Hi Is it worth changing the bearings for an old A3950 washer, it's got very noisy- is there anywhere I can find the procedure?
    Novelist:
  • 142 Answers
In my opinion, it's probably not worth replacing the bearings... envision the time to find parts and do the work only to find out that something else on the older machine was getting ready to break too. If it were me, I'd consider going after a newer machine. The prices aren't that bad, and they'll haul away the old machine and recycle it. AND... it's under warantee.
Good luck.
Posted on Apr 15, 2008
Noisy bearing while spinning
The seal in the drum has failed allowing water to leak into the bearings causing them to rust. Once the bearings are no longer round, the bearing noise will get louder. To replace, the washer needs to be taken apart and the drum needs to be removed in order to replace the bearings. Can be a difficult and expensive repair. Get a few estimates before deciding whether it is worth reparing. Sorry.
Oct 04, 2010 | Maytag Neptune Washer
Machine has become very noisey especially on the spinning programmes, is it time for a new one?
It could mean that either the bearings or the spider needs to be replaced. If you try to spin the wash basket by hand, does it turn smooth and quiet or do you hear a rumble sound? If it is noisy, it probally needs a bearing change. To change the bearing, the washer has to be taken completely appart to get access to the bearing. The parts cost are relatively inexpensive, but the labor costs is high due to the time to disassemble and reassemble the washer. If you are handy, and have the tools, you can buy the parts and do it yourself. You have to decide whether it is worth spending the time and money to fix or to purchase a new machine.
Jun 30, 2010 | Hotpoint First Edition WMA20 Front Load...
Very noisy when spinning - suspect bearing problem. Would appreciate advice on bearing replacement. Model no. WF 240
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 30, 2010 | Hotpoint Aquarius WF220 Front Load Washer
Loud jet noise in spin cycle on Kenmore stackable top load washer
it is the drum bearing seal and it has gone out and ruined the bearings,you would need a lip seal kit and appropriate bearings for that particular unit,i do a lot of maytag front loads and it can take anywhere from 2 hours up to 8 hours depending how the old bearings come out and the damage to the bearing and seal surfaces,the sooner you get to it the less chance of severe damage it will cause,because water will kep on destroying bearings till they lock up and destroy the drive pulley
Mar 05, 2010 | Kenmore 44042 Front Load Washer
Noisy drum, grinding sounds when the drum is spinning
Hi
The grinding sound is because of damaged or broken bearings.
You will have to see if the motor rotor bearing is damaged or the drum bearing before you change anything.
Regards
Berry
Feb 07, 2010 | Zanussi FS1155W Front Load Washer
Noisy drum on even moving by hand
It is definately the main drum bearings that have failed
To be honest with you , if the washer is more than 4 or 5 years old, you would be wise to call it a day, and purchase a new one, as it is an expensive job to put right..Sorry to bring you doom and gloom.
Merry xmas
Dec 17, 2009 | Creda W120VW Front Load Washer
Noisy motor
the best thing is to get a new motor from hotpoint website hope this helped
Mar 23, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Bearings on Hotpoint
the unit is only 18 nmohths old then what you need to do is contact the manufacture and explain to them what is happening and if they are having simuary isssues with that particular moidel number. Possibly they are and you may be able to have it repaired on their dime! 18 months is not that long for a washer to start having these problems if you have not abused the unit by overloading the washer or over filling it with soap. Good Luck
Jan 05, 2009 | Hoover AAA160 Front Load Washer
Noisy Servis M9503S
Hi.
Remve the belt, and turn the drum by hand, if it sounds rough or is noisy, then yes the main drum bearings have failed.
It is a DIY job , but can be expensive, probably cheaper to buy new washer if it is more than 3 or 4 years old.
Nov 22, 2008 | Hoover AAA140 Front Load Washer
Noisy spin cycle
Hey ****, what you are hearing is the spin bearing. Maytag redesigned the bearing kit on this washer, there must of been a lot of leaks causing the bearing to go bad. They put out a service flash...TDL-0060-B. New seal and bearing kit, part number12002470. You may want to contact Maytag on this for it could be covered. I know you have 5 years warranty on the transmission and If they change that, they have to use a new seal and bearing. Catriver...post back.
Oct 06, 2006 | Maytag SAV5710 Top Load Washer
Washing Machines Logo
55 people viewed this question
Top Washing Machines Experts
