http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Refrigerator-Parts/Model-GSS25KGMAWW/0432/0165000/G0311087/00009?blt=06&prst=0&shdMod=GSS25KGMAWWgo here and look at part number 810,this is the water tank in the fridge section,get a hair dryer and heat up the tank where the water lines connect to it,also g.e. has problems with the water line in the freezer door the line freezes up.also when was the last time you changed the water filter?try this,open the freezer door and remove the bottom kickplate,on the left side you'll find a connector for the water line,disconnect it shut the door and hit the water dispenser,if water comes out of line where you disconnected it then you know the line in the door is frozen,if no water comes out i would change the filter and it that doesn't work i'd have to say you have a bad water valve.one more thing and this might sound crazy but if i didn't see it myself i wouldn't believe it,when you went to dispense water have you ever noticed that the condenser fan motor would sound like it was slowing down and also the strip in the middle where the doors close together touch it to see if it's hot,i've found three mother boards bad from this,i'd dispense water, and the fans would slow down, i hope i'm not confusing you by telling you this,lets stick with the basic things first disconnect the water line under the freezer door and behind the kickplate,shut the door and hit the dispenser,if water comes out of the hose the water line is frooze in the door,if no water comes out,heat up the water tank with a hair dryer,after a while like 5 to 10 minutes hit the dispenser but water will leak out the tube if the tanks frozen,if that doesn't do the trick i would change the water filter and if that doesn't work bad water valve,if you look down where the kickplate is you should find a tech sheet that will tell you how to jump out the ice maker,now what did you change out the ice maker?you said you changed two parts,what's happening that you changed the ice maker,was it not getting water to it,i mean if you're not getting water through the door and no water to ice maker,you either have a bad water valve or filter,start there and heat up the water tank,if that's frozen you won't get any wateralso look at this it will tell you how to start the harvest cycle on the ice maker,i beleive you shut it off for 20 seconds,turn it back on and move the arm in and out like three times.
http://appliantology.org/topic/29479-ge-icemaker-wont-fill-or-harvest/hope this helps and good luck,let me know please what you find.
I have this same problem, I have a GE Fridge with ice maker and the same thing occurred with the water not shutting of, the serial number is 197d2303 g0 81 which is located on the ice box itself and the serial number to the fridge is AF212060. Where can I locate a replacement ice maker for this fridge?
