My MP3 won't charge up. I put it in the USB and the light doesn't light up and it won't charge. Please help me!!
  • 5 more comments
  • Changeman May 07, 2008
    Need new battery for my Insignia / NS-DA1G, where can I get one?
    Thanks
  • Oakcamaryw Jul 22, 2008
    My Toshiba gigabeat S60 MP3 Player does not hold the charge. After 30 minutes of playing it dies. Where do you take it for a battery replacement?
  • bstrawberryt Nov 18, 2008
    i plug it in and it wont light up
  • mr_haynes082 Nov 19, 2008
    my friend borrowed my creative zen microphoto mp3 and used the wrong charger now my mp3 wont turn on and isnt working right its been less then a year now
  • vincichick23 Nov 29, 2008
    my hp apple mp3 player will not turn on, even when it is on the charger.
    i have so many great songs on it but i'm affraid i will have to just throw it away. please tell me what to do.
  • I_love_Gary0 Jan 17, 2009
    My ipod wont charge up either..I can put it on the charge all nite and it still wont charge...can u help me plz??
  • Anonymous Apr 25, 2009
    suk my dik bithes i have no problem with my i pod wat asholes u guys are get an i pod and get a life instead of being on the pc or laptop all day fat *****
Yuo Need a new battery (iresq.com)
Posted on Apr 15, 2008
I put a sdcard in the mp3 player & it still won't hold a charge or save pictures that I take, why?
If you charge the MP3 player using the USB cable and the battery will not charge up then the battery is worn out and needs replacing.
Jan 01, 2013 | Audio Players & Recorders
Why isnt my ipod charging?
iPod's battery doesn't charge
Several things could keep your iPod's battery from charging. The major causes are listed below in logical order. Check each one to see if it's what's keeping your battery from charging.
Low-powered USB port
iPods that connect to USB ports require a high-power USB port.
Keyboards and some USB hubs will not charge iPod. Connect iPod directly to the computer or to a USB AC power adapter. Click here for more information.
Connect directly to computer
If you connect iPod to something that connects to the computer (like a USB hub or FireWire drive), connect iPod directly to the USB or
FireWire port on the computer.
FireWire port on a Windows PC
The FireWire (IEEE 1394) ports on some Windows-compatible computers may not be powered, and consequently won't charge iPod when you plug it in. Check here to see if the FireWire port on your PC can charge iPod.
Your computer goes to sleep
Your computer can only charge iPod when it's turned on and not asleep. Make sure your computer is on and not set to go to sleep when you want to charge iPod. Tip:
Some Macintosh computers can charge iPod even though they're asleep.
If your sleeping computer doesn't charge iPod, don't worry, just wake it and let iPod charge.
hope this helps
Aug 14, 2012 | Apple iPod touch
Blackberry won't charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Aug 02, 2012 | RIM BlackBerry Curve 8520 Smartphone
Gigaware mp3 will not hold its charge, when i unplug usb cord it dies out
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% and graduallythe charge reduces until the battery won't charge up at all. OR The batteryshows a 100% charge but when the adapter is disconnected the battery drops offto zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
Mar 28, 2012 | Audio Players & Recorders
My mp3 doesn't turn on but when i put it on the computer, the mp3 turn on then i unput it turn right away turn off
When you plug it into your computer, press "USB Charge" on your V-Touch. This should charge it while its pluged into your computer.
Feb 21, 2012 | Visual Land V-Touch Digital Media Player
It doesnt turn on and charge
If you charge off USB and the device won't turn on you could try charging it with a wall charge as some devices need to be on to charge from USB .
Jan 03, 2012 | Emerson Audio Players & Recorders
Won't come on after charging in usb hub
Depending on how long you've had the player, the batteries may need replacing.
I have seen a problem where the computer would not recognize the player and would not charge it, however.
First, I recommend trying to charge it directly from the computer USB port (not the hub) if possible. If that doesn't help, try reinstalling the software for the player to see if the computer will then recognize it and allow charging.
If neither of these fix the problem, it's probably time to replace the batteries.
Jul 13, 2011 | MyMusix PD-6070 MP3 Player
722 people viewed this question
 Grubhead
Grubhead
