Question about Motorola Mobility RAZR V3
V3 not charging
Hi...when phone is plugged in "Charging Battery " message appears along with a flashing red battery icon.
Battery does not get charged.
Battery and charger work fine on other phone. Any ideas??
    Sergeant:
    Champion:
  • 283 Answers
It's a hardware failure,, cant fix it here ..
Posted on Apr 16, 2008
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 25, 2013 | Motorola Mobility H560 Bluetooth Headset
I have htc windows 8x phone. My phone wont charge! i plug it in and the red charging battery icon doesn't appears, but it wont turn on no matter how long i charge it. i just got my phone 5 days ag
I think you have damaged your charging pin in the phone by mistake either by dropping the phone or while taking the cord out or inserting. I think the best way to get this fixed will be to go show it to the store that you bought it from/microsoft store. Hope this helps. All the best.
Mar 11, 2013 | HTC Windows Phone 8X
LG Secret charging
Dr Know, doesn't know what he's talking about. I have a LG KF750 and have experienced the same problem.
Solution - Really jam the cable into the socket! The connection is pretty rubbish. The phone charging icon will (with some force and wiggling) appear on screen. Then carefully put it down and don't touch it!
USB charges very slowly, if charging from a dead flat battery it may take a good 20mins of charging to boot up.
P.S. the red camera light is not supposed to come on when charging. Keep wiggling the cable and the light will go off when the phone charging icon appears.
Dec 16, 2008 | LG Secret ? KF750 Cellular Phone
Razr V3, charging the battery
take it to motorola service center
May 25, 2008 | Motorola Mobility RAZR V3
Battery?
I am afraid that your battery has malfunctioned. You will need to buy a new one. But before buying a new battery try leaving the battery out of the phone overnight, then try chargnig again.
Apr 18, 2008 | Motorola Mobility RAZR V3
Moto Razr v3
If theres no problem with your phone charging on its original battery before you replace it. the problem lies with the new battery you purchase, just replace it, coz some batteries are due to factory defects.
Feb 15, 2008 | Motorola Mobility RAZR V3
Not charging
you need to try a new battery...if that does not work you have to get the phone reflash with the correct firmware.
Dec 20, 2007 | Motorola Mobility RAZR V3
Battery light
This is pretty common and not necessarily a problem. Red means that the battery is not completely charged. Since it was charging all night, it most likely almost fully charged - say 99% or so. It's not really an issue as long as your battery icon has all the bars and the phone holds the charge for a normal amount of time. If you find that the charge lasts for less time than it should, you should probably replace the battery. My phone, for example, does this every so often and then will charge normally the next day.
Dec 05, 2007 | Motorola Mobility RAZR V3
Phone wont turn on!
i have noticed that the mini plug for the charger and usb connection on RAZR V3 is sometimes sloppy. when the phone is charging it will definitely say battery charging on the external display and also flash the battery icon. i also noticed that the plug for the wall outlet is touchy.
make sure the plug is secure in the wall outlet
make sure the mini plug is secure in the phone
gently wiggle these connections if you have to till you get the battery charging message
if there are any connection problems there will be a unable to charge message instead.
Nov 10, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
500 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
