Our PAV2300 has a problem filling. When I set it to fill just cold water, it will fill very slowly to the point it makes a very high pitch squeel that seems to be coming from the water pipes. When you turn it on warm then the problem goes away. We have replaced the water hoses for both the hot and cold but that didn't solve the problem. The washer is a little over 9 years old and had a new transmission installed in 11/06. What is the problem? Thanks!
I can tell you its not in the hoses, typically in the washer where the hoses go in there will be a screen. Check these screens, you will get a lot of sediment built up on these, i have to clean up mine every 2 years. This will still have to be done even if there is a water softener. If this is not the problem then I suggest checking every valve in the cold water system. Making sure they are opening fully.
