Question about Vacuums
Handle for model bissell 3550 - Vacuums
    President:
  • 1,673 Answers
If 3550 is the correct model number, then parts are no longer available for this model.
Posted on Apr 15, 2008
Switching new belt for old on older model 3550 Bissell vacuum. Where does belt go and does it go around sweeper bar?
If it has a belt it goes around the sweeper part and connects to the motor.
Dec 03, 2012 | Vacuums
Bissel cleaner won't stop spraying water
Remove the handle and check for continuous spray.
After handle is removed, check to make sure the valve is not stuck in the down position. If the valve is stuck in the down position, push on it manually to get it to come back up. If it is stuck you may need to get a new handle for your unit. This handle is for a variety of the ProHeat models http://www.bissell.com/parts/?sc=part&productid=2775&partid=4449&cid=ccsocial
Check to make sure it will properly fit your model if you need a new handle.
May 08, 2012 | Bissell ProHeat Turbo Deep Cleaner Upright...
Trying to find replacement part for a Bissell Power Steamer Deluxe Model 1631-1, Part Grip and Trigger Assembly Part No. 016-4181
http://www.bettervac.com/bissell-016-4181-handle-assembly-for-big-green-machine.asp
Hopefully this helps.
Mar 31, 2011 | Bissell Vacuums
There does not seem to be a handle release button on my bissell shampooer and I can't get the handle to release. Model 08239 C 082390
Seems like the on/off switch is at the bottom of the handle on one side, and the handle release is on the other side. Both are foot switches; that is to say that they're operated with your foot.
--W/D--
Jan 20, 2011 | Bissell Vacuums
New replacement pump on Bissell ProHeat Protech not working
Not sure if I have the same model but this is what I found on mine this morning - wire to switch in the handle came off. Un-plug power cord. Unscrew top two screws on upright handle and remove the front cover above the trigger. see if wires are connected. top connector is not used - if you do solution will spray all the time. Good luck!
Jul 09, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
How do i take off the handle release pedal on a Bissell model 8990 cleanview bagless sweeper so i can fix it ret1@tampabay rr.com
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=539036
Generic problem for all Vacuums
How do i take off
Posted by retthom on Apr 23, 2008
ret1@tampabayrr.com
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Mostly, you need to remove the top cover to the Bissell in order to get @ the handle release pedal. There could be screws on the bottom 2 or 3 screws or the top cover could be held on plastic clips or levers and they would have to be released then the top cover would come off.
This should expose the handle release pedal. If you need more information please feel free to contact your local vacuum cleaner dealer in your area in the yellow pages, or use the trouble shooting guide in the owner’s manual or you can call the Bissell factory @ the information listed below:
http://www.bissell.com/ By Phone Customer Service:
(800) 237-7691 Hours:
M-F 8:00 a.m. - 10:00 p.m. ET
Saturday 9:00 a.m. - 8:00 p.m. ET
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 23, 2008 | Vacuums
My power brushes on my bissel carpet cleaner stopped working. They do not rotate. This is the 2nd power cleaner I have bought and it has the same problem as the first one. What is the problem with the...
The brushes will only work if the handle is released and the ProHeat vacuum is running . There is a micro switch inside the lower handle that switches on the DC carpet brush motor. The DC power for the motor comes from a Bridge Rectifier on the PC Board. petedcurtis@gmail.com
Apr 18, 2008 | Bissell Vacuums
Male plug needs to be replaced.
I had same problem with my lift-off, i sent email to Bissell explaining what the problem was and where to get replacement parts. They sent me emial back saying they will send me refeb replacement vacuum becasue this part has been discontinued (I think there is a prolem with lift-off and Bissell is trying to make it right for their customer without official recall). I did get my fedex lable and i sent entier length of cord from my lift-off back to them. I should be getting my refeb vacuum soon.
---Pete
Apr 05, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Carpet shampooer
I couldn't find the exact guide for your model but the two links below are the ones bissell told me to use. http://www.bissell.com/images/UserGuides/1694-8806_607.pdf http://www.bissell.com/images/UserGuides/1697_1205.pdf I hope this helps:)
Jul 15, 2007 | Bissell 1697-7 Powersteamer Pro Deluxe...
Vacuums Logo
50 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
