FIX-WEB> perform a Error Clear in service mode FUNCTION>CLEAR>ERR>. Hope this helps... Daniel
Sep 30, 2010 | Canon imageRUNNER 400S Copier
Error code e005
E005 is a fuser cleaning web error The fixing cleaning belt has been taken up. ? The fixing cleaning belt has been taken up. ? The DC controller PCB has a fault. ? The image processor PCB has a fault The fixing cleaning belt drive solenoid has been driven more than a specific number of times.
Apr 14, 2010 | Canon ImageRUNNER 330s Copier
Mon copieur me donne le code E005
A E005 means you need to replace the fuser cleaning web..
Mar 13, 2010 | Canon ImageRUNNER 330s Copier
E005 - which part(s) to replace?
E005 code refer to fixing web roller.After replacing the web be sure to reset the two web counter in service mode Copier-Counter- Misc-Fix_-Web and Copier=Counter-DRBL-1=FX Web.
Nov 17, 2009 | Canon ImageRUNNER 330s Copier
I get an error that says e005
E005
I the fuser web has run out
First you must replace the fuser web and then the code or counter needs re-setting.
If you let me know the model number I can tell you how to do this as the procedure is differant from model to model
Thank You
Jun 20, 2008 | Canon ImageRUNNER 330s Copier
Cannon Image Runner 330s
There is nothing wrong with the solenoid. The fuse cleaning web is similar to a roll of paper towels. For each copy made the copier fires the solenoid, advancing the web roll slightly. You can override the error but that will damage the upper fuser roller since it won't be cleaned and lubed properly. You need to replace (or have replaced) the cleaning web and reset the web counter in service mode. I am not sure on that model but when you purchase the web, $15-20, they can tell you how to reset it. Good Luck.
May 07, 2007 | Canon ImageRUNNER 330s Copier
115 people viewed this question
old marine
old marine
