Question about LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive
Lacie drive makes popping noise, goes offline, corrupts files
I have a Lacie 500 gb external drive that began making a strange popping noise this morning. I am using the drive to store Final Cut Pro 6 projects. The noise pops, and then FCP "thinks" for a moment. The drive begins to remount and then the sound comes back. I shut the drive down this morning for a few minutes and then FCP gave me an error message saying that the file was now unreadable. After switching computers ad getting the same message, I went through my autosave vault to find a working version of my project. When I found one from yesterday morning that would work the popping noise came back and I'm back to the same problem. The project is under deadline for an important client. Any suggestions?
  • 30 Answers
I'm afraid your hard drive is cactus. The popping noise is most likely the read head hitting the cylinder. This is causing more and more physical damage to the PC as it attempts to read the files. You will most likely need to consult the supplier of the equipment for a warranty replacement, or go through the vendor. If the drive is out of warranty I suggest buying a new one and throwing the old away.
There is no way to recover a drive that is physically colliding the head with one of the drive plattes.
Posted on Apr 23, 2008
I was copying an avi file from the 250GB lacie porsche hard drive (USB2) and the USB cable got removed while the copy was in progress. I tried restarting the computer but the hard drive isnt regonised. it...
hi.
maybe problem is caused by your Power supply.
so i recommend you to do these:
1- remove the main hard drive and only connect "250GB lacie porsche hard drive".
and see is it recognized or not.
2- go to the bios (with pressing "delete key" at start of turning on) and navigate to power center.
then enable power saving mode.
Jan 29, 2011 | LaCie (300728U) 250 GB Hard Drive
LaCie Big Disk 500GB not showing up
1. the usb connector in the PC may have a broken board contact needs soldering or replacement.
2. there may be a broken USB cord to the external usb drive
3. the electronic controller in the USB case may not be working.
4. A new case may be needed with a new controller.
Jul 08, 2010 | LaCie Big Disk Extreme 500 GB Hard Drive
Lacie ext hard drive, 500 GB, doesn't show files but 123GB used
you can always recover your files with the program undelete . exe
verry good working tool.
if you are interested
Feb 13, 2010 | LaCie External USB 2.0 500GB 7200 RPM 500...
Strange noises, disk won't fully spin or start up...
Your AC adapter is "dying", and must be replaced.
Is it still under "warranty", i.e., you contact LaCie,
get an RMA (Return Materials Authorization) number,
they ship you a new adapter. If you ship them the old adapter,
within a week, they will _not_ charge your credit-card the $30.
Sep 19, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
I WANT TO OPEN THE LACIE 500 GB HDD AND USE THE HDD IN MY DESK TOP
Go for it. There's a chance the internal drive will be PATA (IDE) but odds are good it's a SATA drive with standard connections.
Make sure your PC has connections for SATA drives, and you'll need to buy a SATA cable since the one in the LaCIE case won't connect from your drive to your motherboard.
Sep 08, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
LACIE 500 GB HARD DRIVE
i use my external hard disk many times but now when i connect my lacie external H.D to PC it dose not recognized
Jan 30, 2009 | LaCie (300951U) 500 GB Hard Drive
My lacie is making clicking noise like clock
Hello
Have a look at the link below, it should be of help.
Click HERE to navigate.
Please feel free to let me know of you have any further questions.
Kind regards
Lock123
Dec 31, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Lacie 320 GB Hard Drive acting as if full when it's not.
Simplest solution: back up the data on the drive and repartition it (which will wipe it). Otherwise it sounds like it could be a problem with the file tree or structure of the drive, the configuration files could be corrupt, some program could have stored temporary files in a hidden place that cannot be deleted without making the program delete them, etc. If you are on a mac, spotlight Disk Utility and use it to repartition. If you are on a PC use the search thing from the start menu and find a program called disk management (or something similar to that, you'll know it when you see it.) external drives are annoying. i kick mine into the wall periodically for good measure.
Mar 22, 2008 | LaCie (300950) 400 GB Hard Drive
Hard drive making strange alarm/chiming noise and won't load onto desktop
Listen to your power supply and see if it is making a faint buzzing noise. Try your device with a new power supply. With a new power supply my drive now runs fine, and was not corrupted.
Jan 13, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Power light blinking orange/yellow. does not mount or recognise
IN SPANISH...USE TRADUCTOR OR TRANSLATE.... TRATA DE USAR UN SOFTWARE LLAMADO PARTITION MAGIC DESDE LA SE?AL C: O SEA BAJO DOS.... PERO ANTES CONTESTAME TU BOOT O SOFTWARE DE INICIO RECONOCE EL DISCO DURO?... SI NO LO HACE O ES UNA DA?O LOGICO O SEA DE LA TARJETA DEL DISCO DURO, O FISICO, DEL DISCO EN SI, LO CUAL EXPLICARIA EL RUIDO.... HAY EN INTERNET SOFTWARE FREE.... PARA DIAGNOSTICO Y HASTA REPARACION... UNO DE LOS MEJORES SE LLAMA HIREN´S BOOT CD Y SE BAJA COMO UN ISO Y LUEGO LO GRABAS EN UN CD LUEGO HACES BOOT CON EL Y CORRES EL SOFTWARE QUE QUIERAS, INCLUYENDO EL PARTITION MAGIC, ESPERO QUE TENGAS SUERTE. SI PUEDO SERTE DE MAS AYUDA TENDRIAS QUE SER UN POCO MAS ESPECIFICO. HAY OTRO SOFTWARE BAJO LINUX LLAMADO KANOPPIX Y EL EN OCASIONES RECONOCE LO QUE OTROS SISTEMAS OPERATIVOS NO HACEN.... ASI POR LO MENOS RECUPERARIAS TU INFORMACION Y SI ESTAS DE BUENAS LO FORMATEAS DE NUEVO Y RECUPERAS TU DISCO. ESTE TAMBIEN LO CONSIGUES EN INTERNET Y ES FREE.
Jan 14, 2007 | LaCie (300728U) 250 GB Hard Drive
LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive Logo
146 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
